1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkAcceleratorsVTKmDataModel-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkAcceleratorsVTKmDataModel-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv6.2.so.6.2"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv6.2.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkAcceleratorsVTKmDataModel-pv6.2.so.6.2"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkAcceleratorsVTKmDataModel-pv6.2.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv6.2.so.6.2"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv6.2.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:"
74  NEW_RPATH "\$ORIGIN")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkAcceleratorsVTKmDataModel-pv6.2.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Accelerators/Vtkm/DataModel/vtkmConfigDataModel.h")
91 endif()
92
93 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Accelerators/Vtkm/DataModel/vtkAcceleratorsVTKmDataModelModule.h")
95  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/vtkmlib" TYPE FILE FILES
96  "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/ArrayConverters.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/CellSetConverters.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/DataSetConverters.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/ImageDataConverter.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/ImplicitFunctionConverter.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/PolyDataConverter.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/UnstructuredGridConverter.h"
103  )
104 endif()
105
106 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses" OR NOT CMAKE_INSTALL_COMPONENT)
107  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkAcceleratorsVTKmDataModel" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/LICENSE")
108 endif()
109
110 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
111  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Accelerators/Vtkm/DataModel/vtkAcceleratorsVTKmDataModel.spdx")
112 endif()
113
