GenericIOReader-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.12")
7  message(FATAL_ERROR "CMake >= 2.8.12 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.12...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS GenericIOReader::vtkGenericIOReader GenericIOReader::LANL_GenericIO)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Compute the installation prefix relative to this file.
50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
54 if(_IMPORT_PREFIX STREQUAL "/")
55  set(_IMPORT_PREFIX "")
56 endif()
57
58 # Create imported target GenericIOReader::vtkGenericIOReader
59 add_library(GenericIOReader::vtkGenericIOReader SHARED IMPORTED)
60
61 set_target_properties(GenericIOReader::vtkGenericIOReader PROPERTIES
62  INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::ParallelCore;VTK::ParallelMPI;GenericIOReader::LANL_GenericIO"
63 )
64
65 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
66  target_sources(GenericIOReader::vtkGenericIOReader
67  INTERFACE
68  FILE_SET "vtk_module_templates"
69  TYPE "HEADERS"
70  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
71  FILES
72  INTERFACE
73  FILE_SET "vtk_module_headers"
74  TYPE "HEADERS"
75  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
76  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkGenIOReader.h"
77  INTERFACE
78  FILE_SET "vtk_module_nowrap_headers"
79  TYPE "HEADERS"
80  BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
81  FILES "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins/vtkGenericIOReaderModule.h"
82  )
83 else()
84  set_property(TARGET GenericIOReader::vtkGenericIOReader
85  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
86  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
87  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
88  "${_IMPORT_PREFIX}/include/paraview-6.1/ParaView_paraview_plugins"
89  )
90 endif()
91
92 # Create imported target GenericIOReader::LANL_GenericIO
93 add_library(GenericIOReader::LANL_GenericIO STATIC IMPORTED)
94
95 set_target_properties(GenericIOReader::LANL_GenericIO PROPERTIES
96  INTERFACE_COMPILE_DEFINITIONS "LANL_GENERICIO_NO_MPI"
97 )
98
99 # Load information for each installed configuration.
100 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/GenericIOReader-targets-*.cmake")
101 foreach(_cmake_config_file IN LISTS _cmake_config_files)
102  include("${_cmake_config_file}")
103 endforeach()
104 unset(_cmake_config_file)
105 unset(_cmake_config_files)
106
107 # Cleanup temporary variables.
108 set(_IMPORT_PREFIX)
109
110 # Loop over all imported files and verify that they actually exist
111 foreach(_cmake_target IN LISTS _cmake_import_check_targets)
112  if(CMAKE_VERSION VERSION_LESS "3.28"
113  OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target}
114  OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}")
115  foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}")
116  if(NOT EXISTS "${_cmake_file}")
117  message(FATAL_ERROR "The imported target \"${_cmake_target}\" references the file
118  \"${_cmake_file}\"
119 but this file does not exist. Possible reasons include:
120 * The file was deleted, renamed, or moved to another location.
121 * An install or uninstall procedure did not complete successfully.
122 * The installation package was faulty and contained
123  \"${CMAKE_CURRENT_LIST_FILE}\"
124 but not all the files it references.
125 ")
126  endif()
127  endforeach()
128  endif()
129  unset(_cmake_file)
130  unset("_cmake_import_check_files_for_${_cmake_target}")
131 endforeach()
132 unset(_cmake_target)
133 unset(_cmake_import_check_targets)
134
135 # Make sure the targets which have been exported in some other
136 # export set exist.
137 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
138 foreach(_target "VTK::CommonCore" "VTK::CommonDataModel" "VTK::CommonExecutionModel" "VTK::ParallelCore" "VTK::ParallelMPI" )
139  if(NOT TARGET "${_target}" )
140  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
141  endif()
142 endforeach()
143
144 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
145  if(CMAKE_FIND_PACKAGE_NAME)
146  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
147  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
148  else()
149  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
150  endif()
151 endif()
152 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
153
154 # Commands beyond this point should not need to know the version.
155 set(CMAKE_IMPORT_FILE_VERSION)
156 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
