1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
40 # Set path to fallback-tool for dependency-resolution. 41 if(NOT DEFINED CMAKE_OBJDUMP)
42 set(CMAKE_OBJDUMP
"/usr/sbin/objdump")
46 file(INSTALL DESTINATION
"vtkPVCatalystTestDriver-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVCatalystTestDriver-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalystTestDriver-pv6.2.so.6.2
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalystTestDriver-pv6.2.so.1
" 54 if(EXISTS "${file}
") 58 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalystTestDriver-pv6.2.so.6.2
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalystTestDriver-pv6.2.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalystTestDriver-pv6.2.so.6.2
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalystTestDriver-pv6.2.so.1
" 69 if(EXISTS "${file}
") 73 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 74 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 75 if(CMAKE_INSTALL_DO_STRIP) 76 execute_process(COMMAND "/usr/sbin/strip
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalystTestDriver-pv6.2.so
" TYPE FILE FILES 95 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/
vtkCPFieldBuilder.h
" 97 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/
vtkCPGridBuilder.h
" 103 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/
vtkCPTestDriver.h
" 110 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 111 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver/vtkPVCatalystTestDriverModule.h
") 114 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 115 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver/vtkPVCatalystTestDriver.spdx
") 118 string(REPLACE ";
" "\n
" CMAKE_INSTALL_MANIFEST_CONTENT 119 "${CMAKE_INSTALL_MANIFEST_FILES}
") 120 if(CMAKE_INSTALL_LOCAL_ONLY) 121 file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver/install_local_manifest.txt
" 122 "${CMAKE_INSTALL_MANIFEST_CONTENT}
") Class for specifying constant scalars at points.
Abstract class for specifying tensor fields at points.
Class for specifying nodal fields over grids.
Class for specifying cell fields over grids.
Abstract class for creating grids.
Class for creating multiblock grids.
Class for creating a co-processor test driver.
Abstract class for specifying vectors at points.
Abstract class for specifying scalars at points.
Abstract class for specifying fields over grids.
Class for specifying scalars at points.
Class for creating grids from a VTK file.
Class for creating unstructured grids.
