3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
10 cmake_policy(
VERSION 2.8.3...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS Prism::vtkPrismFilters Prism::vtkPrismViews Prism::vtkPrismServerManager Prism::vtkPrismReaders)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Create imported target Prism::vtkPrismFilters 50 add_library(Prism::vtkPrismFilters SHARED IMPORTED) 52 set_target_properties(Prism::vtkPrismFilters PROPERTIES 53 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Filters
" 54 INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel
") 58 target_sources(Prism::vtkPrismFilters 60 FILE_SET "vtk_module_templates
" 62 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters
" 67 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters
" 68 FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters/vtkPrismGeometryConverter.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters/vtkSimulationPointCloudFilter.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters/vtkSimulationToPrismFilter.h
" 72 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters
" 73 FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Filters/vtkPrismFiltersModule.h
" 76 set_property(TARGET Prism::vtkPrismFilters 77 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 78 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters
" 79 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters
" 80 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters
" 84 # Create imported target Prism::vtkPrismViews 85 add_library(Prism::vtkPrismViews SHARED IMPORTED) 87 set_target_properties(Prism::vtkPrismViews PROPERTIES 88 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Views;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Views;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Views
" 89 INTERFACE_LINK_LIBRARIES "ParaView::RemotingViews;VTK::CommonExecutionModel;VTK::PythonUsed
" 92 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 93 target_sources(Prism::vtkPrismViews 95 FILE_SET "vtk_module_templates
" 97 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views
" 100 FILE_SET "vtk_module_headers
" 102 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views
" 103 FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views/vtkPrismGeometryRepresentation.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views/vtkPrismGeometryRepresentationWithFaces.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views/vtkPrismSelectionRepresentation.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views/vtkPrismView.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views/vtkSMPrismViewProxy.h
" 105 FILE_SET "vtk_module_nowrap_headers
" 107 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views
" 108 FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Views/vtkPrismViewsModule.h
" 111 set_property(TARGET Prism::vtkPrismViews 112 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 113 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views
" 114 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views
" 115 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views
" 119 # Create imported target Prism::vtkPrismServerManager 120 add_library(Prism::vtkPrismServerManager SHARED IMPORTED) 122 set_target_properties(Prism::vtkPrismServerManager PROPERTIES 123 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager
" 124 INTERFACE_LINK_LIBRARIES "ParaView::RemotingServerManager;VTK::CommonExecutionModel;VTK::PythonUsed
" 127 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 128 target_sources(Prism::vtkPrismServerManager 130 FILE_SET "vtk_module_templates
" 132 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager
" 135 FILE_SET "vtk_module_headers
" 137 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager
" 138 FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager/vtkSMPrismIsSimulationDataDomain.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager/vtkSMPrismTableArraysDomain.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager/vtkSMPrismThresholdRangeDomain.h
" 140 FILE_SET "vtk_module_nowrap_headers
" 142 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager
" 143 FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager/vtkPrismServerManagerModule.h
" 146 set_property(TARGET Prism::vtkPrismServerManager 147 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 148 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager
" 149 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager
" 150 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager
" 154 # Create imported target Prism::vtkPrismReaders 155 add_library(Prism::vtkPrismReaders SHARED IMPORTED) 157 set_target_properties(Prism::vtkPrismReaders PROPERTIES 158 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Readers;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Readers;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers;/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Readers
" 159 INTERFACE_LINK_LIBRARIES "ParaView::VTKExtensionsIOCore;Prism::vtkPrismServerManager;VTK::CommonExecutionModel;VTK::PythonUsed
" 162 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 163 target_sources(Prism::vtkPrismReaders 165 FILE_SET "vtk_module_templates
" 167 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers
" 170 FILE_SET "vtk_module_headers
" 172 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers
" 173 FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers/vtkPrismSESAMEFileSeriesReader.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers/vtkPrismSESAMEReader.h
" 175 FILE_SET "vtk_module_nowrap_headers
" 177 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers
" 178 FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Readers/vtkPrismReadersModule.h
" 181 set_property(TARGET Prism::vtkPrismReaders 182 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 183 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers
" 184 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers
" 185 "/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers
" 189 # Import target "Prism::vtkPrismFilters
" for configuration "Release
" 190 set_property(TARGET Prism::vtkPrismFilters APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 191 set_target_properties(Prism::vtkPrismFilters PROPERTIES 192 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::FiltersCore;VTK::FiltersGeneral;VTK::fmt
" 193 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism/libvtkPrismFilters.so
" 194 IMPORTED_SONAME_RELEASE "libvtkPrismFilters.so
" 197 # Import target "Prism::vtkPrismViews
" 198 set_property(TARGET Prism::vtkPrismViews APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 199 set_target_properties(Prism::vtkPrismViews PROPERTIES 200 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingCore;Prism::vtkPrismFilters;VTK::CommonCore;VTK::CommonDataModel;VTK::FiltersExtraction;VTK::FiltersGeometry
" 201 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism/libvtkPrismViews.so
" 202 IMPORTED_SONAME_RELEASE "libvtkPrismViews.so
" 205 # Import target "Prism::vtkPrismServerManager
" 206 set_property(TARGET Prism::vtkPrismServerManager APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 207 set_target_properties(Prism::vtkPrismServerManager PROPERTIES 208 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingCore;VTK::CommonCore;VTK::CommonDataModel
" 209 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism/libvtkPrismServerManager.so
" 210 IMPORTED_SONAME_RELEASE "libvtkPrismServerManager.so
" 213 # Import target "Prism::vtkPrismReaders
" 214 set_property(TARGET Prism::vtkPrismReaders APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 215 set_target_properties(Prism::vtkPrismReaders PROPERTIES 216 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMisc;VTK::FiltersGeometry
" 217 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism/libvtkPrismReaders.so
" 218 IMPORTED_SONAME_RELEASE "libvtkPrismReaders.so
" 221 # Make sure the targets which have been exported in some other 223 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 224 foreach(_target "VTK::CommonExecutionModel
" "ParaView::RemotingViews
" "VTK::PythonUsed
" "ParaView::RemotingServerManager
" "ParaView::VTKExtensionsIOCore
" ) 225 if(NOT TARGET "${_target}
" ) 226 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 230 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 231 if(CMAKE_FIND_PACKAGE_NAME) 232 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 233 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 235 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 238 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 240 # Commands beyond this point should not need to know the version. 241 set(CMAKE_IMPORT_FILE_VERSION)
