/builds/gitlab-kitware-sciviz-ci/build/CTestTestfile.cmake
1 # CMake generated Testfile for
2 # Source directory: /builds/gitlab-kitware-sciviz-ci
3 # Build directory: /builds/gitlab-kitware-sciviz-ci/build
4 #
5 # This file includes the relevant testing commands required for
6 # testing this directory and lists subdirectories to be tested as well.
7 add_test(pv.TestDevelopmentInstall "/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-DBUILD_SHARED_LIBS:BOOL=ON" "-DPARAVIEW_BINARY_DIR:PATH=/builds/gitlab-kitware-sciviz-ci/build" "-DPARAVIEW_INSTALL_DIR:PATH=/usr/local" "-DPARAVIEW_SOURCE_DIR:PATH=/builds/gitlab-kitware-sciviz-ci" "-DPARAVIEW_TEST_DIR:PATH=/builds/gitlab-kitware-sciviz-ci/build/Testing/Temporary" "-DPARAVIEW_CMAKE_DESTINATION:STRING=lib64/cmake/paraview-6.0" "-DPARAVIEW_BINDIR:STRING=bin" "-DCMAKE_BUILD_TYPE:STRING=Release" "-DCMAKE_GENERATOR:STRING=Ninja" "-DCMAKE_GENERATOR_PLATFORM:STRING=" "-DCMAKE_GENERATOR_TOOLSET:STRING=" "-P" "/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTestInstall.cmake")
8 set_tests_properties(pv.TestDevelopmentInstall PROPERTIES ENVIRONMENT "DESTDIR=/builds/gitlab-kitware-sciviz-ci/build/test-install" LABELS "paraview" TIMEOUT "600" _BACKTRACE_TRIPLES "/builds/gitlab-kitware-sciviz-ci/CMakeLists.txt;1226;add_test;/builds/gitlab-kitware-sciviz-ci/CMakeLists.txt;0;")
9 subdirs("VTK/Wrapping/Tools")
10 subdirs("VTK/ThirdParty/fast_float")
11 subdirs("VTK/ThirdParty/fmt")
12 subdirs("VTK/Utilities/KWIML")
13 subdirs("VTK/ThirdParty/nlohmannjson")
14 subdirs("VTK/ThirdParty/scn")
15 subdirs("VTK/ThirdParty/token")
16 subdirs("VTK/Utilities/KWSys")
17 subdirs("VTK/ThirdParty/loguru")
18 subdirs("VTK/Common/Core")
19 subdirs("VTK/ThirdParty/kissfft")
20 subdirs("VTK/Common/Math")
21 subdirs("VTK/Common/Transforms")
22 subdirs("VTK/ThirdParty/exprtk")
23 subdirs("VTK/Common/Misc")
24 subdirs("VTK/Common/System")
25 subdirs("VTK/ThirdParty/pegtl")
26 subdirs("VTK/ThirdParty/pugixml")
27 subdirs("VTK/Common/DataModel")
28 subdirs("VTK/Common/ExecutionModel")
29 subdirs("VTK/Filters/Reduction")
30 subdirs("VTK/Filters/Core")
31 subdirs("VTK/Filters/Geometry")
32 subdirs("VTK/Common/ComputationalGeometry")
33 subdirs("VTK/ThirdParty/verdict")
34 subdirs("VTK/Filters/Verdict")
35 subdirs("VTK/Filters/General")
36 subdirs("VTK/ThirdParty/lz4")
37 subdirs("VTK/ThirdParty/lzma")
38 subdirs("VTK/ThirdParty/utf8")
39 subdirs("VTK/ThirdParty/zlib")
40 subdirs("VTK/IO/Core")
41 subdirs("VTK/Imaging/Core")
42 subdirs("VTK/Utilities/DICOMParser")
43 subdirs("VTK/ThirdParty/jpeg")
44 subdirs("VTK/Utilities/MetaIO")
