Major changes made since ParaView 5.9.1 are listed in this document. The full list of issues addressed by this release is available here.
ParaView is now tested on the macOS arm64 platform.
Due to this change, ParaView binaries are now available using the processor name according to the platform in the binary filename rather than a generic "32Bit" or "64Bit" indicator.
Linux: x86_64 macOS: arm64 and x86_64 Windows: AMD64
To make it easier to test and validate HPC builds, we have added a new package under the paraview Python package called tests. This package includes several modules that test and validate different aspects of the ParaView build.
The tests can be run as follows:
Use the --help or -h command line argument for either the paraview.tests package or individual test module to get list of additional options available.
The list is expected to grow over multiple releases. Suggestions to expand this validation test suite are welcome.
The command-line options parsing code has been completely refactored. ParaView now uses CLI11. This has implications for users and developers alike.
There way to specify command line options is now more flexible. These can be provided as follows:
-a : a single flag / boolean option-f filename: option with value, separated by space--long: long flag / boolean option--file filename: long option with value separated using a space--file=filename: long option with value separated by equalsNote this is a subset of ways supported by CLI11 itself. This is because ParaView traditionally supported options of form -long=value i.e. - could be used as the prefix for long-named options. This is non-standard and now deprecated. Instead, one should add use -- as the prefix for such options, e.g., -url=... becomes --url=.... Currently, this is done automatically to avoid disruption and a warning is raised. Since this conflicts with some of the other more flexible ways of specifying options in CLI11, we limit ourselves to the ways listed above until this legacy behavior is no longer supported.
The --help output for all ParaView executables is now better formatted. Options are grouped, making it easier to inspect related options together. Mutually exclusive options and deprecated options are clearly marked to minimize confusion. Also, in most terminals, the text width is automatically adjusted to the terminal width and text is wrapped to make it easier to read.
Several options support overriding default values using environment variables. If the option is not specified on the command line, then that denoted environment variable will be used to fetch the value for that option (or flag).
vtkPVOptions and subclasses are deprecated. Instead of a single class that handled the parsing of the defining of command line flags/options, command-line arguments, and then keep state for the flag/option selections, the new design uses two different classes. vtkCLIOptions handle the parsing (using CLI11), while singletons such as vtkProcessModuleConfiguration, vtkRemotingCoreConfiguration, pqCoreConfiguration maintain the state and also populate vtkCLIOptions with supported flags/options. Custom applications can easily add their own *Configuration classes to populate vtkCLIOptions to custom options or override the default ParaView ones. If your custom code was simply checking user selections from vtkPVOptions or subclasses, change it to using the corresponding *Configuration singleton
The format of text strings used to reference certain quantities in ParaView have been standardized across sources, filters, and views. ParaView now uses the {fmt} library and associated syntax to reference particular quantities available in different contexts.
In all sources, filters, and views that make use of substitution strings, the following globally available text strings can be used to reference the information they represent:
{username} (equivalently, {ENV_username}) - name of user logged in to machine on which ParaView is running{hostname} (equivalently, {ENV_hostname}) - name of host machine on which ParaView is running{os} (equivalently, {ENV_os}) - name of operating system on which ParaView is running{date} (equivalently, {GLOBAL_date}) - date and time at which ParaView was started.{appname} (equivalently, {GLOBAL_appname}) - name of the application, e.g ParaView. For ParaView-based applications, this will evaluate to the name of the application.{appversion} (equivalently, {GLOBAL_appversion}) - version of the application.The actual information represented by the strings listed above is substituted into the string that is rendered, subject to formatting modifiers supported by the {fmt} library for strings, numbers, and dates.
