1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
40 # Set path to fallback-tool for dependency-resolution. 41 if(NOT DEFINED CMAKE_OBJDUMP)
42 set(CMAKE_OBJDUMP
"/usr/sbin/objdump")
46 file(INSTALL DESTINATION
"vtkIOGeometry-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOGeometry-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv6.2.so.6.2
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv6.2.so.1
" 54 if(EXISTS "${file}
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOGeometry-pv6.2.so.6.2
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOGeometry-pv6.2.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv6.2.so.6.2
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOGeometry-pv6.2.so.1
" 69 if(EXISTS "${file}
") 75 if(CMAKE_INSTALL_DO_STRIP) 76 execute_process(COMMAND "/usr/sbin/strip
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOGeometry-pv6.2.so
" TYPE FILE FILES 91 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/GLTFSampler.h
" 93 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/
vtkBYUReader.h
" 94 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/
vtkBYUWriter.h
" 95 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/
vtkChacoReader.h
" 96 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/
vtkFacetWriter.h
" 99 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkGLTFDocumentLoader.h
" 100 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkGLTFReader.h
" 101 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkGLTFTexture.h
" 102 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkGLTFWriter.h
" 104 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/
vtkIVWriter.h
" 107 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/
vtkMFIXReader.h
" 108 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/
vtkOBJReader.h
" 109 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkOBJWriter.h
" 110 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/vtkOFFReader.h
" 114 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/
vtkPTSReader.h
" 115 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/
vtkSTLReader.h
" 116 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Geometry/
vtkSTLWriter.h
" 122 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 123 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Geometry/vtkIOGeometryModule.h
") 126 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 127 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Geometry/vtkIOGeometry.spdx
") 130 string(REPLACE ";
" "\n
" CMAKE_INSTALL_MANIFEST_CONTENT 131 "${CMAKE_INSTALL_MANIFEST_FILES}
") 132 if(CMAKE_INSTALL_LOCAL_ONLY) 133 file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Geometry/install_local_manifest.txt
" 134 "${CMAKE_INSTALL_MANIFEST_CONTENT}
