3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
6 if(CMAKE_VERSION VERSION_LESS "3.0.0")
7 message(FATAL_ERROR "CMake >= 3.0.0 required")
10 cmake_policy(
VERSION 3.0.0...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS ParaView::AdaptorsPython ParaView::Catalyst ParaView::vtkPVCatalyst-
private-kit-links ParaView::AdaptorsPhasta ParaView::AdaptorsParticle ParaView::PythonCatalyst ParaView::AdaptorsPagosa ParaView::AdaptorsNPIC ParaView::CatalystTestDriver ParaView::AdaptorsCam ParaView::AdaptorsCamPython ParaView::AdaptorsCTH ParaView::ClientsWeb ParaView::InSitu)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Create imported target ParaView::AdaptorsPython 50 add_library(ParaView::AdaptorsPython INTERFACE IMPORTED) 52 # Create imported target ParaView::Catalyst 53 add_library(ParaView::Catalyst SHARED IMPORTED) 55 set_target_properties(ParaView::Catalyst PROPERTIES 56 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/Fortran
" 57 INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::PythonUsed
" 60 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 61 target_sources(ParaView::Catalyst 63 FILE_SET "vtk_module_templates
" 65 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst
" 68 FILE_SET "vtk_module_headers
" 70 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst
" 71 FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/vtkCPConfig.h
" "/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/FortranAdaptorAPIMangling.h
" "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/CAdaptorAPI.h
vtkCPAdaptorAPI.h
vtkCPCxxHelper.h
vtkCPDataDescription.h
vtkCPInputDataDescription.h
vtkCPPipeline.h
vtkCPProcessor.h
vtkCPXMLPWriterPipeline.h
" "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/FortranAdaptorAPI.h
" 73 FILE_SET "vtk_module_nowrap_headers
" 75 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst
" 76 FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/vtkPVCatalystModule.h
" 79 set_property(TARGET ParaView::Catalyst 80 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 81 "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst
" 82 "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst
" 83 "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst
" 87 # Create imported target ParaView::vtkPVCatalyst-private-kit-links 88 add_library(ParaView::vtkPVCatalyst-private-kit-links INTERFACE IMPORTED) 90 set_target_properties(ParaView::vtkPVCatalyst-private-kit-links PROPERTIES 91 INTERFACE_LINK_LIBRARIES "\$<LINK_ONLY:ParaView::paraview_plugins>
" 94 # Create imported target ParaView::AdaptorsPhasta 95 add_library(ParaView::AdaptorsPhasta SHARED IMPORTED) 97 set_target_properties(ParaView::AdaptorsPhasta PROPERTIES 98 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Phasta;/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Phasta;/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Phasta
" 99 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonCore;VTK::CommonDataModel;VTK::PythonUsed
" 102 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 103 target_sources(ParaView::AdaptorsPhasta 105 FILE_SET "vtk_module_templates
" 107 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta
" 110 FILE_SET "vtk_module_headers
" 112 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta
" 113 FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta/PhastaAdaptor.h
" 115 FILE_SET "vtk_module_nowrap_headers
" 117 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta
" 118 FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Phasta/vtkPVAdaptorsPhastaModule.h
" 121 set_property(TARGET ParaView::AdaptorsPhasta 122 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 123 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta
" 124 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta
" 125 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta
" 129 # Create imported target ParaView::AdaptorsParticle 130 add_library(ParaView::AdaptorsParticle SHARED IMPORTED) 132 set_target_properties(ParaView::AdaptorsParticle PROPERTIES 133 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Particle;/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Particle;/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Particle
" 134 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::RemotingViews;VTK::CommonCore;VTK::CommonDataModel;VTK::IOImage;VTK::IOParallelXML;VTK::ParallelMPI;VTK::RenderingCore;VTK::RenderingOpenGL2;VTK::PythonUsed
" 137 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 138 target_sources(ParaView::AdaptorsParticle 140 FILE_SET "vtk_module_templates
" 142 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle
" 145 FILE_SET "vtk_module_headers
" 147 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle
" 148 FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle/ParticleAdaptor.h
" "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle/