These sources and filters use the new string formatting method:
{time}. The number formatting syntax from the {fmt} library are available to control the precision of the displayed time, e.g., {time:3.2f} limits the number of displayed digits after the decimal point to two.time_value, and time_index in the provided expression, now you may also use {timevalue} == {CALCULATOR_timevalue}, and {timeindex} == {CALCULATOR_timeindex}.{time} available in their Chart Title properties in addition to the globally available substitutions. The Bag Chart View (Comparative) views provided in the BagPlotViewsAndFilters plugin also defines a {variance} string substitution available for use in the Chart Title property.{time} (equivalently, {EXTRACT_time}) and an additional {timestep} (equivalently, {EXTRACT_timestep}) substitution that provides the current timestep index. In addition, image extractors have available a {camera} (equivalently, {EXTRACT_camera}) substitution for encoding camera information in the output File Name property.>
Example of new string formatting in an Annotate Time filter.
You can now customize a set of favorite directories displayed in file dialogs. Buttons to "Add current directory to favorites", "Remove current directory from favorites" and "Reset favorites to system default" are available in the dialog. The context menu that appears when right-clicking a directory in the files list now includes "Add to favorites", "Remove from favorites", "Rename", and "Open in file explorer" options. When the "Open in file explorer" option is selected, if the selected item is a directory, it will be opened in the system file explorer. Otherwise, if a file or nothing is selected, the current directory is opened in the file explorer. The context menu shows a "Delete empty directory" when right-clicking an empty directory in the files list.
When right-clicking a directory in the favorites list, a "Rename label" option is available, which can also be triggered by pressing the F2 key. It only renames the label displayed in the favorites list and not the actual folder name. If a favorites directory does not exist (e.g., it was deleted), the name is greyed out and in italic, and the icon indicates a warning and the tooltip says that the path does not exist.
Standard shortcuts to some buttons in the file dialog have been added as well. Alt+Left goes back, Alt+Right goes forward, Alt+Up goes to the parent directory and Ctrl+N creates a new directory. The "Create New Folder" button is now disabled when opening an existing file.
It is now possible to change the granularity of the animation using the Stride property in the Animation View. This property only makes sense in the Snap to Timesteps and Sequence mode, i.e., when there is a fixed number of frames. The Stride property allows skipping a fixed number of frames to control how many frames should be displayed. For example, with a dataset having a time domain of [0,1,2,3,4,5,6] and when setting the stride to 2, only the times [0,2,4,6] will be used. The stride is taken into account when using the Play, Go To Next Frame or Go To Previous Frame buttons. A stride of 1 will act as the default behavior, i.e., no frames are skipped.
The 'RealTime' animation mode is deprecated and will be removed in a future release. Rationale:
See the discussion leading to the decision to remove this animation mode.
The Default View Type advanced property under "General" settings/preferences tab now has an "Empty" option. This setting will open ParaView with an empty view that lets you select one of the available views.
ParaView server configuration files (PVSC) now support two new predefined variables:
PV_APPLICATION_DIR: This is set to the directory containing the application executable. For macOS app bundles, for example, this will be inside the bundle. This is simply QCoreApplication::applicationDirPath.PV_APPLICATION_NAME: This is set to the name of the Qt application as specified during application initialization. This is same as QCoreApplication::applicationName.ParaView now supports a 19-node-pyramid (vtkTriQuadraticPyramid) element. This new cell type is included as an option in the UnstructuredCellTypes source.
ParaView 5.10.0 installers now include many more example datasets. A netCDF example with sea surface temperature has been added. VTK legacy and XML examples have also been added, including both structured and unstructured datasets. Some of these datasets are parallel and/or time-dependent examples.
Render View (and related views) now have a property UseColorPaletteForBackground that indicates if the view-specific background overrides should be used or the view should simply use the global color palette to determine how the background is rendered. Previously, it was confusing to know which views were using the global color palette and which ones were using user overridden values for background color.
In addition, instead of having separate boolean properties that are largely mutually exclusive, the view now adds a BackgroundColorMode property that lets the user choose how the background should be rendered. Supported values are "Single Color", "Gradient", "Texture" and "Skybox".
This change impacts the Python API. UseGradientBackground, UseTexturedBackground and UseSkyboxBackground properties have been replaced by BackgroundColorMode which is now an enumeration that lets you choose how to render the background. Also, unless Python compatibility for ParaView 5.9 or earlier is specified, view specific background color changes will get ignored unless UseColorPaletteForBackground property is not set to 0 explicitly.
