ParaViewPythonIncubator-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "3.0.0")
7  message(FATAL_ERROR "CMake >= 3.0.0 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 3.0.0...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS ParaView::PyvtkPVIncubatorCorePython ParaView::pvincubatorpythonmodules)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Compute the installation prefix relative to this file.
50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
54 if(_IMPORT_PREFIX STREQUAL "/")
55  set(_IMPORT_PREFIX "")
56 endif()
57
58 # Create imported target ParaView::PyvtkPVIncubatorCorePython
59 add_library(ParaView::PyvtkPVIncubatorCorePython MODULE IMPORTED)
60
61 # Create imported target ParaView::pvincubatorpythonmodules
62 add_library(ParaView::pvincubatorpythonmodules INTERFACE IMPORTED)
63
64 set_target_properties(ParaView::pvincubatorpythonmodules PROPERTIES
65  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.1/pvincubatorpythonmodules"
66  INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules"
67 )
68
69 # Load information for each installed configuration.
70 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/ParaViewPythonIncubator-targets-*.cmake")
71 foreach(_cmake_config_file IN LISTS _cmake_config_files)
72  include("${_cmake_config_file}")
73 endforeach()
74 unset(_cmake_config_file)
75 unset(_cmake_config_files)
76
77 # Cleanup temporary variables.
78 set(_IMPORT_PREFIX)
79
80 # Loop over all imported files and verify that they actually exist
81 foreach(_cmake_target IN LISTS _cmake_import_check_targets)
82  if(CMAKE_VERSION VERSION_LESS "3.28"
83  OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target}
84  OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}")
85  foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}")
86  if(NOT EXISTS "${_cmake_file}")
87  message(FATAL_ERROR "The imported target \"${_cmake_target}\" references the file
88  \"${_cmake_file}\"
89 but this file does not exist. Possible reasons include:
90 * The file was deleted, renamed, or moved to another location.
91 * An install or uninstall procedure did not complete successfully.
92 * The installation package was faulty and contained
93  \"${CMAKE_CURRENT_LIST_FILE}\"
94 but not all the files it references.
95 ")
96  endif()
97  endforeach()
98  endif()
99  unset(_cmake_file)
100  unset("_cmake_import_check_files_for_${_cmake_target}")
101 endforeach()
102 unset(_cmake_target)
103 unset(_cmake_import_check_targets)
104
105 # Make sure the targets which have been exported in some other
106 # export set exist.
107 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
108 foreach(_target "VTK::vtkpythonmodules" )
109  if(NOT TARGET "${_target}" )
110  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
111  endif()
112 endforeach()
113
114 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
115  if(CMAKE_FIND_PACKAGE_NAME)
116  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
117  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
118  else()
119  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
120  endif()
121 endif()
122 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
123
124 # Commands beyond this point should not need to know the version.
125 set(CMAKE_IMPORT_FILE_VERSION)
126 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