vtkParticlePipeline.h
" 150 FILE_SET "vtk_module_nowrap_headers
" 152 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle
" 153 FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Particle/vtkPVAdaptorsParticleModule.h
" 156 set_property(TARGET ParaView::AdaptorsParticle 157 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 158 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle
" 159 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle
" 160 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle
" 164 # Create imported target ParaView::PythonCatalyst 165 add_library(ParaView::PythonCatalyst SHARED IMPORTED) 167 set_target_properties(ParaView::PythonCatalyst PROPERTIES 168 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst/Fortran
" 169 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::PythonInterpreter;ParaView::PythonInterpreterPath;VTK::PythonUsed
" 172 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 173 target_sources(ParaView::PythonCatalyst 175 FILE_SET "vtk_module_templates
" 177 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst
" 180 FILE_SET "vtk_module_headers
" 182 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst
" 183 FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst/FortranPythonAdaptorAPIMangling.h
" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/CPythonAdaptorAPI.h
vtkCPPythonAdaptorAPI.h
vtkCPPythonPipeline.h
vtkCPPythonScriptPipeline.h
vtkCPPythonScriptV2Helper.h
vtkCPPythonScriptV2Pipeline.h
vtkCPPythonStringPipeline.h
" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/FortranPythonAdaptorAPI.h
" 185 FILE_SET "vtk_module_nowrap_headers
" 187 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst
" 188 FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst/vtkPVPythonCatalystModule.h
" 191 set_property(TARGET ParaView::PythonCatalyst 192 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 193 "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst
" 194 "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst
" 195 "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst
" 199 # Create imported target ParaView::AdaptorsPagosa 200 add_library(ParaView::AdaptorsPagosa SHARED IMPORTED) 202 set_target_properties(ParaView::AdaptorsPagosa PROPERTIES 203 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Pagosa;/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Pagosa;/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Pagosa
" 204 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonDataModel;VTK::PythonUsed
" 207 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 208 target_sources(ParaView::AdaptorsPagosa 210 FILE_SET "vtk_module_templates
" 212 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa
" 215 FILE_SET "vtk_module_headers
" 217 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa
" 220 FILE_SET "vtk_module_nowrap_headers
" 222 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa
" 223 FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Pagosa/vtkPVAdaptorsPagosaModule.h
" 226 set_property(TARGET ParaView::AdaptorsPagosa 227 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 228 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa
" 229 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa
" 230 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa
" 234 # Create imported target ParaView::AdaptorsNPIC 235 add_library(ParaView::AdaptorsNPIC SHARED IMPORTED) 237 set_target_properties(ParaView::AdaptorsNPIC PROPERTIES 238 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/NPIC;/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/NPIC;/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/NPIC
" 239 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonDataModel;VTK::CommonCore;VTK::ParallelMPI;VTK::PythonUsed
" 242 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 243 target_sources(ParaView::AdaptorsNPIC 245 FILE_SET "vtk_module_templates
" 247 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC
" 250 FILE_SET "vtk_module_headers
" 252 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC
" 253 FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC/NPICAdaptor.h
" 255 FILE_SET "vtk_module_nowrap_headers
" 257 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC
" 258 FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/NPIC/vtkPVAdaptorsNPICModule.h
" 261 set_property(TARGET ParaView::AdaptorsNPIC 262 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 263 "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC
" 264 "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC
" 265 "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC
" 269 # Create imported target ParaView::CatalystTestDriver 270 add_library(ParaView::CatalystTestDriver SHARED IMPORTED) 272 set_target_properties(ParaView::CatalystTestDriver PROPERTIES 273 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver;/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver;/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver
" 274 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::PythonUsed
" 277 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 278 target_sources(ParaView::CatalystTestDriver 280 FILE_SET "vtk_module_templates
" 282 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver
" 285 FILE_SET "vtk_module_headers
" 287 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver
" 290 FILE_SET "vtk_module_nowrap_headers
" 292 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver
" 293 FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver/vtkPVCatalystTestDriverModule.h
" 296 set_property(TARGET ParaView::CatalystTestDriver 297 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 298 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver
" 299 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver
" 300 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver
" 304 # Create imported target ParaView::AdaptorsCam 305 add_library(ParaView::AdaptorsCam SHARED IMPORTED) 307 set_target_properties(ParaView::AdaptorsCam PROPERTIES 308 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Cam;/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Cam;/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Cam
" 309 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::PythonCatalyst;VTK::CommonDataModel;VTK::CommonCore;VTK::PythonUsed
" 312 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 313 target_sources(ParaView::AdaptorsCam 315 FILE_SET "vtk_module_templates
" 317 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam
" 318 FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/Grid.txx
" 320 FILE_SET "vtk_module_headers
" 322 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam
" 323 FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/fv_create_data.h
" "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/se_create_data.h
" "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/Grid.h
" 325 FILE_SET "vtk_module_nowrap_headers
" 327 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam
" 328 FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Cam/vtkPVAdaptorsCamModule.h
" 331 set_property(TARGET ParaView::AdaptorsCam 332 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 333 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam
" 334 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam
" 335 "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam
" 339 # Create imported target ParaView::AdaptorsCamPython 340 add_library(ParaView::AdaptorsCamPython INTERFACE IMPORTED) 342 set_target_properties(ParaView::AdaptorsCamPython PROPERTIES 343 INTERFACE_LINK_LIBRARIES "ParaView::AdaptorsCam
" 346 # Create imported target ParaView::AdaptorsCTH 347 add_library(ParaView::AdaptorsCTH SHARED IMPORTED) 349 set_target_properties(ParaView::AdaptorsCTH PROPERTIES 350 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CTH;/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CTH;/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CTH
" 351 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::PythonCatalyst;ParaView::Versioning;VTK::CommonCore;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::ParallelMPI;VTK::PythonUsed
" 354 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 355 target_sources(ParaView::AdaptorsCTH 357 FILE_SET "vtk_module_templates
" 359 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH
" 362 FILE_SET "vtk_module_headers
" 364 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH
" 365 FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH/CTHAdaptor.h
" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH/
vtkCTHSource.h
vtkCTHDataArray.h
" 367 FILE_SET "vtk_module_nowrap_headers
" 369 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH
" 370 FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CTH/vtkPVAdaptorsCTHModule.h
" 373 set_property(TARGET ParaView::AdaptorsCTH 374 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 375 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH
" 376 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH
" 377 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH
" 381 # Create imported target ParaView::ClientsWeb 382 add_library(ParaView::ClientsWeb SHARED IMPORTED) 384 set_target_properties(ParaView::ClientsWeb PROPERTIES 385 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Clients/Web;/builds/gitlab-kitware-sciviz-ci/build/Clients/Web;/builds/gitlab-kitware-sciviz-ci/Clients/Web;/builds/gitlab-kitware-sciviz-ci/build/Clients/Web;/builds/gitlab-kitware-sciviz-ci/Clients/Web;/builds/gitlab-kitware-sciviz-ci/build/Clients/Web
" 386 INTERFACE_LINK_LIBRARIES "VTK::WebCore;VTK::WebGLExporter;VTK::PythonUsed