When using the PBR representation under the lighting panel, you can now add a second layer on top of the base layer. This is useful to simulate a coating on top of a material. This layer is dielectric (as opposed to metallic), and can be configured with various parameters. You can set the coat strength to control the presence of the coat layer (1.0 means strongest coating), the coat roughness and the coat color. You can also choose the index of refraction of the coat layer as well as the base layer. The more the index of refraction goes up, the more specular reflections there are.
You can also use a texture to normal map the coating. These parameters are supported by OSPRay pathtracer.
When using the PBR representation under the lighting panel, you can now set the anisotropy strength and anisotropy rotation for a material. The anisotropy strength controls the amount of light reflected along the anisotropy direction (i.e., the tangent). The anisotropy rotation rotates the tangent around the normal. Notice that the object must have normals and tangents defined to work. You can also use a texture to hold the anisotropy strength in the red channel, and the anisotropy rotation in the green channel. These parameters are supported by OSPRay pathtracer.
You can now rotate the Skybox horizontally with Control + Left Click. This binding was previously set to rotate the view. You can still rotate the view with Left Click alone. This is useful when using "PBR" (physically-based rendering) shading and "Image Based Lighting" and you want to change the reflection without moving geometry in the scenery.
The Text Source Representation used to represent how text sources are rendered has been updated to let you customize the borders and the background of the text. For the borders, it is now possible to draw round corners, choose the color as well as the thickness. A combo box allows you to define the visibility of the border (only on hover, always or never). For the text, you can now choose the background color and opacity and the right and top padding between the border and the text.
The rendering of equations using mathtext now supports multiline and multicolumn equations. You can define a new line by writing a new line in the text source, and you can define a new column by entering the character '|'. You can still write a '|' by escaping it with a backslash ('\|').
A new double property, WindowResizeNonInteractiveRenderDelay, on view proxies has been added that lets you set the time in seconds before doing a full-resolution render after the last WindowResize event. This allows the view to render interactively when resizing a window, improving rendering performance when using large data sets.
Topology Toolkit (TTK) filters are now available in ParaView by loading the TopologyToolkit plugin. TTK is a collection of filters that help with topological data analysis.
Structured grids rendered by the "NVIDIA IndeX" representation can now be cropped to a volume of interest (VOI) by checking the "Use Cropping" property. Cropping is controlled by an interactive box widget or through the associated text widgets.
This replaces the custom "NVIDIA IndeX Region of Interest" properties, which however are still in use for unstructured grids. Existing state files that rely on the old properties will continue to work, but a warning will be printed, showing the corresponding settings for the "Cropping Origin" and "Cropping Scale" parameters.
A limited "remote rendering only" version of the NVIDIA IndeX plugin is now available for macOS, making it possible to connect a macOS ParaView client to a remote pvserver running Linux and rendering with NVIDIA IndeX there. The plugin does not support local rendering on macOS and an error will be printed when the user tries to enable the "NVIDIA IndeX" representation locally.
32-bit integer data values (signed/unsigned) of structured and unstructured grids will be automatically converted to an internal float representation by the plugin, to enable efficient rendering. This automatic data conversion does not affect the memory utilization.
Multiple components per voxel (e.g. vector or RGB data) are now supported for structured grids. The component to be rendered can be selected with the "Coloring" setting in the "Properties" panel. Rendering the vector magnitude is also supported.
Plugin settings can be changed in the new "NVIDIA IndeX" tab of the "Settings" dialog:
nvindex_config.xml, which still takes precedence if it exists.nvindex_config.xml (both have precedence).Fixed the "Update kernel" button not always updating the rendering after the source code of an XAC shader was modified.
On Windows, the NVIDIA IndeX plugin can now be used to connect to a remote pvserver even if no NVIDIA display driver is installed locally.
Fixed an issue that could lead to visible seams on structured grids for certain configurations when rendering in cluster mode on multiple hosts.
