ParaViewPython-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "3.0.0")
7  message(FATAL_ERROR "CMake >= 3.0.0 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 3.0.0...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS ParaView::vtkRemotingClientServerStreamPython ParaView::vtkPVVersioningPython ParaView::vtkPVVTKExtensionsCorePython ParaView::vtkRemotingCorePython ParaView::vtkRemotingServerManagerPython ParaView::vtkRemotingViewsPython ParaView::vtkRemotingViewsPythonPython ParaView::vtkRemotingServerManagerPythonPython ParaView::vtkRemotingMiscPython ParaView::vtkPVVTKExtensionsExtractionPython ParaView::vtkRemotingLivePython ParaView::vtkRemotingImportPython ParaView::vtkRemotingExportPython ParaView::vtkRemotingApplicationComponentsPython ParaView::vtkRemotingApplicationPython ParaView::vtkPVVTKExtensionsIOCorePython ParaView::vtkRemotingAnimationPython ParaView::vtkPVVTKExtensionsInteractionStylePython ParaView::vtkRemotingSettingsPython ParaView::vtkPVVTKExtensionsPointsPython ParaView::vtkPVVTKExtensionsIOSPCTHPython ParaView::vtkPVVTKExtensionsIOCGNSWriterPython ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython ParaView::vtkPVVTKExtensionsIOImportPython ParaView::vtkPVVTKExtensionsIOImagePython ParaView::vtkPVVTKExtensionsIOGeneralPython ParaView::vtkPVVTKExtensionsIOExodusPython ParaView::vtkPVVTKExtensionsIOEnSightPython ParaView::vtkPVVTKExtensionsIOAMRPython ParaView::vtkPVVTKExtensionsFiltersStatisticsPython ParaView::vtkPVVTKExtensionsFiltersPythonPython ParaView::vtkPVVTKExtensionsFiltersGeneralPython ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python ParaView::vtkPVVTKExtensionsFiltersParallelPython ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython ParaView::vtkPVVTKExtensionsFiltersRenderingPython ParaView::vtkPVVTKExtensionsMiscPython ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython ParaView::vtkPVVTKExtensionsExtractionPythonPython ParaView::vtkPVVTKExtensionsAMRPython ParaView::vtkPVCatalystPython ParaView::vtkPVCatalystTestDriverPython ParaView::vtkPVPythonCatalystPython ParaView::vtkPVClientWebPython ParaView::vtkPVInSituPython ParaView::pvpythonmodules)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Compute the installation prefix relative to this file.
50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
54 if(_IMPORT_PREFIX STREQUAL "/")
55  set(_IMPORT_PREFIX "")
56 endif()
57
58 # Create imported target ParaView::vtkRemotingClientServerStreamPython
59 add_library(ParaView::vtkRemotingClientServerStreamPython MODULE IMPORTED)
60
61 # Create imported target ParaView::vtkPVVersioningPython
62 add_library(ParaView::vtkPVVersioningPython MODULE IMPORTED)
63
64 # Create imported target ParaView::vtkPVVTKExtensionsCorePython
65 add_library(ParaView::vtkPVVTKExtensionsCorePython MODULE IMPORTED)
66
67 # Create imported target ParaView::vtkRemotingCorePython
68 add_library(ParaView::vtkRemotingCorePython MODULE IMPORTED)
69
70 # Create imported target ParaView::vtkRemotingServerManagerPython
71 add_library(ParaView::vtkRemotingServerManagerPython MODULE IMPORTED)
72
73 # Create imported target ParaView::vtkRemotingViewsPython
74 add_library(ParaView::vtkRemotingViewsPython MODULE IMPORTED)
75
76 # Create imported target ParaView::vtkRemotingViewsPythonPython
77 add_library(ParaView::vtkRemotingViewsPythonPython MODULE IMPORTED)
78
79 # Create imported target ParaView::vtkRemotingServerManagerPythonPython
80 add_library(ParaView::vtkRemotingServerManagerPythonPython MODULE IMPORTED)
81
82 # Create imported target ParaView::vtkRemotingMiscPython
83 add_library(ParaView::vtkRemotingMiscPython MODULE IMPORTED)
84
85 # Create imported target ParaView::vtkPVVTKExtensionsExtractionPython
86 add_library(ParaView::vtkPVVTKExtensionsExtractionPython MODULE IMPORTED)
87
88 # Create imported target ParaView::vtkRemotingLivePython
89 add_library(ParaView::vtkRemotingLivePython MODULE IMPORTED)
90
91 # Create imported target ParaView::vtkRemotingImportPython
