ParaViewPython-targets.cmake
1 # Generated by CMake
4  message(FATAL_ERROR "CMake >= 3.0.0 required")
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "3.0.0")
7  message(FATAL_ERROR "CMake >= 3.0.0 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 3.0.0...3.30)
14
17
22 foreach(_cmake_expected_target IN ITEMS ParaView::PyvtkRemotingClientServerStreamPython ParaView::PyvtkPVVersioningPython ParaView::PyvtkPVVTKExtensionsCorePython ParaView::PyvtkRemotingCorePython ParaView::PyvtkRemotingServerManagerPython ParaView::PyvtkRemotingViewsPython ParaView::PyvtkRemotingViewsPythonPython ParaView::PyvtkRemotingServerManagerPythonPython ParaView::PyvtkRemotingMiscPython ParaView::PyvtkPVVTKExtensionsExtractionPython ParaView::PyvtkRemotingLivePython ParaView::PyvtkRemotingImportPython ParaView::PyvtkRemotingApplicationComponentsPython ParaView::PyvtkRemotingApplicationPython ParaView::PyvtkRemotingExportPython ParaView::PyvtkPVVTKExtensionsIOCorePython ParaView::PyvtkRemotingAnimationPython ParaView::PyvtkPVVTKExtensionsInteractionStylePython ParaView::PyvtkRemotingSettingsPython ParaView::PyvtkPVVTKExtensionsPointsPython ParaView::PyvtkPVVTKExtensionsIOSPCTHPython ParaView::PyvtkPVVTKExtensionsIOCGNSWriterPython ParaView::PyvtkPVVTKExtensionsIOParallelCGNSWriterPython ParaView::PyvtkPVVTKExtensionsIOImportPython ParaView::PyvtkPVVTKExtensionsIOImagePython ParaView::PyvtkPVVTKExtensionsIOGeneralPython ParaView::PyvtkPVVTKExtensionsIOExodusPython ParaView::PyvtkPVVTKExtensionsIOEnSightPython ParaView::PyvtkPVVTKExtensionsIOAMRPython ParaView::PyvtkPVVTKExtensionsFiltersStatisticsPython ParaView::PyvtkPVVTKExtensionsFiltersPythonPython ParaView::PyvtkPVVTKExtensionsFiltersGeneralPython ParaView::PyvtkPVVTKExtensionsFiltersParallelDIY2Python ParaView::PyvtkPVVTKExtensionsFiltersParallelPython ParaView::PyvtkPVVTKExtensionsFiltersMaterialInterfacePython ParaView::PyvtkPVVTKExtensionsFiltersGeneralMPIPython ParaView::PyvtkPVVTKExtensionsFiltersRenderingPython ParaView::PyvtkPVVTKExtensionsMiscPython ParaView::PyvtkPVVTKExtensionsFiltersFlowPathsPython ParaView::PyvtkPVVTKExtensionsExtractionPythonPython ParaView::PyvtkPVVTKExtensionsAMRPython ParaView::PyvtkPVCatalystPython ParaView::PyvtkPVCatalystTestDriverPython ParaView::PyvtkPVPythonCatalystPython ParaView::PyvtkPVClientWebPython ParaView::PyvtkPVInSituPython ParaView::pvpythonmodules)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Compute the installation prefix relative to this file.
50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
54 if(_IMPORT_PREFIX STREQUAL "/")
55  set(_IMPORT_PREFIX "")
56 endif()
57
58 # Create imported target ParaView::PyvtkRemotingClientServerStreamPython
59 add_library(ParaView::PyvtkRemotingClientServerStreamPython MODULE IMPORTED)
60
61 # Create imported target ParaView::PyvtkPVVersioningPython
62 add_library(ParaView::PyvtkPVVersioningPython MODULE IMPORTED)
63
64 # Create imported target ParaView::PyvtkPVVTKExtensionsCorePython
65 add_library(ParaView::PyvtkPVVTKExtensionsCorePython MODULE IMPORTED)
66
67 # Create imported target ParaView::PyvtkRemotingCorePython
68 add_library(ParaView::PyvtkRemotingCorePython MODULE IMPORTED)
69
70 # Create imported target ParaView::PyvtkRemotingServerManagerPython
71 add_library(ParaView::PyvtkRemotingServerManagerPython MODULE IMPORTED)
72
73 # Create imported target ParaView::PyvtkRemotingViewsPython
74 add_library(ParaView::PyvtkRemotingViewsPython MODULE IMPORTED)
75
76 # Create imported target ParaView::PyvtkRemotingViewsPythonPython
77 add_library(ParaView::PyvtkRemotingViewsPythonPython MODULE IMPORTED)
78
79 # Create imported target ParaView::PyvtkRemotingServerManagerPythonPython
80 add_library(ParaView::PyvtkRemotingServerManagerPythonPython MODULE IMPORTED)
81
82 # Create imported target ParaView::PyvtkRemotingMiscPython
83 add_library(ParaView::PyvtkRemotingMiscPython MODULE IMPORTED)
84
85 # Create imported target ParaView::PyvtkPVVTKExtensionsExtractionPython
86 add_library(ParaView::PyvtkPVVTKExtensionsExtractionPython MODULE IMPORTED)
87
88 # Create imported target ParaView::PyvtkRemotingLivePython
