3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
10 cmake_policy(
VERSION 2.8.3...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS NonOrthogonalSource::vtkNonOrthogonalSources)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Create imported target NonOrthogonalSource::vtkNonOrthogonalSources 50 add_library(NonOrthogonalSource::vtkNonOrthogonalSources SHARED IMPORTED) 52 set_target_properties(NonOrthogonalSource::vtkNonOrthogonalSources PROPERTIES 53 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources;/builds/gitlab-kitware-sciviz-ci/build/Plugins/NonOrthogonalSource/Sources;/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources;/builds/gitlab-kitware-sciviz-ci/build/Plugins/NonOrthogonalSource/Sources;/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources;/builds/gitlab-kitware-sciviz-ci/build/Plugins/NonOrthogonalSource/Sources
" 54 INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel;VTK::PythonUsed
") 58 target_sources(NonOrthogonalSource::vtkNonOrthogonalSources 60 FILE_SET "vtk_module_templates
" 62 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources
" 67 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources
" 68 FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources/vtkShearedWaveletSource.h
" 72 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources
" 73 FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/NonOrthogonalSource/Sources/vtkNonOrthogonalSourcesModule.h
" 76 set_property(TARGET NonOrthogonalSource::vtkNonOrthogonalSources 77 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 78 "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources
" 79 "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources
" 80 "/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources
" 84 # Import target "NonOrthogonalSource::vtkNonOrthogonalSources
" for configuration "Release
" 85 set_property(TARGET NonOrthogonalSource::vtkNonOrthogonalSources APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 86 set_target_properties(NonOrthogonalSource::vtkNonOrthogonalSources PROPERTIES 87 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::VTKExtensionsMisc;VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMath;VTK::CommonTransforms;VTK::FiltersGeneral;VTK::ImagingCore
" 88 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/NonOrthogonalSource/libvtkNonOrthogonalSources.so
" 89 IMPORTED_SONAME_RELEASE "libvtkNonOrthogonalSources.so
" 92 # Make sure the targets which have been exported in some other 94 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 95 foreach(_target "VTK::CommonExecutionModel
" "VTK::PythonUsed
" ) 96 if(NOT TARGET "${_target}
" ) 97 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 101 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 102 if(CMAKE_FIND_PACKAGE_NAME) 103 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 104 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 106 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 109 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 111 # Commands beyond this point should not need to know the version. 112 set(CMAKE_IMPORT_FILE_VERSION)