92 add_library(ParaView::vtkRemotingImportPython MODULE IMPORTED)
93
94 # Create imported target ParaView::vtkRemotingExportPython
95 add_library(ParaView::vtkRemotingExportPython MODULE IMPORTED)
96
97 # Create imported target ParaView::vtkRemotingApplicationComponentsPython
98 add_library(ParaView::vtkRemotingApplicationComponentsPython MODULE IMPORTED)
99
100 # Create imported target ParaView::vtkRemotingApplicationPython
101 add_library(ParaView::vtkRemotingApplicationPython MODULE IMPORTED)
102
103 # Create imported target ParaView::vtkPVVTKExtensionsIOCorePython
104 add_library(ParaView::vtkPVVTKExtensionsIOCorePython MODULE IMPORTED)
105
106 # Create imported target ParaView::vtkRemotingAnimationPython
107 add_library(ParaView::vtkRemotingAnimationPython MODULE IMPORTED)
108
109 # Create imported target ParaView::vtkPVVTKExtensionsInteractionStylePython
110 add_library(ParaView::vtkPVVTKExtensionsInteractionStylePython MODULE IMPORTED)
111
112 # Create imported target ParaView::vtkRemotingSettingsPython
113 add_library(ParaView::vtkRemotingSettingsPython MODULE IMPORTED)
114
115 # Create imported target ParaView::vtkPVVTKExtensionsPointsPython
116 add_library(ParaView::vtkPVVTKExtensionsPointsPython MODULE IMPORTED)
117
118 # Create imported target ParaView::vtkPVVTKExtensionsIOSPCTHPython
119 add_library(ParaView::vtkPVVTKExtensionsIOSPCTHPython MODULE IMPORTED)
120
121 # Create imported target ParaView::vtkPVVTKExtensionsIOCGNSWriterPython
122 add_library(ParaView::vtkPVVTKExtensionsIOCGNSWriterPython MODULE IMPORTED)
123
124 # Create imported target ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython
125 add_library(ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython MODULE IMPORTED)
126
127 # Create imported target ParaView::vtkPVVTKExtensionsIOImportPython
128 add_library(ParaView::vtkPVVTKExtensionsIOImportPython MODULE IMPORTED)
129
130 # Create imported target ParaView::vtkPVVTKExtensionsIOImagePython
131 add_library(ParaView::vtkPVVTKExtensionsIOImagePython MODULE IMPORTED)
132
133 # Create imported target ParaView::vtkPVVTKExtensionsIOGeneralPython
134 add_library(ParaView::vtkPVVTKExtensionsIOGeneralPython MODULE IMPORTED)
135
136 # Create imported target ParaView::vtkPVVTKExtensionsIOExodusPython
137 add_library(ParaView::vtkPVVTKExtensionsIOExodusPython MODULE IMPORTED)
138
139 # Create imported target ParaView::vtkPVVTKExtensionsIOEnSightPython
140 add_library(ParaView::vtkPVVTKExtensionsIOEnSightPython MODULE IMPORTED)
141
142 # Create imported target ParaView::vtkPVVTKExtensionsIOAMRPython
143 add_library(ParaView::vtkPVVTKExtensionsIOAMRPython MODULE IMPORTED)
144
145 # Create imported target ParaView::vtkPVVTKExtensionsFiltersStatisticsPython
146 add_library(ParaView::vtkPVVTKExtensionsFiltersStatisticsPython MODULE IMPORTED)
147
148 # Create imported target ParaView::vtkPVVTKExtensionsFiltersPythonPython
149 add_library(ParaView::vtkPVVTKExtensionsFiltersPythonPython MODULE IMPORTED)
150
151 # Create imported target ParaView::vtkPVVTKExtensionsFiltersGeneralPython
152 add_library(ParaView::vtkPVVTKExtensionsFiltersGeneralPython MODULE IMPORTED)
153
154 # Create imported target ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python
155 add_library(ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python MODULE IMPORTED)
156
157 # Create imported target ParaView::vtkPVVTKExtensionsFiltersParallelPython
158 add_library(ParaView::vtkPVVTKExtensionsFiltersParallelPython MODULE IMPORTED)
159
160 # Create imported target ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython
161 add_library(ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython MODULE IMPORTED)
162
163 # Create imported target ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython
164 add_library(ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython MODULE IMPORTED)
165
166 # Create imported target ParaView::vtkPVVTKExtensionsFiltersRenderingPython
167 add_library(ParaView::vtkPVVTKExtensionsFiltersRenderingPython MODULE IMPORTED)
