ParaViewInstallCMakePackage.cmake
1 if (NOT (DEFINED paraview_cmake_dir AND
2  DEFINED paraview_cmake_build_dir AND
3  DEFINED paraview_cmake_destination AND
4  DEFINED paraview_modules))
5  message(FATAL_ERROR
6  "ParaViewInstallCMakePackage is missing input variables.")
7 endif ()
9 _vtk_module_write_import_prefix("${paraview_cmake_build_dir}/paraview-prefix.cmake" "${paraview_cmake_destination}")
10
11 set(paraview_has_catalyst 0)
12 set(paraview_catalyst_directory "")
13 if (TARGET ParaView::catalyst-paraview)
14  set(paraview_has_catalyst 1)
15  get_property(paraview_catalyst_directory GLOBAL
16  PROPERTY paraview_catalyst_directory)
17 endif ()
18
19 string(REPLACE "ParaView::" "" _paraview_all_components "${paraview_modules};${paraview_client_modules}")
20
21 configure_file(
22  "${paraview_cmake_dir}/paraview-config.cmake.in"
23  "${paraview_cmake_build_dir}/paraview-config.cmake"
24  @ONLY)
25 include(CMakePackageConfigHelpers)
26 write_basic_package_version_file("${paraview_cmake_build_dir}/paraview-config-version.cmake"
27  VERSION "${PARAVIEW_VERSION_FULL}"
28  COMPATIBILITY AnyNewerVersion)
30 # For convenience, a package is written to the top of the build tree. At some
31 # point, this should probably be deprecated and warn when it is used.
32 file(GENERATE
33  OUTPUT "${CMAKE_BINARY_DIR}/paraview-config.cmake"
34  CONTENT "include(\"${paraview_cmake_build_dir}/paraview-config.cmake\")\n")
35 configure_file(
36  "${paraview_cmake_build_dir}/paraview-config-version.cmake"
37  "${CMAKE_BINARY_DIR}/paraview-config-version.cmake"
38  COPYONLY)
40 set(paraview_cmake_module_files
41  # Compatibility
42  paraview-use-file-compat.cmake
43  paraview-use-file-deprecated.cmake
44  paraview-use-file-error.cmake
45
46  # Client API
47  paraview_client_initializer.cxx.in
48  paraview_client_initializer.h.in
49  paraview_client_main.cxx.in
50  ParaViewClient.cmake
51  paraview_servermanager_convert_categoryindex.xsl
52  paraview_servermanager_convert_html.xsl
53  paraview_servermanager_convert_wiki.xsl.in
54  paraview_servermanager_convert_xml.xsl
55
56  # Plugin API
57  paraview_plugin.cxx.in
58  paraview_plugin.h.in
59  ParaViewPlugin.cmake
60  pqActionGroupImplementation.cxx.in
61  pqActionGroupImplementation.h.in
62  pqAutoStartImplementation.cxx.in
63  pqAutoStartImplementation.h.in
64  pqDockWindowImplementation.cxx.in
65  pqDockWindowImplementation.h.in
66  pqGraphLayoutStrategyImplementation.cxx.in
67  pqGraphLayoutStrategyImplementation.h.in
68  pqPluginLocationImplementation.cxx.in
69  pqPluginLocationImplementation.h.in
70  pqPropertyWidgetInterface.cxx.in
71  pqPropertyWidgetInterface.h.in
72  pqServerManagerModelImplementation.cxx.in
73  pqServerManagerModelImplementation.h.in
74  pqToolBarImplementation.cxx.in
75  pqToolBarImplementation.h.in
76  pqTreeLayoutStrategyImplementation.cxx.in
77  pqTreeLayoutStrategyImplementation.h.in
78
79  # ServerManager API
80  ParaViewServerManager.cmake
81
82  # Testing
83  ParaViewTesting.cmake
84
85  # Client Server
86  vtkModuleWrapClientServer.cmake
87
88  # Translation API
89  ParaViewTranslations.cmake
90  XML_translations_header_generator.py)
91
92 # From the `GmshIO` plugin.
93 if (TARGET GmshIO::vtkGmshIO)
94  list(APPEND paraview_cmake_module_files
95  FindGmsh.cmake)
96 endif ()
97
98 set(paraview_cmake_files_to_install)
99 foreach (paraview_cmake_module_file IN LISTS paraview_cmake_module_files)
100  configure_file(
101  "${paraview_cmake_dir}/${paraview_cmake_module_file}"
102  "${paraview_cmake_build_dir}/${paraview_cmake_module_file}"
103  COPYONLY)
104  list(APPEND paraview_cmake_files_to_install
105  "${paraview_cmake_module_file}")
106 endforeach ()
107
108 if (PARAVIEW_ENABLE_VISITBRIDGE)
109  set(paraview_visitbridge_cmake_module_files
110  FindBoxlib.cmake
111  FindGFortran.cmake
112  FindMili.cmake
113  FindRapidJSON.cmake
114  FindSILO.cmake)
115  foreach (paraview_cmake_module_file IN LISTS paraview_visitbridge_cmake_module_files)
116  configure_file(
117  "${ParaView_SOURCE_DIR}/Utilities/VisItBridge/databases/cmake/${paraview_cmake_module_file}"
118  "${paraview_cmake_build_dir}/${paraview_cmake_module_file}"
119  COPYONLY)
120  list(APPEND paraview_cmake_files_to_install
121  "${paraview_cmake_build_dir}/${paraview_cmake_module_file}")
122  endforeach ()
123 endif ()
124
125 include(ParaViewInstallCMakePackageHelpers)
126 if (NOT PARAVIEW_RELOCATABLE_INSTALL)
127  list(APPEND paraview_cmake_files_to_install
128  "${paraview_cmake_build_dir}/paraview-find-package-helpers.cmake")
129 endif ()
130