The GmshReader plugin is deprecated in favor of the GmshIO plugin.
The Calculator filter implementation has a completely new backend and has been multhithreaded using VTK's symmetric multiprocessing tools. The implementation uses the ExprTk library for expression parsing and evaluation. The new implementation solves several bugs found in the previous calculator implementation, and it offers improved performance as well. Expression syntax is largely unchanged, but the expression for a dot product operation has changed from A.B to dot(A,B). Data arrays with names that include spaces or characters unsupported by the backend can be used as long as they are surrounded by quotation marks. The previous implementation will be used for backwards compatibility when loading state files from ParaView 5.9.1 or earlier.
New thresholding methods have been added to the Threshold filter:
Previously, it was possible to keep only cells with values falling between two values.
Accordingly, the property ThresholdBetween has been removed. Instead, the following three properties have been added: LowerThreshold, UpperThreshold and ThresholdMethod.
Extract Block filter now supports choosing blocks to extract using selector expressions. This makes the block selection more robust to changes to the input hierarchy than the previous selection implementation, which was based on block indices.
The Group Datasets filter now supports multiple types of outputs including vtkPartitionedDataSetCollection, vtkPartitionedDataSet, and vtkMultiBlockDataSet. One can also assign names to inputs which then get assigned as blocked names in the output.
Before ParaView 5.10, these two filters could be used to compute the gradient of a dataset:
Gradient for vtkImageData onlyGradient Of Unstructured DataSet for all vtkDataSet typesThese two filters have been replaced with a single Gradient filter based on vtkGradientFilter and including the functionalities from the former Gradient filter.
For vtkImageData objects, it is still possible to use the specialized implementation through the BoundaryMethod property, which has two options defining the gradient computation at the boundaries:
Smoothed corresponds to the the old Gradient filter and uses central differencing for the boundary elements by duplicating their valuesNon-Smoothed corresponds to the old Gradient of Unstructured DataSet implementation and simply uses forward/backward differencing for the boundary elementsFor all other vtkDataSet objects, the filter usage is unchanged.
Previously, Resample With Dataset would not pass partial arrays from composite dataset input. A new option, Pass Partial Arrays has been added. When on, partial arrays are sampled from the source data.
For all those blocks where a particular data array is missing, this filter uses vtkMath::Nan() for double and float arrays, and 0 for all other types of arrays (e.g., int, char, etc.)
The Histogram filter has been enhanced in several ways:
Filter named Grid Connectivity has been removed. The Connectivity filter should support a wider set of use cases than the Grid Connectivity filter and should be preferred.
A new filter, Convert To Point Cloud, has been added. It let users convert any dataset into a vtkPolyData containing the same points as the inputs but with either a single poly vertex cell, one vertex cell per point, or no cells.
The Merge Time filter takes multiple temporal datasets as input and synchronizes them.
The output data is a multiblock dataset containing one block per input dataset. The output timesteps are the union (or the intersection) of each input's timestep list. Duplicate time values within an absolute or relative tolerance are removed.
The Merge Vector Components filter takes three separate single-component data arrays and combines them into a single vector (three-component) data array in the output. More
The Rotational Extrusion filter has a new property named Rotation Axis to select the axis around which the extrusion shall be done. The default stays the z-axis.
ParaView Windows binaries now offer export of H.264-encoded MP4 files. The frame rate and bit rate are both exposed as options.
ParaView now uses the IOSS library to read Exodus files. This new reader,vtkIOSSReader, was introduced in 5.9 as a plugin. In this release, ParaView now uses this new reader as the default reader for all Exodus files. The previous reader is still available and can be used in the UI by simply loading the LegacyExodusReader plugin. XML state files and Python scripts using the old Exodus reader explicitly will continue to work without any changes.
The IOSS reader has several advantages over the previous implementation. One of the major advantage is that it uses the modern vtkPartitionedDataSetCollection as the output data-type instead of vtkMultiBlockDataSet.