168
169 # Create imported target ParaView::vtkPVVTKExtensionsMiscPython
170 add_library(ParaView::vtkPVVTKExtensionsMiscPython MODULE IMPORTED)
171
172 # Create imported target ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython
173 add_library(ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython MODULE IMPORTED)
174
175 # Create imported target ParaView::vtkPVVTKExtensionsExtractionPythonPython
176 add_library(ParaView::vtkPVVTKExtensionsExtractionPythonPython MODULE IMPORTED)
177
178 # Create imported target ParaView::vtkPVVTKExtensionsAMRPython
179 add_library(ParaView::vtkPVVTKExtensionsAMRPython MODULE IMPORTED)
180
181 # Create imported target ParaView::vtkPVCatalystPython
182 add_library(ParaView::vtkPVCatalystPython MODULE IMPORTED)
183
184 # Create imported target ParaView::vtkPVCatalystTestDriverPython
185 add_library(ParaView::vtkPVCatalystTestDriverPython MODULE IMPORTED)
186
187 # Create imported target ParaView::vtkPVPythonCatalystPython
188 add_library(ParaView::vtkPVPythonCatalystPython MODULE IMPORTED)
189
190 # Create imported target ParaView::vtkPVClientWebPython
191 add_library(ParaView::vtkPVClientWebPython MODULE IMPORTED)
192
193 # Create imported target ParaView::vtkPVInSituPython
194 add_library(ParaView::vtkPVInSituPython MODULE IMPORTED)
195
196 # Create imported target ParaView::pvpythonmodules
197 add_library(ParaView::pvpythonmodules INTERFACE IMPORTED)
198
199 set_target_properties(ParaView::pvpythonmodules PROPERTIES
200  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.0/pvpythonmodules"
201  INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules"
202 )
203
204 # Load information for each installed configuration.
205 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/ParaViewPython-targets-*.cmake")
206 foreach(_cmake_config_file IN LISTS _cmake_config_files)
207  include("${_cmake_config_file}")
208 endforeach()
209 unset(_cmake_config_file)
210 unset(_cmake_config_files)
211
212 # Cleanup temporary variables.
213 set(_IMPORT_PREFIX)
214
215 # Loop over all imported files and verify that they actually exist
216 foreach(_cmake_target IN LISTS _cmake_import_check_targets)
217  if(CMAKE_VERSION VERSION_LESS "3.28"
218  OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target}
219  OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}")
220  foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}")
221  if(NOT EXISTS "${_cmake_file}")
222  message(FATAL_ERROR "The imported target \"${_cmake_target}\" references the file
223  \"${_cmake_file}\"
224 but this file does not exist. Possible reasons include:
225 * The file was deleted, renamed, or moved to another location.
226 * An install or uninstall procedure did not complete successfully.
227 * The installation package was faulty and contained
228  \"${CMAKE_CURRENT_LIST_FILE}\"
229 but not all the files it references.
230 ")
231  endif()
232  endforeach()
233  endif()
234  unset(_cmake_file)
235  unset("_cmake_import_check_files_for_${_cmake_target}")
236 endforeach()
237 unset(_cmake_target)
238 unset(_cmake_import_check_targets)
239
240 # Make sure the targets which have been exported in some other
241 # export set exist.
242 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
243 foreach(_target "VTK::vtkpythonmodules" )
244  if(NOT TARGET "${_target}" )
245  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
246  endif()
247 endforeach()
248
249 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
250  if(CMAKE_FIND_PACKAGE_NAME)
251  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
252  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
253  else()
254  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
255  endif()
256 endif()
257 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
258
259 # Commands beyond this point should not need to know the version.
260 set(CMAKE_IMPORT_FILE_VERSION)
261 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
