1 set(CMAKE_Fortran_COMPILER
"/usr/sbin/f95")
2 set(CMAKE_Fortran_COMPILER_ARG1
3 set(CMAKE_Fortran_COMPILER_ID
"GNU")
4 set(CMAKE_Fortran_COMPILER_VERSION
"16.2.1")
5 set(CMAKE_Fortran_COMPILER_WRAPPER
6 set(CMAKE_Fortran_PLATFORM_ID
7 set(CMAKE_Fortran_SIMULATE_ID
8 set(CMAKE_Fortran_COMPILER_FRONTEND_VARIANT
"GNU")
9 set(CMAKE_Fortran_SIMULATE_VERSION
14 set(CMAKE_AR
"/usr/sbin/ar")
15 set(CMAKE_Fortran_COMPILER_AR
"/usr/sbin/gcc-ar")
16 set(CMAKE_RANLIB
"/usr/sbin/ranlib")
17 set(CMAKE_LINKER
"/usr/sbin/ld")
18 set(CMAKE_Fortran_COMPILER_LINKER
"/usr/sbin/ld")
19 set(CMAKE_Fortran_COMPILER_LINKER_ID
"GNU")
20 set(CMAKE_Fortran_COMPILER_LINKER_VERSION 2.46.1)
21 set(CMAKE_Fortran_COMPILER_LINKER_FRONTEND_VARIANT GNU)
22 set(CMAKE_Fortran_COMPILER_RANLIB
"/usr/sbin/gcc-ranlib")
23 set(CMAKE_TAPI
"CMAKE_TAPI-NOTFOUND")
24 set(CMAKE_COMPILER_IS_GNUG77 1)
25 set(CMAKE_Fortran_COMPILER_LOADED 1)
26 set(CMAKE_Fortran_COMPILER_WORKS TRUE)
27 set(CMAKE_Fortran_ABI_COMPILED TRUE)
29 set(CMAKE_Fortran_COMPILER_ENV_VAR
"FC")
31 set(CMAKE_Fortran_COMPILER_SUPPORTS_F90 1)
33 set(CMAKE_Fortran_COMPILER_ID_RUN 1)
34 set(CMAKE_Fortran_SOURCE_FILE_EXTENSIONS f;F;fpp;FPP;f77;F77;f90;F90;
for;For;FOR;f95;F95;f03;F03;f08;F08)
35 set(CMAKE_Fortran_IGNORE_EXTENSIONS h;H;o;O;obj;OBJ;def;
DEF;rc;RC)
36 set(CMAKE_Fortran_LINKER_PREFERENCE 20)
37 set(CMAKE_Fortran_LINKER_DEPFILE_SUPPORTED TRUE)
38 set(CMAKE_LINKER_PUSHPOP_STATE_SUPPORTED TRUE)
39 set(CMAKE_Fortran_LINKER_PUSHPOP_STATE_SUPPORTED TRUE)
41 set(CMAKE_Fortran_OUTPUT_EXTENSION .o)
43 set(CMAKE_Fortran_OUTPUT_EXTENSION .obj)
46 # Save compiler ABI information. 47 set(CMAKE_Fortran_SIZEOF_DATA_PTR
"8")
48 set(CMAKE_Fortran_COMPILER_ABI
49 set(CMAKE_Fortran_LIBRARY_ARCHITECTURE
51 if(CMAKE_Fortran_SIZEOF_DATA_PTR AND NOT CMAKE_SIZEOF_VOID_P)
52 set(CMAKE_SIZEOF_VOID_P
"${CMAKE_Fortran_SIZEOF_DATA_PTR}")
55 if(CMAKE_Fortran_COMPILER_ABI)
56 set(CMAKE_INTERNAL_PLATFORM_ABI
"${CMAKE_Fortran_COMPILER_ABI}")
59 if(CMAKE_Fortran_LIBRARY_ARCHITECTURE)
60 set(CMAKE_LIBRARY_ARCHITECTURE
67 set(CMAKE_Fortran_IMPLICIT_INCLUDE_DIRECTORIES
"/usr/lib/gcc/x86_64-redhat-linux/16/include;/usr/local/include;/usr/include")
68 set(CMAKE_Fortran_IMPLICIT_LINK_LIBRARIES
"gfortran;m;gcc_s;gcc;atomic_asneeded;quadmath;m;c;gcc_s;gcc")
69 set(CMAKE_Fortran_IMPLICIT_LINK_DIRECTORIES
"/usr/lib/gcc/x86_64-redhat-linux/16;/usr/lib64;/lib64;/usr/lib;/lib")
70 set(CMAKE_Fortran_IMPLICIT_LINK_FRAMEWORK_DIRECTORIES