In additional to Exodus, IOSS reader now supports reading CGNS files as well. Note, the reader only supports a subset of CGNS files that are generated using the IOSS library and hence may not work for all CGNS files. The CGNS reader is still the preferred way for reading all CGNS files.
ParaView now has a writer for OpenVDB Format files. The writer currently works with vtkDataSets and time-series data.
Uniform grid data exported from ParaView using the OpenVDB writer and rendered in 3D Studio Max. Data generated by the Geotechnical and Structures Laboratory at the US Army's ERDC and visualization generated by the US DoD HPCMP.
ParaView now has a reader for Open Mining Format files. You can specify which elements - point set, line set, surface, or volume - should be loaded.
ParaView now includes a reader for the SAVG file format, developed by the High Performance Computing and Visualization Group at the National Institute of Standards and Technology. SAVG is an ASCII format supporting definition of primitives likes points, lines, and polygons.
#sinclude directive (silent include) - OpenFOAM-v1806<case>, <constant>, <system> tagss - OpenFOAM-v1806include compatibility keyword, which was poorly documented, rarely (if ever) used. Was deprecated in 2008 (OpenFOAM-v1.5)uniformFixedValue. The content that can be specified as a "uniformValue" has evolved well beyond a simple value that can be handled without using OpenFOAM libraries.Avoid lagrangian and region name ambiguity.
Now prefix all non-default regions as "/regionName/...". The default region has now prefix. This eliminates any possible ambiguity if we happen to have slightly odd region names like "patch", "lagrangian", "internalMesh", ...
Remove hard-coded limits on polyhedral size
For some systems, one can have a so-called "single-cell" OpenFOAM mesh with a single polyhedral cell that has LOTS of faces.
This can be used for mapping surface noise data to retain most of the geometry but entirely discarding the internal field. It can also potentially arise from finiteArea situations.
Preserve uncollated lagrangian information (fixes #18179)
Old version assumed lagrangian data are available on all processor sub-directories and used a central naming mechanism accordingly.
This meant that missing clouds on higher processors would effectively block out clouds. Likely didn't work properly with clouds in multiple regions.
Avoid rescanning of time directories for decomposed
Avoids repetitive calls to directory listings, which tend to really slow down loading.
fixed handling of SetTimeValue() in vtkPOpenFOAMReader.
This mostly affected direct calls from VTK (not from ParaView)
The SEP reader can now read up to 32 dimensions and output either 2D or 3D scalar fields. Be careful, though, as the proxy settings have changed: the default parameters for the scalar field may not necessarily correspond to the original one, leading to different output.
The Information Panel has been redesigned to improve the way information is presented. Besides general layout improvements that make the panel more compact and consistent with other panels:
The Color Map Editor now has a combo box to quickly apply a preset from the Default group without needing to open the Choose Preset dialog.
Imported presets can specify a Groups field in their json definition files to add the preset to one or more groups. For example this preset will be added to the groups Default, CustomGroup1, and Linear:
In this case, CustomGroup1 does not exist beforehand so it will be created on import. If the Groups field is absent in the JSON definition, the preset is added to the Default and User groups. The DefaultMap field is no longer used as it is redundant with the new Groups field. Additionally, any preset can now be added or removed from the Default group.
To aid in viewing the results of applying differet color maps to the visualization, the Choose Preset dialog is now non-modal, meaning it can remain open while you interact with ParaView's other user interface elements. Lastly, imported presets are displayed in italics to be able to differentiate them from base presets.
The Find Data dialog has been replaced by Find Data panel which offers similar capabilities but is now a dockable panel.
The Selection Display Inspector been removed since the Find Data panel presents the same information under the Selection Display section.
The following was added to the ParaView Python script editor:
Some property widgets in the Edit Color Legend Window now have descriptions.
Basic properties:
Advanced properties:
Options for the Window Location property in the Edit Color Legend Properties have been made more readable by adding spaces between words. For example, LowerLeftCorner has been replaced with Lower Left Corner.
