1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/StreamingParticles/Testing
40 # Set path to fallback-tool for dependency-resolution.
42  set(CMAKE_OBJDUMP "/usr/sbin/objdump")
45 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
46  "${CMAKE_INSTALL_MANIFEST_FILES}")
47 if(CMAKE_INSTALL_LOCAL_ONLY)
48  file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/Plugins/StreamingParticles/Testing/install_local_manifest.txt"
49  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
50 endif()