45 subdirs("VTK/ThirdParty/png")
46 subdirs("VTK/ThirdParty/tiff")
47 subdirs("VTK/IO/Image")
48 subdirs("VTK/ThirdParty/eigen")
49 subdirs("VTK/Filters/CellGrid")
50 subdirs("VTK/IO/CellGrid")
51 subdirs("VTK/IO/Legacy")
52 subdirs("VTK/Parallel/Core")
53 subdirs("VTK/Utilities/Python")
54 subdirs("VTK/Common/Color")
55 subdirs("VTK/Filters/Sources")
56 subdirs("VTK/Rendering/Core")
57 subdirs("VTK/ThirdParty/expat")
58 subdirs("VTK/IO/XMLParser")
59 subdirs("VTK/IO/XML")
60 subdirs("VTK/ThirdParty/freetype")
61 subdirs("VTK/Rendering/FreeType")
62 subdirs("VTK/Rendering/Context2D")
63 subdirs("VTK/Rendering/SceneGraph")
64 subdirs("VTK/ThirdParty/jsoncpp")
65 subdirs("VTK/Rendering/VtkJS")
66 subdirs("VTK/Domains/Chemistry")
67 subdirs("VTK/Imaging/Sources")
68 subdirs("VTK/Filters/Hybrid")
69 subdirs("VTK/IO/Geometry")
70 subdirs("VTK/IO/Export")
71 subdirs("VTK/Filters/Modeling")
72 subdirs("VTK/Filters/Texture")
73 subdirs("VTK/Imaging/Color")
74 subdirs("VTK/Imaging/General")
75 subdirs("VTK/Imaging/Hybrid")
76 subdirs("VTK/Filters/HyperTree")
77 subdirs("VTK/Filters/Statistics")
78 subdirs("VTK/Utilities/MPI")
79 subdirs("VTK/ThirdParty/diy2")
80 subdirs("VTK/Parallel/MPI")
81 subdirs("VTK/Parallel/DIY")
82 subdirs("VTK/Filters/Extraction")
83 subdirs("VTK/Interaction/Style")
84 subdirs("VTK/Rendering/Annotation")
85 subdirs("VTK/Rendering/Volume")
86 subdirs("VTK/Interaction/Widgets")
87 subdirs("VTK/Web/WebGLExporter")
88 subdirs("VTK/Web/Core")
89 subdirs("VTK/Web/Python")
90 subdirs("VTK/Wrapping/PythonCore")
91 subdirs("VTK/Utilities/PythonInterpreter")
92 subdirs("VTK/Utilities/X11")
93 subdirs("VTK/ThirdParty/glad")
94 subdirs("VTK/Rendering/UI")
95 subdirs("VTK/Views/Core")
96 subdirs("VTK/Views/Context2D")
97 subdirs("VTK/ThirdParty/cli11")
98 subdirs("VTK/Testing/Core")
99 subdirs("VTK/Testing/Rendering")
100 subdirs("VTK/Testing/DataModel")
101 subdirs("VTK/Serialization/Manager")
102 subdirs("VTK/Imaging/Math")
103 subdirs("VTK/Rendering/HyperTreeGrid")
104 subdirs("VTK/Rendering/OpenGL2")
105 subdirs("VTK/Rendering/VolumeOpenGL2")
106 subdirs("VTK/Filters/AMR")
107 subdirs("VTK/Rendering/VolumeAMR")
108 subdirs("VTK/Rendering/LICOpenGL2")
109 subdirs("VTK/Rendering/ParallelLIC")
110 subdirs("VTK/Filters/Parallel")
111 subdirs("VTK/Rendering/VRModels")
112 subdirs("VTK/Rendering/Parallel")
113 subdirs("VTK/Rendering/Matplotlib")
114 subdirs("VTK/Utilities/octree")
115 subdirs("VTK/Rendering/Label")
116 subdirs("VTK/Infovis/Core")
117 subdirs("VTK/Charts/Core")
118 subdirs("VTK/Rendering/GridAxes")
119 subdirs("VTK/Rendering/ContextOpenGL2")
