ParaViewPythonIncubator-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "3.0.0")
7  message(FATAL_ERROR "CMake >= 3.0.0 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 3.0.0...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS ParaView::PyvtkPVIncubatorCorePython ParaView::pvincubatorpythonmodules)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Create imported target ParaView::PyvtkPVIncubatorCorePython
50 add_library(ParaView::PyvtkPVIncubatorCorePython MODULE IMPORTED)
51
52 # Create imported target ParaView::pvincubatorpythonmodules
53 add_library(ParaView::pvincubatorpythonmodules INTERFACE IMPORTED)
54
55 set_target_properties(ParaView::pvincubatorpythonmodules PROPERTIES
56  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/include/paraview-6.2/pvincubatorpythonmodules"
57  INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules"
58 )
59
60 # Import target "ParaView::PyvtkPVIncubatorCorePython" for configuration "Release"
61 set_property(TARGET ParaView::PyvtkPVIncubatorCorePython APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
62 set_target_properties(ParaView::PyvtkPVIncubatorCorePython PROPERTIES
63  IMPORTED_COMMON_LANGUAGE_RUNTIME_RELEASE ""
64  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.13/site-packages/paraview/incubator/vtkPVIncubatorCore.so"
65  IMPORTED_NO_SONAME_RELEASE "TRUE"
66  )
67
68 # Make sure the targets which have been exported in some other
69 # export set exist.
70 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
71 foreach(_target "VTK::vtkpythonmodules" )
72  if(NOT TARGET "${_target}" )
73  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
74  endif()
75 endforeach()
76
77 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
78  if(CMAKE_FIND_PACKAGE_NAME)
79  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
80  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
81  else()
82  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
83  endif()
84 endif()
85 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
86
87 # Commands beyond this point should not need to know the version.
88 set(CMAKE_IMPORT_FILE_VERSION)
89 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
