LegacyGhostCellsGenerator-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.3")
7  message(FATAL_ERROR "CMake >= 2.8.3 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.3...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS LegacyGhostCellsGeneratorFilters LegacyGhostCellsGeneratorParallel)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Create imported target LegacyGhostCellsGeneratorFilters
50 add_library(LegacyGhostCellsGeneratorFilters SHARED IMPORTED)
51
52 set_target_properties(LegacyGhostCellsGeneratorFilters PROPERTIES
53  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Filters"
54  INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel"
55 )
56
57 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
58  target_sources(LegacyGhostCellsGeneratorFilters
59  INTERFACE
60  FILE_SET "vtk_module_templates"
61  TYPE "HEADERS"
62  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters"
63  FILES
64  INTERFACE
65  FILE_SET "vtk_module_headers"
66  TYPE "HEADERS"
67  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters"
68  FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters/vtkUnstructuredGridGhostCellsGenerator.h"
69  INTERFACE
70  FILE_SET "vtk_module_nowrap_headers"
71  TYPE "HEADERS"
72  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters"
73  FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Filters/LegacyGhostCellsGeneratorFiltersModule.h"
74  )
75 else()
76  set_property(TARGET LegacyGhostCellsGeneratorFilters
77  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
78  "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters"
79  "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters"
80  "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters"
81  )
82 endif()
83
84 # Create imported target LegacyGhostCellsGeneratorParallel
85 add_library(LegacyGhostCellsGeneratorParallel SHARED IMPORTED)
86
87 set_target_properties(LegacyGhostCellsGeneratorParallel PROPERTIES
88  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel;/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel;/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel"
89  INTERFACE_LINK_LIBRARIES "LegacyGhostCellsGeneratorFilters;VTK::CommonExecutionModel;VTK::CommonSystem;VTK::FiltersCore;VTK::FiltersGeneral;VTK::FiltersGeometry;VTK::ParallelMPI"
90 )
91
92 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
93  target_sources(LegacyGhostCellsGeneratorParallel
94  INTERFACE
95  FILE_SET "vtk_module_templates"
96  TYPE "HEADERS"
97  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel"
98  FILES
99  INTERFACE
100  FILE_SET "vtk_module_headers"
101  TYPE "HEADERS"
102  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel"
103  FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel/vtkPUnstructuredGridGhostCellsGenerator.h"
104  INTERFACE
105  FILE_SET "vtk_module_nowrap_headers"
106  TYPE "HEADERS"
107  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel"
108  FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel/LegacyGhostCellsGeneratorParallelModule.h"
109  )
110 else()
111  set_property(TARGET LegacyGhostCellsGeneratorParallel
112  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
113  "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel"
114  "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel"
115  "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel"
116  )
117 endif()
118
119 # Import target "LegacyGhostCellsGeneratorFilters" for configuration "Release"
120 set_property(TARGET LegacyGhostCellsGeneratorFilters APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
121 set_target_properties(LegacyGhostCellsGeneratorFilters PROPERTIES
122  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMisc;VTK::ParallelCore"
123  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorFilters.so"
124  IMPORTED_SONAME_RELEASE "libLegacyGhostCellsGeneratorFilters.so"
125  )
126
127 # Import target "LegacyGhostCellsGeneratorParallel" for configuration "Release"
128 set_property(TARGET LegacyGhostCellsGeneratorParallel APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
129 set_target_properties(LegacyGhostCellsGeneratorParallel PROPERTIES
130  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMisc;VTK::ParallelCore"
131  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorParallel.so"
132  IMPORTED_SONAME_RELEASE "libLegacyGhostCellsGeneratorParallel.so"
133  )
134
135 # Make sure the targets which have been exported in some other
136 # export set exist.
137 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
138 foreach(_target "VTK::CommonExecutionModel" "VTK::CommonSystem" "VTK::FiltersCore" "VTK::FiltersGeneral" "VTK::FiltersGeometry" "VTK::ParallelMPI" )
139  if(NOT TARGET "${_target}" )
140  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
141  endif()
142 endforeach()
143
144 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
145  if(CMAKE_FIND_PACKAGE_NAME)
146  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
147  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
148  else()
149  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
150  endif()
151 endif()
152 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
153
154 # Commands beyond this point should not need to know the version.
155 set(CMAKE_IMPORT_FILE_VERSION)
156 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