120 subdirs("VTK/Rendering/CellGrid")
121 subdirs("VTK/ThirdParty/mpi4py")
122 subdirs("VTK/Parallel/MPI4Py")
123 subdirs("VTK/Imaging/Fourier")
124 subdirs("VTK/ThirdParty/libxml2")
125 subdirs("VTK/ThirdParty/hdf5")
126 subdirs("VTK/ThirdParty/xdmf2")
127 subdirs("VTK/IO/Xdmf2")
128 subdirs("VTK/IO/VeraOut")
129 subdirs("VTK/ThirdParty/vpic")
130 subdirs("VTK/IO/VPIC")
131 subdirs("VTK/IO/TecplotTable")
132 subdirs("VTK/IO/TRUCHAS")
133 subdirs("VTK/IO/SegY")
134 subdirs("VTK/IO/ParallelXML")
135 subdirs("VTK/ThirdParty/netcdf")
136 subdirs("VTK/IO/NetCDF")
137 subdirs("VTK/IO/ParallelNetCDF")
138 subdirs("VTK/IO/LSDyna")
139 subdirs("VTK/IO/ParallelLSDyna")
140 subdirs("VTK/ThirdParty/exodusII")
141 subdirs("VTK/IO/Exodus")
142 subdirs("VTK/IO/ParallelExodus")
143 subdirs("VTK/IO/PLY")
144 subdirs("VTK/IO/PIO")
145 subdirs("VTK/IO/Movie")
146 subdirs("VTK/ThirdParty/ogg")
147 subdirs("VTK/ThirdParty/theora")
148 subdirs("VTK/IO/OggTheora")
149 subdirs("VTK/IO/OMF")
150 subdirs("VTK/IO/Parallel")
151 subdirs("VTK/IO/MPIImage")
152 subdirs("VTK/IO/LANLX3D")
153 subdirs("VTK/IO/Import")
154 subdirs("VTK/ThirdParty/cgns")
155 subdirs("VTK/Utilities/Catalyst")
156 subdirs("VTK/ThirdParty/ioss")
157 subdirs("VTK/IO/IOSS")
158 subdirs("VTK/IO/HDFTools")
159 subdirs("VTK/Filters/Temporal")
160 subdirs("VTK/IO/HDF")
161 subdirs("VTK/ThirdParty/h5part")
162 subdirs("VTK/IO/H5part")
163 subdirs("VTK/IO/H5Rage")
164 subdirs("VTK/IO/FLUENTCFF")
165 subdirs("VTK/IO/Infovis")
166 subdirs("VTK/IO/FDS")
167 subdirs("VTK/ThirdParty/gl2ps")
168 subdirs("VTK/Rendering/GL2PSOpenGL2")
169 subdirs("VTK/IO/ExportGL2PS")
170 subdirs("VTK/IO/EnSight")
171 subdirs("VTK/IO/ERF")
172 subdirs("VTK/IO/CityGML")
173 subdirs("VTK/IO/Chemistry")
174 subdirs("VTK/ThirdParty/viskores")
175 subdirs("VTK/Accelerators/Vtkm/Core")
176 subdirs("VTK/Accelerators/Vtkm/DataModel")
177 subdirs("VTK/IO/CatalystConduit")
178 subdirs("VTK/IO/CONVERGECFD")
179 subdirs("VTK/IO/CGNS")
180 subdirs("VTK/IO/Avmesh")
181 subdirs("VTK/IO/Asynchronous")
182 subdirs("VTK/IO/AMR")
183 subdirs("VTK/ThirdParty/sqlite")
184 subdirs("VTK/ThirdParty/libproj")
185 subdirs("VTK/Geovis/Core")
186 subdirs("VTK/Filters/Tensor")
187 subdirs("VTK/Filters/Python")
188 subdirs("VTK/Filters/Programmable")
189 subdirs("VTK/Filters/Points")
190 subdirs("VTK/Filters/ParallelVerdict")
191 subdirs("VTK/Filters/ParallelStatistics")
192 subdirs("VTK/Filters/ParallelGeometry")
193 subdirs("VTK/Filters/FlowPaths")
194 subdirs("VTK/Filters/ParallelFlowPaths")
195 subdirs("VTK/Filters/ParallelDIY2")
196 subdirs("VTK/Filters/Imaging")
