1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
40 # Set path to fallback-tool for dependency-resolution. 41 if(NOT DEFINED CMAKE_OBJDUMP)
42 set(CMAKE_OBJDUMP
"/usr/sbin/objdump")
46 file(INSTALL DESTINATION
"vtkChartsCore-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkChartsCore-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv6.2.so.6.2
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv6.2.so.1
" 54 if(EXISTS "${file}
") 58 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkChartsCore-pv6.2.so.6.2
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkChartsCore-pv6.2.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv6.2.so.6.2
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv6.2.so.1
" 69 if(EXISTS "${file}
") 73 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 74 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 75 if(CMAKE_INSTALL_DO_STRIP) 76 execute_process(COMMAND "/usr/sbin/strip
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkChartsCore-pv6.2.so
" TYPE FILE FILES 91 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkAxis.h
" 94 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkChart.h
" 95 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkChartBox.h
" 97 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkChartLegend.h
" 98 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkChartMatrix.h
" 100 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkChartPie.h
" 101 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkChartXY.h
" 102 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkChartXYZ.h
" 103 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkColorLegend.h
" 108 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkContextArea.h
" 111 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkInteractiveArea.h
" 116 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlot.h
" 117 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlot3D.h
" 118 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlotArea.h
" 119 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlotBag.h
" 120 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlotBar.h
" 121 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotBarRangeHandlesItem.h
" 122 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlotBox.h
" 124 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlotGrid.h
" 126 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlotLine.h
" 127 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlotLine3D.h
" 129 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlotPie.h
" 130 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlotPoints.h
" 132 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotRangeHandlesItem.h
" 133 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlotStacked.h
" 134 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/
vtkPlotSurface.h
" 135 "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkRangeHandlesItem.h
" 141 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 142 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES 143 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Charts/Core/vtkChartsCoreModule.h
" 144 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Charts/Core/vtkChartsCoreSerDes.h
" 148 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 149 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Charts/Core/vtkChartsCore.spdx
") 152 string(REPLACE ";
" "\n
" CMAKE_INSTALL_MANIFEST_CONTENT 153 "${CMAKE_INSTALL_MANIFEST_FILES}
") 154 if(CMAKE_INSTALL_LOCAL_ONLY) 155 file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTK/Charts/Core/install_local_manifest.txt
" 156 "${CMAKE_INSTALL_MANIFEST_CONTENT}