89 add_library(ParaView::PyvtkRemotingLivePython MODULE IMPORTED)
90
91 # Create imported target ParaView::PyvtkRemotingImportPython
92 add_library(ParaView::PyvtkRemotingImportPython MODULE IMPORTED)
93
94 # Create imported target ParaView::PyvtkRemotingApplicationComponentsPython
95 add_library(ParaView::PyvtkRemotingApplicationComponentsPython MODULE IMPORTED)
96
97 # Create imported target ParaView::PyvtkRemotingApplicationPython
98 add_library(ParaView::PyvtkRemotingApplicationPython MODULE IMPORTED)
99
100 # Create imported target ParaView::PyvtkRemotingExportPython
101 add_library(ParaView::PyvtkRemotingExportPython MODULE IMPORTED)
102
103 # Create imported target ParaView::PyvtkPVVTKExtensionsIOCorePython
104 add_library(ParaView::PyvtkPVVTKExtensionsIOCorePython MODULE IMPORTED)
105
106 # Create imported target ParaView::PyvtkRemotingAnimationPython
107 add_library(ParaView::PyvtkRemotingAnimationPython MODULE IMPORTED)
108
109 # Create imported target ParaView::PyvtkPVVTKExtensionsInteractionStylePython
110 add_library(ParaView::PyvtkPVVTKExtensionsInteractionStylePython MODULE IMPORTED)
111
112 # Create imported target ParaView::PyvtkRemotingSettingsPython
113 add_library(ParaView::PyvtkRemotingSettingsPython MODULE IMPORTED)
114
115 # Create imported target ParaView::PyvtkPVVTKExtensionsPointsPython
116 add_library(ParaView::PyvtkPVVTKExtensionsPointsPython MODULE IMPORTED)
117
118 # Create imported target ParaView::PyvtkPVVTKExtensionsIOSPCTHPython
119 add_library(ParaView::PyvtkPVVTKExtensionsIOSPCTHPython MODULE IMPORTED)
120
121 # Create imported target ParaView::PyvtkPVVTKExtensionsIOCGNSWriterPython
122 add_library(ParaView::PyvtkPVVTKExtensionsIOCGNSWriterPython MODULE IMPORTED)
123
124 # Create imported target ParaView::PyvtkPVVTKExtensionsIOParallelCGNSWriterPython
125 add_library(ParaView::PyvtkPVVTKExtensionsIOParallelCGNSWriterPython MODULE IMPORTED)
126
127 # Create imported target ParaView::PyvtkPVVTKExtensionsIOImportPython
128 add_library(ParaView::PyvtkPVVTKExtensionsIOImportPython MODULE IMPORTED)
129
130 # Create imported target ParaView::PyvtkPVVTKExtensionsIOImagePython
131 add_library(ParaView::PyvtkPVVTKExtensionsIOImagePython MODULE IMPORTED)
132
133 # Create imported target ParaView::PyvtkPVVTKExtensionsIOGeneralPython
134 add_library(ParaView::PyvtkPVVTKExtensionsIOGeneralPython MODULE IMPORTED)
135
136 # Create imported target ParaView::PyvtkPVVTKExtensionsIOExodusPython
137 add_library(ParaView::PyvtkPVVTKExtensionsIOExodusPython MODULE IMPORTED)
138
139 # Create imported target ParaView::PyvtkPVVTKExtensionsIOEnSightPython
140 add_library(ParaView::PyvtkPVVTKExtensionsIOEnSightPython MODULE IMPORTED)
141
142 # Create imported target ParaView::PyvtkPVVTKExtensionsIOAMRPython
143 add_library(ParaView::PyvtkPVVTKExtensionsIOAMRPython MODULE IMPORTED)
144
145 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersStatisticsPython
146 add_library(ParaView::PyvtkPVVTKExtensionsFiltersStatisticsPython MODULE IMPORTED)
147
148 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersPythonPython
149 add_library(ParaView::PyvtkPVVTKExtensionsFiltersPythonPython MODULE IMPORTED)
150
151 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersGeneralPython
152 add_library(ParaView::PyvtkPVVTKExtensionsFiltersGeneralPython MODULE IMPORTED)
153
154 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersParallelDIY2Python
155 add_library(ParaView::PyvtkPVVTKExtensionsFiltersParallelDIY2Python MODULE IMPORTED)
156
157 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersParallelPython
158 add_library(ParaView::PyvtkPVVTKExtensionsFiltersParallelPython MODULE IMPORTED)
159
160 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersMaterialInterfacePython
161 add_library(ParaView::PyvtkPVVTKExtensionsFiltersMaterialInterfacePython MODULE IMPORTED)
162
163 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersGeneralMPIPython
164 add_library(ParaView::PyvtkPVVTKExtensionsFiltersGeneralMPIPython MODULE IMPORTED)
165
166 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersRenderingPython
