1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Testing
40 # Set path to fallback-tool for dependency-resolution.
42  set(CMAKE_OBJDUMP "/usr/sbin/objdump")
47  include("/builds/gitlab-kitware-sciviz-ci/build/Remoting/Views/Testing/Cxx/cmake_install.cmake")
48 endif()
49
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51  # Include the install script for the subdirectory.
52  include("/builds/gitlab-kitware-sciviz-ci/build/Remoting/Views/Testing/Python/cmake_install.cmake")
53 endif()
54
55 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
56  "${CMAKE_INSTALL_MANIFEST_FILES}")
57 if(CMAKE_INSTALL_LOCAL_ONLY)
58  file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Views/Testing/install_local_manifest.txt"
59  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
60 endif()