131 foreach (paraview_cmake_file IN LISTS paraview_cmake_files_to_install)
132  if (IS_ABSOLUTE "${paraview_cmake_file}")
133  file(RELATIVE_PATH paraview_cmake_subdir_root "${paraview_cmake_build_dir}" "${paraview_cmake_file}")
134  get_filename_component(paraview_cmake_subdir "${paraview_cmake_subdir_root}" DIRECTORY)
135  set(paraview_cmake_original_file "${paraview_cmake_file}")
136  else ()
137  get_filename_component(paraview_cmake_subdir "${paraview_cmake_file}" DIRECTORY)
138  set(paraview_cmake_original_file "${paraview_cmake_dir}/${paraview_cmake_file}")
139  endif ()
140  install(
141  FILES "${paraview_cmake_original_file}"
142  DESTINATION "${paraview_cmake_destination}/${paraview_cmake_subdir}"
143  COMPONENT "development")
144 endforeach ()
145
146 install(
147  FILES "${paraview_cmake_build_dir}/paraview-config.cmake"
148  "${paraview_cmake_build_dir}/paraview-config-version.cmake"
149  "${paraview_cmake_build_dir}/paraview-prefix.cmake"
150  DESTINATION "${paraview_cmake_destination}"
151  COMPONENT "development")
152
153 vtk_module_export_find_packages(
154  CMAKE_DESTINATION "${paraview_cmake_destination}"
155  FILE_NAME "ParaView-vtk-module-find-packages.cmake"
156  MODULES ${paraview_modules})
157
158 vtk_module_export_find_packages(
159  CMAKE_DESTINATION "${paraview_cmake_destination}"
160  FILE_NAME "ParaViewIncubator-vtk-module-find-packages.cmake"
161  MODULES ${paraview_incubator_modules})
162
163 if (PARAVIEW_USE_QT)
164  get_property(paraview_client_xml_files GLOBAL
165  PROPERTY paraview_client_xml_files)
166  get_property(paraview_client_xml_destination GLOBAL
167  PROPERTY paraview_client_xml_destination)
168
169  set(cmake_xml_file_name "ParaView-client-xml.cmake")
170  set(cmake_xml_build_file "${paraview_cmake_build_dir}/${cmake_xml_file_name}")
171  set(cmake_xml_install_file "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${cmake_xml_file_name}.install")
172
173  file(WRITE "${cmake_xml_build_file}" "")
174  file(WRITE "${cmake_xml_install_file}" "")
175  _vtk_module_write_import_prefix("${cmake_xml_install_file}" "${paraview_client_xml_destination}")
176  file(APPEND "${cmake_xml_build_file}"
177  "set(\"\${CMAKE_FIND_PACKAGE_NAME}_CLIENT_XML_FILES\")\n")
178  file(APPEND "${cmake_xml_install_file}"
179  "set(\"\${CMAKE_FIND_PACKAGE_NAME}_CLIENT_XML_FILES\")\n")
180
181  foreach (paraview_client_xml_file IN LISTS paraview_client_xml_files)
182  get_filename_component(basename "${paraview_client_xml_file}" NAME)
183  file(APPEND "${cmake_xml_build_file}"
184  "list(APPEND \"\${CMAKE_FIND_PACKAGE_NAME}_CLIENT_XML_FILES\"
185  \"${paraview_client_xml_file}\")\n")
186  file(APPEND "${cmake_xml_install_file}"
187  "list(APPEND \"\${CMAKE_FIND_PACKAGE_NAME}_CLIENT_XML_FILES\"
188  \"\${_vtk_module_import_prefix}/${paraview_client_xml_destination}/${basename}\")\n")
189  endforeach ()
190
191  install(
192  FILES "${cmake_xml_install_file}"
193  DESTINATION "${paraview_cmake_destination}"
194  RENAME "${cmake_xml_file_name}"
195  COMPONENT "development")
196 endif ()
197
198 # Expose ParaView_QCH_FILES variable used to locate where ParaView .qch help files are located.
199 # For now, it contains only the location of the `paraview.qch` file.
200 # To handle this location, which can vary between build and install dir, it is exposed via
201 # a specifc cmake file generate at build time.
202 if (PARAVIEW_USE_QT)
203  get_property(paraview_qch_build_file GLOBAL PROPERTY paraview_qch_build_file)
204  get_property(paraview_qch_install_file GLOBAL PROPERTY paraview_qch_install_file)
205
206  set(cmake_qch_name "ParaView-client-qch.cmake")
207  set(cmake_qch_build_file "${paraview_cmake_build_dir}/${cmake_qch_name}")
208  set(cmake_qch_install_file "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${cmake_qch_name}.install")
209
210  file(WRITE "${cmake_qch_build_file}" "")
211  file(WRITE "${cmake_qch_install_file}" "")
212
213  file(APPEND "${cmake_qch_build_file}"
214  "set(\"\${CMAKE_FIND_PACKAGE_NAME}_QCH_FILES\" \"${paraview_qch_build_file}\")\n")
215
216  _vtk_module_write_import_prefix("${cmake_qch_install_file}" "${CMAKE_INSTALL_DOCDIR}")
217  file(APPEND "${cmake_qch_install_file}"
218  "list(APPEND \"\${CMAKE_FIND_PACKAGE_NAME}_QCH_FILES\"
219  \"\${_vtk_module_import_prefix}/${paraview_qch_install_file}\")\n")
220
221  install(
222  FILES "${cmake_qch_install_file}"
223  DESTINATION "${paraview_cmake_destination}"
224  RENAME "${cmake_qch_name}"
225  COMPONENT "development")
226 endif()
version
#define PARAVIEW_VERSION_FULL
Definition: vtkPVVersion.h:10