Adds the following in the Help -> About dialog:
Two new buttons "Reset Camera Closest" and "Zoom Closest To Data" has been added to the right of the existing "Reset Camera" and "Zoom To Data" buttons. These buttons reset the camera to maximize the screen occupancy occupation of the whole scene bounding box ("Reset Camera Closest") or of the active source bounding box ("Zoom Closest To Data").
When clicking the screenshot capture button, a simple click now saves the screenshot to a file and a click with a modifier key (Option or Ctrl) copies it to the clipboard, which is the opposite of what it was before.
When copying a screenshot to the clipboard, the view now blinks to confirm the copying action.
A new OSPRay material editor control panel has been added to control the OSPRay materials. This control panel can be accessed by selecting the "Material Editor" item in the "View" menu. The control panel is available when ParaView is compiled with PARAVIEW_ENABLE_RAYTRACING CMake option set to ON to enable the editor widget.
This editor enables the following:
.json file or create materials directly in the GUI>
ParaView will now detect whether OSPRay is supported at runtime and enable it only if it is. Of note is when using under macOS' Rosetta translation support of x86_64 binaries on arm64 hardware.
The "ParaView Community Support" link in the "Help" menu will send you to the ParaView Support Discourse page to open a new topic or search for an existing one.
When loading .pvsm state files in Python using LoadState function, it was tricky to provide arguments to override data files used in the state file. The LoadState function has now been modified to enable you to specify filenames to override using a Python dictionary. The Python trace captures this new way of loading state files. Invocations of this function with previously used arguments is still supported and will continue to work.
Some examples:
To make creation of various proxies easier, ParaView defines classes for each known proxy type. These class types were immediately defined when paraview.simple was imported or a connection was initialized. Creation of these class types is now deferred until they are needed. This helps speed up ParaView Python initialization.
This change should be largely transparent to users except for those who were directly accessing proxy types from the paraview.servermanager as follows:
paraview.simple now provides a new way to fetch all data from the data server to the client from a particular data producer. Using paraview.simple.FetchData users can fetch data from the data-server locally for custom processing.
Unlike Fetch, this new function does not bother applying any transformations to the data and hence provides a convenient way to simply access remote data.
Since this can cause large datasets to be delivered the client, this must be used with caution in HPC environments.
The openPMD python module now supports 1D and 2D particle and mesh data. API changes for openPMD-api 0.13+ were incorporated and several read bugs have been fixed.
Many updates to improve the OpenVR plugin support have been made in ParaView 5.10:
A new Microsoft Windows-only plugin named zSpace has been added. It adds a new view named zSpaceView that let a user interact with a zSpace device directly. This device is designed to work with Crystal Eyes (quad-buffered) stereo, in full screen or in a CAVE display. The zSpace glasses use a head tracking system that allow you to look around 3D object by moving your head.
This plugin requires a zSpace System Software >= 4.4.2, and a SDK version >= 4.0.0. It was tested on a zSpace 200 device but should be compatible with more recent devices as well.
The icons in macOS 11 Big Sur are in a new unified style, and ParaView's icon has been updated to conform to this style.
ParaViewWeb now supports [unsigned] long long data arrays when retrieving data information.
To assist in debugging in-situ pipelines, Catalyst now supports conduit_node I/O. The params argument to each invocation of catalyst_initialize, catalyst_execute, and catalyst_finalize can be written to disk. These can later be read back in using the catalyst_replay executable. Please see the corresponding documentation for more information.
Fortran bindings to Catalyst APIs has been improved. There is now a catalyst and catalyst_python module available with namespaced APIs.
catalyst modulecoprocessorinitialize() is now catalyst_initialize()coprocessorfinalize() is now catalyst_finalize()requestdatadescription(step, time, need) is now need = catalyst_request_data_description(step, time)needtocreategrid(need) is now need = catalyst_need_to_create_grid()coprocess() is now catalyst_process()The need return values are of type logical rather than an integer.
catalyst_python modulecoprocessorinitializewithpython(filename, len) is now catalyst_initialize_with_python(filename)coprocessoraddpythonscript(filename, len) is now catalyst_add_python_script(filename)Add steering capabilities to Catalyst 2.0, by implementing the catalyst_results method in ParaView Catalyst.
