ParaViewTools-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.3")
7  message(FATAL_ERROR "CMake >= 2.8.3 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.3...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS ParaView::pvserver ParaView::pvdataserver ParaView::pvrenderserver ParaView::pvbatch ParaView::pvpython)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Compute the installation prefix relative to this file.
50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
54 if(_IMPORT_PREFIX STREQUAL "/")
55  set(_IMPORT_PREFIX "")
56 endif()
57
58 # Create imported target ParaView::pvserver
59 add_executable(ParaView::pvserver IMPORTED)
60
61 # Create imported target ParaView::pvdataserver
62 add_executable(ParaView::pvdataserver IMPORTED)
63
64 # Create imported target ParaView::pvrenderserver
65 add_executable(ParaView::pvrenderserver IMPORTED)
66
67 # Create imported target ParaView::pvbatch
68 add_executable(ParaView::pvbatch IMPORTED)
69
70 # Create imported target ParaView::pvpython
71 add_executable(ParaView::pvpython IMPORTED)
72
73 # Load information for each installed configuration.
74 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/ParaViewTools-targets-*.cmake")
75 foreach(_cmake_config_file IN LISTS _cmake_config_files)
76  include("${_cmake_config_file}")
77 endforeach()
78 unset(_cmake_config_file)
79 unset(_cmake_config_files)
80
81 # Cleanup temporary variables.
82 set(_IMPORT_PREFIX)
83
84 # Loop over all imported files and verify that they actually exist
85 foreach(_cmake_target IN LISTS _cmake_import_check_targets)
86  if(CMAKE_VERSION VERSION_LESS "3.28"
87  OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target}
88  OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}")
89  foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}")
90  if(NOT EXISTS "${_cmake_file}")
91  message(FATAL_ERROR "The imported target \"${_cmake_target}\" references the file
92  \"${_cmake_file}\"
93 but this file does not exist. Possible reasons include:
94 * The file was deleted, renamed, or moved to another location.
95 * An install or uninstall procedure did not complete successfully.
96 * The installation package was faulty and contained
97  \"${CMAKE_CURRENT_LIST_FILE}\"
98 but not all the files it references.
99 ")
100  endif()
101  endforeach()
102  endif()
103  unset(_cmake_file)
104  unset("_cmake_import_check_files_for_${_cmake_target}")
105 endforeach()
106 unset(_cmake_target)
107 unset(_cmake_import_check_targets)
108
109 # This file does not depend on other imported targets which have
110 # been exported from the same project but in a separate export set.
111
112 # Commands beyond this point should not need to know the version.
113 set(CMAKE_IMPORT_FILE_VERSION)
114 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
