3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
10 cmake_policy(
VERSION 2.8.3...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS ParFlow::ParFlowIO)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Create imported target ParFlow::ParFlowIO 50 add_library(ParFlow::ParFlowIO SHARED IMPORTED) 52 set_target_properties(ParFlow::ParFlowIO PROPERTIES 53 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO;/builds/gitlab-kitware-sciviz-ci/build/Plugins/ParFlow/IO;/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO;/builds/gitlab-kitware-sciviz-ci/build/Plugins/ParFlow/IO;/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO;/builds/gitlab-kitware-sciviz-ci/build/Plugins/ParFlow/IO
" 54 INTERFACE_LINK_LIBRARIES "VTK::nlohmannjson;VTK::CommonCore;VTK::CommonMath;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::ParallelCore
") 58 target_sources(ParFlow::ParFlowIO 60 FILE_SET "vtk_module_templates
" 62 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO
" 67 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO
" 68 FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO/vtkParFlowReader.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO/vtkParFlowMetaReader.h
" 72 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO
" 73 FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/ParFlow/IO/vtkParFlowIOModule.h
" 76 set_property(TARGET ParFlow::ParFlowIO 77 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 78 "/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO
" 79 "/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO
" 80 "/builds/gitlab-kitware-sciviz-ci/Plugins/ParFlow/IO
" 84 # Import target "ParFlow::ParFlowIO
" for configuration "Release
" 85 set_property(TARGET ParFlow::ParFlowIO APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 86 set_target_properties(ParFlow::ParFlowIO PROPERTIES 87 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/ParFlow/libvtkParFlowIO.so
" 88 IMPORTED_SONAME_RELEASE "libvtkParFlowIO.so
" 91 # Make sure the targets which have been exported in some other 93 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 94 foreach(_target "VTK::nlohmannjson
" "VTK::CommonCore
" "VTK::CommonMath
" "VTK::CommonDataModel
" "VTK::CommonExecutionModel
" "VTK::ParallelCore
" ) 95 if(NOT TARGET "${_target}
" ) 96 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 100 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 101 if(CMAKE_FIND_PACKAGE_NAME) 102 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 103 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 105 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 108 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 110 # Commands beyond this point should not need to know the version. 111 set(CMAKE_IMPORT_FILE_VERSION)