" 389 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 390 target_sources(ParaView::ClientsWeb 392 FILE_SET "vtk_module_templates
" 394 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Web
" 397 FILE_SET "vtk_module_headers
" 399 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Web
" 402 FILE_SET "vtk_module_nowrap_headers
" 404 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Web
" 405 FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/Web/vtkPVClientWebModule.h
" 408 set_property(TARGET ParaView::ClientsWeb 409 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 410 "/builds/gitlab-kitware-sciviz-ci/Clients/Web
" 411 "/builds/gitlab-kitware-sciviz-ci/Clients/Web
" 412 "/builds/gitlab-kitware-sciviz-ci/Clients/Web
" 416 # Create imported target ParaView::InSitu 417 add_library(ParaView::InSitu SHARED IMPORTED) 419 set_target_properties(ParaView::InSitu PROPERTIES 420 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu;/builds/gitlab-kitware-sciviz-ci/build/Clients/InSitu;/builds/gitlab-kitware-sciviz-ci/Clients/InSitu;/builds/gitlab-kitware-sciviz-ci/build/Clients/InSitu;/builds/gitlab-kitware-sciviz-ci/Clients/InSitu;/builds/gitlab-kitware-sciviz-ci/build/Clients/InSitu
" 421 INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::PythonUsed
" 424 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 425 target_sources(ParaView::InSitu 427 FILE_SET "vtk_module_templates
" 429 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu
" 432 FILE_SET "vtk_module_headers
" 434 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu
" 437 FILE_SET "vtk_module_nowrap_headers
" 439 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu
" 440 FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/InSitu/vtkPVInSituModule.h
" 443 set_property(TARGET ParaView::InSitu 444 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 445 "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu
" 446 "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu
" 447 "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu
" 451 # Import target "ParaView::Catalyst
" for configuration "Release
" 452 set_property(TARGET ParaView::Catalyst APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 453 set_target_properties(ParaView::Catalyst PROPERTIES 454 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingApplication;VTK::FiltersGeneral;VTK::FiltersHybrid;VTK::vtksys;VTK::ParallelMPI
" 455 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalyst-pv6.2.so.6.2
" 456 IMPORTED_SONAME_RELEASE "libvtkPVCatalyst-pv6.2.so.1
" 459 # Import target "ParaView::AdaptorsPhasta
" 460 set_property(TARGET ParaView::AdaptorsPhasta APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 461 set_target_properties(ParaView::AdaptorsPhasta PROPERTIES 462 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::ParallelMPI
" 463 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPhasta-pv6.2.so.6.2
" 464 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsPhasta-pv6.2.so.1
" 467 # Import target "ParaView::AdaptorsParticle
" 468 set_property(TARGET ParaView::AdaptorsParticle APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 469 set_target_properties(ParaView::AdaptorsParticle PROPERTIES 470 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsParticle-pv6.2.so.6.2
" 471 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsParticle-pv6.2.so.1
" 474 # Import target "ParaView::PythonCatalyst
" 475 set_property(TARGET ParaView::PythonCatalyst APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 476 set_target_properties(ParaView::PythonCatalyst PROPERTIES 477 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::PythonInitializer;ParaView::RemotingServerManager;ParaView::VTKExtensionsCore;VTK::ParallelCore;VTK::WrappingPythonCore;ParaView::RemotingLive
" 478 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVPythonCatalyst-pv6.2.so.6.2
" 479 IMPORTED_SONAME_RELEASE "libvtkPVPythonCatalyst-pv6.2.so.1
" 482 # Import target "ParaView::AdaptorsPagosa
" 483 set_property(TARGET ParaView::AdaptorsPagosa APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 484 set_target_properties(ParaView::AdaptorsPagosa PROPERTIES 485 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::PythonCatalyst;VTK::ParallelMPI
" 486 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPagosa-pv6.2.so.6.2
" 487 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsPagosa-pv6.2.so.1
" 490 # Import target "ParaView::AdaptorsNPIC
" 491 set_property(TARGET ParaView::AdaptorsNPIC APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 492 set_target_properties(ParaView::AdaptorsNPIC PROPERTIES 493 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsNPIC-pv6.2.so.6.2
" 494 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsNPIC-pv6.2.so.1
" 497 # Import target "ParaView::CatalystTestDriver
