1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/FortranCInterface 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
40 if(CMAKE_INSTALL_COMPONENT)
41 set(CMAKE_INSTALL_MANIFEST
"install_manifest_${CMAKE_INSTALL_COMPONENT}.txt")
43 set(CMAKE_INSTALL_MANIFEST
"install_manifest.txt")
46 string(REPLACE
";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
47 "${CMAKE_INSTALL_MANIFEST_FILES}")
48 file(WRITE
"/builds/gitlab-kitware-sciviz-ci/build/CMakeFiles/FortranCInterface/${CMAKE_INSTALL_MANIFEST}" 49 "${CMAKE_INSTALL_MANIFEST_CONTENT}")
