This document describes the functionality and naming of the existing C++ interactor style proxies, and gives some best practices for writing new ones.
Many of the built-in C++ interactor styles can be grouped into two main categories: those that control the entire scene, and those that control a single source or view property. Interactor styles that control the entire scene include Travel in the name, while interactor styles that control a single property include Control in the name. Note, however, there are several interactor styles that do not fall into either of these categories, for example, Debug, Track, and Python.
When interactor styles provide a rotational component to the interaction, this can happen in one of two ways. Either the scene/object can appear to orbit around the viewer, which we have termed ego-centric rotation, or else the scene/object can appear to rotate about the center of the world (turn on "Center Axes" in ParaView's view properties to see where this point is). We have termed this latter type of rotation exo-centric. Built-in C++ interactor styles that provide a rotational component to their interaction thus include either Exo or Ego in the name to indicate which type of rotation is provided.
When an interactor style includes Grab in the name, the intent is that it behaves by following the location and orientation of the controller, as if you had grabbed the object or scene. When an interactor style includes Split in the name, it indicates that it provides both translational and rotational components to the interaction, which are triggered by separate buttons.
To provide some background and motivation for the best practices section, below, this section describes how the plugin works. The CAVEInteraction plugin is multithreaded, when the user clicks the "Start" button in the panel, it starts the background thread collecting events from the tracking system. In the foreground thread, this begins the event loop running which consists of the following:
Handle...() methods implemented by the interactor styles are called.Update() once on each interactor styleStillRender()Typically, many new events will arrive during one iteration of the event loop, mostly tracker events (or valuator events if those are used). Many of those tracker events are essentially a replacement of the previous tracker event associated to the same role, so it doesn't make sense to do a lot of work that will just be repeated multiple times before the next Update() and StillRender() portion of the event loop.
Based on the event loop description above, it's clear that one best practice (aimed at performance) is to minimize the work done in HandleTracker(). Thus, all of the built-in C++ interactor styles follow the practice of simply copying the tracker matrix contained in the event payload (and possibly doing any work that needs to be done only once after the initial button press). Then in the Update() method, the latest copy of the tracker matrix is used to do any computations, and finally the UpdateVTKObjects() method is called on the controlled proxy, if necessary. This practice maximizes the effective fps that can be achieved by the plugin.
Controlling the entire scene can only be accomplished by manipulating the ModelTransformMatrix property of the active vtkSMRenderViewProxy. This proxy can be acquired by calling GetActiveView() in Python, or by calling the vtkSMVRInteractorStyleProxy::GetActiveViewProxy() in C++. There is also an alias (available in both Python and C++) for this behavior in the vtkSMVRInteractorStyleProxy base class: SetNavigationMatrix(). This alias was created to align with the terminology used for the coordinate system property of ParaView representations, which allows them to be placed in either Navigable (world) or Fixed (physical) coordinate systems.
When writing any new interactor style, recall from above that all travel (control of the entire scene) can only be accomplished by manipulation of the ModelTransformMatrix. Thus, all interactor styles must account for likely non-identity ModelTransformMatrix to make sure they work well with other interactor styles. When controlling a 3D point or vector, this means first converting the 3D element into model coordinates, then performing the desired transformation on the element, then converting back to world coordinates. When controlling the ModelTransformMatrix itself, this typically means translating the matrix back to the origin, operating on it, then translating it back, before setting the property back on the proxy again. All built-in C++ interactor styles behave this way, so it should always work well to have several of them loaded at any given time.
Notice from the description of the event loop above that nothing prevents a button press from being the final event in the pile of dequeued events. If that happens when more than one interactor is being used to control the same property, it is important not to proceed with Update(), or you may notice distinct jumps in position or orientation of the target property. To avoid this, all built-in interactor styles use a variable to indicate whether at least one tracker event has been handled since the button was pressed, and they avoid doing anything in Update() until that has happened.
1.8.13 on Mon May 25 2026