" 498 set_property(TARGET ParaView::CatalystTestDriver APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 499 set_target_properties(ParaView::CatalystTestDriver PROPERTIES 500 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonDataModel;VTK::ParallelCore
" 501 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalystTestDriver-pv6.2.so.6.2
" 502 IMPORTED_SONAME_RELEASE "libvtkPVCatalystTestDriver-pv6.2.so.1
" 505 # Import target "ParaView::AdaptorsCam
" 506 set_property(TARGET ParaView::AdaptorsCam APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 507 set_target_properties(ParaView::AdaptorsCam PROPERTIES 508 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCam-pv6.2.so.6.2
" 509 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsCam-pv6.2.so.1
" 512 # Import target "ParaView::AdaptorsCTH
" 513 set_property(TARGET ParaView::AdaptorsCTH APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 514 set_target_properties(ParaView::AdaptorsCTH PROPERTIES 515 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCTH-pv6.2.so.6.2
" 516 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsCTH-pv6.2.so.1
" 519 # Import target "ParaView::ClientsWeb
" 520 set_property(TARGET ParaView::ClientsWeb APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 521 set_target_properties(ParaView::ClientsWeb PROPERTIES 522 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingApplication;ParaView::RemotingViews;VTK::CommonSystem
" 523 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVClientWeb-pv6.2.so.6.2
" 524 IMPORTED_SONAME_RELEASE "libvtkPVClientWeb-pv6.2.so.1
" 527 # Import target "ParaView::InSitu
" 528 set_property(TARGET ParaView::InSitu APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 529 set_target_properties(ParaView::InSitu PROPERTIES 530 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::Catalyst;ParaView::RemotingApplication;ParaView::RemotingLive;ParaView::VTKExtensionsCore;ParaView::PythonCatalyst;ParaView::PythonInitializer;VTK::IOCatalystConduit;VTK::ParallelMPI;VTK::WrappingPythonCore
" 531 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVInSitu-pv6.2.so.6.2
" 532 IMPORTED_SONAME_RELEASE "libvtkPVInSitu-pv6.2.so.1
" 535 # Make sure the targets which have been exported in some other 537 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 538 foreach(_target "VTK::CommonCore
" "VTK::PythonUsed
" "ParaView::paraview_plugins
" "VTK::CommonDataModel
" "ParaView::RemotingViews
" "VTK::IOImage
" "VTK::IOParallelXML
" "VTK::ParallelMPI
" "VTK::RenderingCore
" "VTK::RenderingOpenGL2
" "VTK::PythonInterpreter
" "ParaView::PythonInterpreterPath
" "ParaView::Versioning
" "VTK::CommonExecutionModel
" "VTK::WebCore
" "VTK::WebGLExporter
" ) 539 if(NOT TARGET "${_target}
" ) 540 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 544 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 545 if(CMAKE_FIND_PACKAGE_NAME) 546 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 547 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 549 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 552 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 554 # Commands beyond this point should not need to know the version. 555 set(CMAKE_IMPORT_FILE_VERSION) Class for specifying constant scalars at points.
Abstract class for specifying tensor fields at points.
Class for specifying nodal fields over grids.
vtkCPAdaptorAPI provides the implementation for API exposed to typical adaptor, such as C...
Class for specifying cell fields over grids.
vtkCPPipeline for Catalyst Python script / package version 2.0
Class that creates a coprocessing pipeline from a coprocessing string.
Abstract class for creating grids.
Class for creating multiblock grids.
an internal class encapsulating logic for Catalyst Python scripts.
defines ParaViewWeb application interface.
Similar to vtkCPAdaptorAPI provides the implementation for API exposed to typical adaptor...
Generic PXML writer pipeline to write out the full Catalyst input datasets.
Class for creating a co-processor test driver.
Singleton class for initializing without python.
Abstract class that takes care of initializing Catalyst Python pipelines for all concrete implementat...
initialization helper for in situ environments.
There are 3 distinct phases for the operation of a co-processor.
Abstract class for specifying vectors at points.
subclass for Python in situ scripts.
Generic interface for operating on pipelines.
Abstract class for specifying scalars at points.
Abstract class for specifying fields over grids.
A helper class to get the conduit node stored during the execution of one of the catalyst* calls as a...
Class for specifying scalars at points.
Class that creates a coprocessing pipeline starting from a coprocessing script.
abstract base class for all in situ pipelines.
Class for creating grids from a VTK file.
This class provides the description of the data for the coprocessor pipelines.
Class for creating unstructured grids.