197 subdirs("VTK/Filters/GeometryPreview")
198 subdirs("VTK/Filters/Generic")
199 subdirs("VTK/Filters/ParallelMPI")
200 subdirs("VTK/Domains/ChemistryOpenGL2")
201 subdirs("VTK/Accelerators/Vtkm/Filters")
202 subdirs("Utilities/WrapClientServer")
203 subdirs("Utilities/TestDriver")
204 subdirs("Utilities/PythonInitializer")
205 subdirs("Utilities/PythonInterpreterPath")
206 subdirs("Utilities/ProcessXML")
207 subdirs("ThirdParty/cinemasci")
208 subdirs("ThirdParty/cinema")
209 subdirs("ThirdParty/IceT")
210 subdirs("ThirdParty/protobuf")
211 subdirs("Remoting/ClientServerStream")
212 subdirs("Utilities/Versioning")
213 subdirs("VTKExtensions/Core")
214 subdirs("Remoting/Core")
215 subdirs("Remoting/Settings")
216 subdirs("Remoting/ServerManager")
217 subdirs("VTKExtensions/ExtractionPython")
218 subdirs("VTKExtensions/Extraction")
219 subdirs("VTKExtensions/Misc")
220 subdirs("VTKExtensions/FiltersRendering")
221 subdirs("VTKExtensions/InteractionStyle")
222 subdirs("Remoting/Views")
223 subdirs("Remoting/ViewsPython")
224 subdirs("Remoting/ServerManagerPython")
225 subdirs("VTKExtensions/AMR")
226 subdirs("VTKExtensions/FiltersGeneral")
227 subdirs("VTKExtensions/IOGeneral")
228 subdirs("Remoting/Misc")
229 subdirs("Remoting/Live")
230 subdirs("VTKExtensions/IOCore")
231 subdirs("VTKExtensions/IOImport")
232 subdirs("Remoting/Import")
233 subdirs("Remoting/Export")
234 subdirs("Remoting/ApplicationComponents")
235 subdirs("VTKExtensions/IOCGNS")
236 subdirs("Remoting/Application")
237 subdirs("Remoting/Animation")
238 subdirs("Web/Python")
239 subdirs("VTKExtensions/Points")
240 subdirs("VTKExtensions/IOSPCTH")
241 subdirs("VTKExtensions/IOParallelCGNS")
242 subdirs("VTKExtensions/IOImage")
243 subdirs("VTKExtensions/IOExodus")
244 subdirs("VTKExtensions/IOEnSight")
245 subdirs("VTKExtensions/IOAMR")
246 subdirs("VTKExtensions/FiltersStatistics")
247 subdirs("VTKExtensions/FiltersPython")
248 subdirs("VTKExtensions/FiltersParallelDIY2")
249 subdirs("VTKExtensions/FiltersParallel")
250 subdirs("VTKExtensions/FiltersMaterialInterface")
251 subdirs("VTKExtensions/FiltersGeneralMPI")
252 subdirs("VTKExtensions/FiltersFlowPaths")
253 subdirs("Remoting/Live/Testing")
254 subdirs("Remoting/Application/Testing")
255 subdirs("Remoting/Animation/Testing")
256 subdirs("Remoting/Views/Testing")
257 subdirs("Remoting/ServerManager/Testing")
258 subdirs("Web/Python/Testing")
259 subdirs("VTKExtensions/IOParallelCGNS/Testing")
260 subdirs("VTKExtensions/IOEnSight/Testing")
261 subdirs("VTKExtensions/IOCGNS/Testing")
262 subdirs("VTKExtensions/IOCore/Testing")