With steering, you are now able to change simulation parameters through the ParaView Catalyst GUI. See CxxSteeringExample in Examples/Catalyst2 folder for live example of the feature.
A new TimeValue trigger option for triggering output through Catalyst 2.0 has been added which is based on the amount of simulation time that has passed since the last output of the specified extract. This trigger option is more appropriate for simulation codes that have variable timestep lengths.
Catalyst Adaptor API V2 now supports polygonal and polyhedral elements. This is done by adding support for such elements in vtkConduitSource. Two new examples, CxxPolygonal and CxxPolyhedra, demonstrate how to use Conduit Mesh Blueprint to communicate information about these elements.
Catalyst 2.0 used to fail when the simulation code sent a mesh through Conduit with a full Conduit tree that matches the Mesh Blueprint but without any cells or points. This can happen, for example, with distributed data where some of the dataset may be empty on some ranks. When using vtkUnstructedGrids, Catalyst 2.0 now checks the number of cells in the Conduit tree and returns an empty vtkUnstructuredGrid when needed.
This release reintroduces the experimental recolorable images generation capability. It is exposed using Extractors. A new experimental extractor called Recolorable Image is now available. The extractor is experimental and requires specific conditions to work.
vtkPVDataInformationvtkPVDataInformation implementation has been greatly simplified.
vtkPVDataInformation no longer builds a complete composite data hierarchy information. Thus, vtkPVCompositeDataInformation is no longer populated and hence removed. This simplifies the logic in vtkPVDataInformation considerably.
vtkPVDataInformation now provides access to vtkDataAssembly representing the hierarchy for composite datasets. This can be used by application to support cases where information about the composite data hierarchy is needed. For vtkPartitionedDataSetCollection, which can other assemblies associated with it, vtkPVDataInformation also collects those.
For composite datasets, vtkPVDataInformation now gathers information about all unique leaf datatypes. This is useful for applications to determine exactly what type of datasets comprise a composite dataset.
vtkPVTemporalDataInformation is now simply a subclass of vtkPVDataInformation. This is possible since vtkPVDataInformation no longer includes vtkPVCompositeDataInformation.
ProxyListDomain support default for groupA proxy list domain containing a group can define a proxy from that group to use as the default. As an example, the following says to use the SphereSource as the default proxy for the property to which this ProxyListDomain is assigned.
Previously, the default proxy was alphabetically the first in the group.
Most filters using ProxyListDomain have been converted to use group and default in order for it to be easier to add a new proxy to a proxy list domain through plugins.
paraview_plugin_add_proxyA new example plugin AddPQProxy has been added to demonstrate how to use the paraview_plugin_add_proxy CMake macros (add_pqproxy before ParaView 5.7.0).
Three new CMake options to the paraview_add_plugin function have been added:
DOCUMENTATION_DIR other than the default ones (i.e., *.html, *.css, *.png, *.js and *.jpg). This can be used to add new patterns (ex: *.txt) or even subdirectories (ex: subDir/*.*). Subdirectory hierarchy is kept so if you store all of your images in a img/ sub directory and if your HTML file is at the root level of your documentation directory, then you should reference them using <img src="img/my_image.png"/> in the HTML file.ref keyword) that is accessed when double-clicked in the UI. A section that contains other sections can be folded into the UI. An example of such a string is: See Examples/Plugins/ElevationFilter for an example of how to use these features.
It is possible to add a .js file to a plugins documentation and reference it into an .html file. However JS scripts will only be evaluated if PARAVIEW_USE_WEBENGINE is activated. Inline scripting using <script> [...] </script> is also possible. An example of how to add a documentation folder is available at Examples/Plugins/ElevationFilter/.
A new example that shows how to create a plugin with a complex architecture is now available.
