1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.1/plugins/ParFlow/vtk/hierarchy/ParFlow" TYPE FILE RENAME
"vtkParFlowIO-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.1/plugins/ParFlow/vtk/hierarchy/ParFlow/vtkParFlowIO-hierarchy.txt")
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "plugins" OR NOT CMAKE_INSTALL_COMPONENT)
50 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.1/plugins/ParFlow/libvtkParFlowIO.so
" AND 51 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.1/plugins/ParFlow/libvtkParFlowIO.so
") 53 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.1/plugins/ParFlow/libvtkParFlowIO.so
" 54 RPATH "\$ORIGIN:\$ORIGIN/../../../
") 56 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.1/plugins/ParFlow
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.1/plugins/ParFlow/libvtkParFlowIO.so
") 57 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.1/plugins/ParFlow/libvtkParFlowIO.so
" AND 58 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.1/plugins/ParFlow/libvtkParFlowIO.so
") 60 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.1/plugins/ParFlow/libvtkParFlowIO.so
" 61 OLD_RPATH "\$ORIGIN/../../../::::::::
" 62 NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../
") 63 if(CMAKE_INSTALL_DO_STRIP) 64 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.1/plugins/ParFlow/libvtkParFlowIO.so
") 69 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 72 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 75 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 76 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins
" TYPE FILE FILES 77 "/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO/vtkParFlowReader.h
" 78 "/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO/vtkParFlowMetaReader.h
" 82 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 83 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/ParFlow/IO/vtkParFlowIOModule.h
") 86 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 87 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/ParFlow/IO/vtkParFlowIO.spdx