263 subdirs("VTKExtensions/FiltersGeneral/Testing")
264 subdirs("VTKExtensions/FiltersRendering/Testing")
265 subdirs("VTKExtensions/Misc/Testing")
266 subdirs("Remoting/Core/Testing")
267 subdirs("Remoting/ClientServerStream/Testing")
268 subdirs("VTKExtensions/Core/Testing")
269 subdirs("Adaptors/Python")
270 subdirs("Clients/Catalyst")
271 subdirs("Adaptors/Phasta")
272 subdirs("Adaptors/Particle")
273 subdirs("Clients/PythonCatalyst")
274 subdirs("Adaptors/Pagosa")
275 subdirs("Adaptors/NPIC")
276 subdirs("Adaptors/CatalystTestDriver")
277 subdirs("Adaptors/Cam")
278 subdirs("Adaptors/Cam/Python")
279 subdirs("Adaptors/CTH")
280 subdirs("Clients/Web")
281 subdirs("Clients/InSitu")
282 subdirs("Clients/Web/Testing")
283 subdirs("Clients/PythonCatalyst/Testing")
284 subdirs("Clients/Catalyst/Testing")
285 subdirs("Incubator/Core")
286 subdirs("Incubator/Core/Testing")
287 subdirs("Plugins/AcceleratedAlgorithms")
288 subdirs("Plugins/AnalyzeNIfTIReaderWriter")
289 subdirs("Plugins/ArrowGlyph")
290 subdirs("Plugins/BagPlotViewsAndFilters")
291 subdirs("Plugins/BivariateRepresentations")
292 subdirs("Plugins/CFSReader")
293 subdirs("Plugins/ContourLabelPlugin")
294 subdirs("Plugins/DSP")
295 subdirs("Plugins/Datamine")
296 subdirs("Plugins/DigitalRockPhysics")
297 subdirs("Plugins/EULATestPlugin")
298 subdirs("Plugins/EmbossingRepresentations")
299 subdirs("Plugins/EnSightGoldCombinedReader")
300 subdirs("Plugins/ExplicitStructuredGrid")
301 subdirs("Plugins/GMVReader")
302 subdirs("Plugins/GenericIOReader")
303 subdirs("Plugins/GeodesicMeasurement")
304 subdirs("Plugins/HyperTreeGridADR")
305 subdirs("Plugins/LagrangianParticleTracker")
306 subdirs("Plugins/LegacyExodusReader")
307 subdirs("Plugins/LegacyExodusWriter")
308 subdirs("Plugins/LegacyGhostCellsGenerator")
309 subdirs("Plugins/Moments")
310 subdirs("Plugins/MooseXfemClip")
311 subdirs("Plugins/NetCDFTimeAnnotationPlugin")
312 subdirs("Plugins/NonOrthogonalSource")
313 subdirs("Plugins/PacMan")
314 subdirs("Plugins/PanoramicProjectionView")
315 subdirs("Plugins/ParFlow")
316 subdirs("Plugins/ParametricSurfaces")
317 subdirs("Plugins/Prism")
318 subdirs("Plugins/SLACTools")
319 subdirs("Plugins/StereoCursorView")
320 subdirs("Plugins/StreamLinesRepresentation")
321 subdirs("Plugins/StreamingParticles")
322 subdirs("Plugins/ThickenLayeredCells")
323 subdirs("Plugins/VTKmFilters")
324 subdirs("Plugins/XArrayCFReader")
325 subdirs("VTK/Wrapping/Python")
326 subdirs("Clients")
327 subdirs("Wrapping/Python")
328 subdirs("Utilities/Doxygen")
329 subdirs("Utilities/Sphinx")
330 subdirs("Documentation")
331 subdirs("Examples")
