3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
6 if(CMAKE_VERSION VERSION_LESS "2.8.12")
7 message(FATAL_ERROR "CMake >= 2.8.12 required")
10 cmake_policy(
VERSION 2.8.12...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS LegacyGhostCellsGeneratorFilters LegacyGhostCellsGeneratorParallel)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Compute the installation prefix relative to this file. 50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 54 if(_IMPORT_PREFIX STREQUAL "/
") 55 set(_IMPORT_PREFIX "") 58 # Create imported target LegacyGhostCellsGeneratorFilters 59 add_library(LegacyGhostCellsGeneratorFilters SHARED IMPORTED) 61 set_target_properties(LegacyGhostCellsGeneratorFilters PROPERTIES 62 INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel
" 65 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 66 target_sources(LegacyGhostCellsGeneratorFilters 68 FILE_SET "vtk_module_templates
" 70 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 73 FILE_SET "vtk_module_headers
" 75 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 76 FILES "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins/vtkUnstructuredGridGhostCellsGenerator.h
" 78 FILE_SET "vtk_module_nowrap_headers
" 80 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 81 FILES "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins/LegacyGhostCellsGeneratorFiltersModule.h
" 84 set_property(TARGET LegacyGhostCellsGeneratorFilters 85 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 86 "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 87 "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 88 "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 92 # Create imported target LegacyGhostCellsGeneratorParallel 93 add_library(LegacyGhostCellsGeneratorParallel SHARED IMPORTED) 95 set_target_properties(LegacyGhostCellsGeneratorParallel PROPERTIES 96 INTERFACE_LINK_LIBRARIES "LegacyGhostCellsGeneratorFilters;VTK::CommonExecutionModel;VTK::CommonSystem;VTK::FiltersCore;VTK::FiltersGeneral;VTK::FiltersGeometry;VTK::ParallelMPI
" 99 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 100 target_sources(LegacyGhostCellsGeneratorParallel 102 FILE_SET "vtk_module_templates
" 104 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 107 FILE_SET "vtk_module_headers
" 109 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 112 FILE_SET "vtk_module_nowrap_headers
" 114 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 115 FILES "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins/LegacyGhostCellsGeneratorParallelModule.h
" 118 set_property(TARGET LegacyGhostCellsGeneratorParallel 119 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 120 "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 121 "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 122 "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 126 # Load information for each installed configuration. 127 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/LegacyGhostCellsGenerator-targets-*.cmake
") 128 foreach(_cmake_config_file IN LISTS _cmake_config_files) 129 include("${_cmake_config_file}
") 131 unset(_cmake_config_file) 132 unset(_cmake_config_files) 134 # Cleanup temporary variables. 137 # Loop over all imported files and verify that they actually exist 138 foreach(_cmake_target IN LISTS _cmake_import_check_targets) 139 if(CMAKE_VERSION VERSION_LESS "3.28
" 140 OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target} 141 OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}
") 142 foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}
") 143 if(NOT EXISTS "${_cmake_file}
") 144 message(FATAL_ERROR "The imported
target \
"${_cmake_target}\" references the file 146 but this file does not exist. Possible reasons include: 147 * The file was deleted, renamed, or moved to another location. 148 * An install or uninstall procedure did not complete successfully. 149 * The installation package was faulty and contained 150 \"${CMAKE_CURRENT_LIST_FILE}\" 151 but not all the files it references. 157 unset("_cmake_import_check_files_for_${_cmake_target}
") 160 unset(_cmake_import_check_targets) 162 # Make sure the targets which have been exported in some other 164 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 165 foreach(_target "VTK::CommonExecutionModel
" "VTK::CommonSystem
" "VTK::FiltersCore
" "VTK::FiltersGeneral
" "VTK::FiltersGeometry
" "VTK::ParallelMPI
" ) 166 if(NOT TARGET "${_target}
" ) 167 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 171 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 172 if(CMAKE_FIND_PACKAGE_NAME) 173 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 174 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 176 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 179 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 181 # Commands beyond this point should not need to know the version. 182 set(CMAKE_IMPORT_FILE_VERSION)