This new example contains two plugins. One plugin uses multiple internal VTK modules. Both plugins use a third, shared, VTK module.
The example can be found in Examples/Plugins/ComplexPluginArchitecture.
New CMake options to debug plugin discovery and building have been added. The ParaView_DEBUG_PLUGINS, ParaView_DEBUG_PLUGINS_ALL, ParaView_DEBUG_PLUGINS_building, and ParaView_DEBUG_PLUGINS_plugin flags may be used to enable various logging for plugins.
Dynamically-loaded plugins can now get the file system location of the plugin binary file (DLL, shared object) with the addition of the pqPluginLocationInterface class and paraview_add_plugin_location CMake function. This allows dynamic plugins to include text and/or data files that can be located and loaded at runtime.
pqProxyWidgetpqProxyWidget is the widget used to auto-generate several panels based on proxy definitions. The class supports two types of panel visibilities for individual widgets for properties on the proxy: default and advanced. These needed to match the value set for the panel_visibility attribute used the defining the property in ServerManager XML. pqProxyWidget now has API to make this configurable. One can now use arbitrary text for panel_visibility attribute and then select how that text is interpreted, default or advanced, by a particular pqProxyWidget instance. This makes it possible for proxies to define properties that are never shown in the Properties panel, for example, but are automatically shown in some other panel such as the Multiblock Inspector without requiring any custom code. For more details, see pqProxyWidget::defaultVisibilityLabels and pqProxyWidget::advancedVisibilityLabels.
pqTabbedMultiViewWidgetpqTabbedMultiViewWidget which is used to show multiple view layouts as tabs now supports filtering based on annotations specified on the underlying layout proxies. Checkout the TabbedMultiViewWidgetFilteringApp.cxx test to see how this can be used in custom applications for limiting the widget to only a subset of layouts.
Certain properties on a filter may not be relevant in all types of connections supported by ParaView and hence one may want to hide (or disable) such properties except when ParaView is in support session. This is now supported using pqSessionTypeDecorator.
ParaView now supports plugins that add to or replace the default context menu, via the pqContextMenuInterface class. The default ParaView context menu code has been moved out of pqPipelineContextMenuBehavior into pqDefaultContextMenu.
Context menu interface objects have a priority; when preparing a menu in response to user actions, the objects are sorted by descending priority. This allows plugins to place menu items relative to others (such as the default menu) as well as preempt all interfaces with lower priority by indicating (with their return value) that the behavior should stop iterating over context-menu interfaces.
There is an example in Examples/Plugins/ContextMenu and documentation in Utilities/Doxygen/pages/PluginHowto.md.
Settings JSON configuration files can now specify default scalar bar titles for arrays of specific names. In a settings JSON file, a <custom title>for <array name> can be specified with the following JSON structure:
Custom titles can only be read from JSON - this change does not include a mechanism to save custom titles from ParaView.
A new CMake option PARAVIEW_WINDOWS_PYTHON_DEBUGGABLE has been added. Turn this option ON to build ParaView on Windows with Python debug libraries.
The documentation about OpenGL options has been improved. In addition, CMake now checks which options are compatible with each other.
QString conversion to and from Utf8 bytesThe practice of converting QString data to a user's current locale has been replaced by an explicit conversion to UTF-8 encoding. This change integrates neatly with VTK's UTF-8 everywhere policy and is in line with Qt5 string handling, whereby C++ strings and char* are assumed to be UTF-8 encoded. Any legacy text files containing extended character sets should be saved as UTF-8 documents, in order to load them in the latest version of ParaView.
Loading paths and file names containing non-ASCII characters on Windows is now handled via the wide string API and uses vtksys for the utf8 <-> utf16 conversions. Thus the concept of converting text to the system's current locale has been completely eliminated.
ParaView no longer allows building kits with static builds. There are issues with in situ modules being able to reliably load Python in such configurations. However, the configuration does not make much sense in the first place since the goal of kits is to reduce the number of libraries that need to be loaded at runtime and static builds do not have this problem.
1.8.13 on Mon May 25 2026
