3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
6 if(CMAKE_VERSION VERSION_LESS "2.8.12")
7 message(FATAL_ERROR "CMake >= 2.8.12 required")
10 cmake_policy(
VERSION 2.8.12...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS BivariateRepresentations::vtkBivariateRepresentations)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Compute the installation prefix relative to this file. 50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 54 if(_IMPORT_PREFIX STREQUAL "/
") 55 set(_IMPORT_PREFIX "") 58 # Create imported target BivariateRepresentations::vtkBivariateRepresentations 59 add_library(BivariateRepresentations::vtkBivariateRepresentations STATIC IMPORTED) 61 set_target_properties(BivariateRepresentations::vtkBivariateRepresentations PROPERTIES 62 INTERFACE_LINK_LIBRARIES "ParaView::RemotingViews;VTK::RenderingOpenGL2;\$<LINK_ONLY:ParaView::RemotingMisc>;\$<LINK_ONLY:ParaView::VTKExtensionsFiltersRendering>;\$<LINK_ONLY:VTK::CommonCore>;\$<LINK_ONLY:VTK::RenderingContextOpenGL2>;VTK::PythonUsed
" 65 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 66 target_sources(BivariateRepresentations::vtkBivariateRepresentations 68 FILE_SET "vtk_module_templates
" 70 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 73 FILE_SET "vtk_module_headers
" 75 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 76 FILES "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins/vtkBivariateNoiseMapper.h
" "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins/vtkBivariateNoiseRepresentation.h
" "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins/vtkBivariateTextureRepresentation.h
" "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins/vtkContext2DTexturedScalarBarActor.h
" "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins/vtkContext2DTexturedScalarBarRepresentation.h
" "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins/vtkSMBivariateTextureRepresentationProxy.h
" "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins/vtkOpenGLBivariateNoiseMapperDelegator.h
" 78 FILE_SET "vtk_module_nowrap_headers
" 80 BASE_DIRS "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 81 FILES "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins/vtkBivariateRepresentationsModule.h
" 84 set_property(TARGET BivariateRepresentations::vtkBivariateRepresentations 85 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 86 "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 87 "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 88 "${_IMPORT_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" 92 # Load information for each installed configuration. 93 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/BivariateRepresentations-targets-*.cmake
") 94 foreach(_cmake_config_file IN LISTS _cmake_config_files) 95 include("${_cmake_config_file}
") 97 unset(_cmake_config_file) 98 unset(_cmake_config_files) 100 # Cleanup temporary variables. 103 # Loop over all imported files and verify that they actually exist 104 foreach(_cmake_target IN LISTS _cmake_import_check_targets) 105 if(CMAKE_VERSION VERSION_LESS "3.28
" 106 OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target} 107 OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}
") 108 foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}
") 109 if(NOT EXISTS "${_cmake_file}
") 110 message(FATAL_ERROR "The imported
target \
"${_cmake_target}\" references the file 112 but this file does not exist. Possible reasons include: 113 * The file was deleted, renamed, or moved to another location. 114 * An install or uninstall procedure did not complete successfully. 115 * The installation package was faulty and contained 116 \"${CMAKE_CURRENT_LIST_FILE}\" 117 but not all the files it references. 123 unset("_cmake_import_check_files_for_${_cmake_target}
") 126 unset(_cmake_import_check_targets) 128 # Make sure the targets which have been exported in some other 130 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 131 foreach(_target "ParaView::RemotingViews
" "VTK::RenderingOpenGL2
" "ParaView::RemotingMisc
" "ParaView::VTKExtensionsFiltersRendering
" "VTK::CommonCore
" "VTK::RenderingContextOpenGL2
" "VTK::PythonUsed
" ) 132 if(NOT TARGET "${_target}
" ) 133 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 137 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 138 if(CMAKE_FIND_PACKAGE_NAME) 139 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 140 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 142 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 145 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 147 # Commands beyond this point should not need to know the version. 148 set(CMAKE_IMPORT_FILE_VERSION) boost::graph_traits< vtkGraph *>::vertex_descriptor target(boost::graph_traits< vtkGraph *>::edge_descriptor e, vtkGraph *)