167 add_library(ParaView::PyvtkPVVTKExtensionsFiltersRenderingPython MODULE IMPORTED)
168
169 # Create imported target ParaView::PyvtkPVVTKExtensionsMiscPython
170 add_library(ParaView::PyvtkPVVTKExtensionsMiscPython MODULE IMPORTED)
171
172 # Create imported target ParaView::PyvtkPVVTKExtensionsFiltersFlowPathsPython
173 add_library(ParaView::PyvtkPVVTKExtensionsFiltersFlowPathsPython MODULE IMPORTED)
174
175 # Create imported target ParaView::PyvtkPVVTKExtensionsExtractionPythonPython
176 add_library(ParaView::PyvtkPVVTKExtensionsExtractionPythonPython MODULE IMPORTED)
177
178 # Create imported target ParaView::PyvtkPVVTKExtensionsAMRPython
179 add_library(ParaView::PyvtkPVVTKExtensionsAMRPython MODULE IMPORTED)
180
181 # Create imported target ParaView::PyvtkPVCatalystPython
182 add_library(ParaView::PyvtkPVCatalystPython MODULE IMPORTED)
183
184 # Create imported target ParaView::PyvtkPVCatalystTestDriverPython
185 add_library(ParaView::PyvtkPVCatalystTestDriverPython MODULE IMPORTED)
186
187 # Create imported target ParaView::PyvtkPVPythonCatalystPython
188 add_library(ParaView::PyvtkPVPythonCatalystPython MODULE IMPORTED)
189
190 # Create imported target ParaView::PyvtkPVClientWebPython
191 add_library(ParaView::PyvtkPVClientWebPython MODULE IMPORTED)
192
193 # Create imported target ParaView::PyvtkPVInSituPython
194 add_library(ParaView::PyvtkPVInSituPython MODULE IMPORTED)
195
196 # Create imported target ParaView::pvpythonmodules
197 add_library(ParaView::pvpythonmodules INTERFACE IMPORTED)
198
199 set_target_properties(ParaView::pvpythonmodules PROPERTIES
200  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.2/pvpythonmodules"
201  INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules"
202 )
203
204 # Load information for each installed configuration.
205 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/ParaViewPython-targets-*.cmake")
206 foreach(_cmake_config_file IN LISTS _cmake_config_files)
207  include("${_cmake_config_file}")
208 endforeach()
209 unset(_cmake_config_file)
210 unset(_cmake_config_files)
211
212 # Cleanup temporary variables.
213 set(_IMPORT_PREFIX)
214
215 # Loop over all imported files and verify that they actually exist
216 foreach(_cmake_target IN LISTS _cmake_import_check_targets)
217  if(CMAKE_VERSION VERSION_LESS "3.28"
218  OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target}
219  OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}")
220  foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}")
221  if(NOT EXISTS "${_cmake_file}")
222  message(FATAL_ERROR "The imported target \"${_cmake_target}\" references the file
223  \"${_cmake_file}\"
224 but this file does not exist. Possible reasons include:
225 * The file was deleted, renamed, or moved to another location.
226 * An install or uninstall procedure did not complete successfully.
227 * The installation package was faulty and contained
228  \"${CMAKE_CURRENT_LIST_FILE}\"
229 but not all the files it references.
230 ")
231  endif()
232  endforeach()
233  endif()
234  unset(_cmake_file)
235  unset("_cmake_import_check_files_for_${_cmake_target}")
236 endforeach()
237 unset(_cmake_target)
238 unset(_cmake_import_check_targets)
239
240 # Make sure the targets which have been exported in some other
241 # export set exist.
242 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
243 foreach(_target "VTK::vtkpythonmodules" )
244  if(NOT TARGET "${_target}" )
245  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
246  endif()
247 endforeach()
248
249 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
250  if(CMAKE_FIND_PACKAGE_NAME)
251  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
252  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
253  else()
254  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
255  endif()
256 endif()
257 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
258
259 # Commands beyond this point should not need to know the version.
260 set(CMAKE_IMPORT_FILE_VERSION)
261 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:20
