3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
10 cmake_policy(
VERSION 2.8.3...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS DigitalSignalProcessing::DSPDataModel DigitalSignalProcessing::DSPFiltersPlugin)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Create imported target DigitalSignalProcessing::DSPDataModel 50 add_library(DigitalSignalProcessing::DSPDataModel STATIC IMPORTED) 52 set_target_properties(DigitalSignalProcessing::DSPDataModel PROPERTIES 53 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel
" 54 INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonExecutionModel;\$<LINK_ONLY:VTK::CommonDataModel>
") 58 target_sources(DigitalSignalProcessing::DSPDataModel 60 FILE_SET "vtk_module_templates
" 62 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel
" 67 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel
" 72 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel
" 73 FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkArrayDispatchDSPArrayList.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkMultiDimensionalArray.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel/vtkMultiDimensionalImplicitBackend.h
" "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel/vtkDSPDataModelModule.h
" 76 set_property(TARGET DigitalSignalProcessing::DSPDataModel 77 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 78 "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel
" 79 "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel
" 80 "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel
" 84 # Create imported target DigitalSignalProcessing::DSPFiltersPlugin 85 add_library(DigitalSignalProcessing::DSPFiltersPlugin STATIC IMPORTED) 87 set_target_properties(DigitalSignalProcessing::DSPFiltersPlugin PROPERTIES 88 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters
" 89 INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::FiltersGeneral;\$<LINK_ONLY:DigitalSignalProcessing::DSPDataModel>;\$<LINK_ONLY:VTK::FiltersCore>;\$<LINK_ONLY:VTK::FiltersExtraction>;\$<LINK_ONLY:VTK::ParallelCore>
" 92 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0
") 93 target_sources(DigitalSignalProcessing::DSPFiltersPlugin 95 FILE_SET "vtk_module_templates
" 97 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters
" 100 FILE_SET "vtk_module_headers
" 102 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters
" 103 FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkAccousticUtilities.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkBandFiltering.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkDSPTableFFT.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkMeanPowerSpectralDensity.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkMergeReduceTables.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkMultiDimensionBrowser.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkProjectSpectrumMagnitude.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkSoundQuantitiesCalculator.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkSpectrogramFilter.h
" "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters/vtkTemporalMultiplexing.h
" 105 FILE_SET "vtk_module_nowrap_headers
" 107 BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters
" 108 FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters/vtkDSPFiltersPluginModule.h
" 111 set_property(TARGET DigitalSignalProcessing::DSPFiltersPlugin 112 APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES 113 "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters
" 114 "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters
" 115 "/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters
" 119 # Import target "DigitalSignalProcessing::DSPDataModel
" for configuration "Release
" 120 set_property(TARGET DigitalSignalProcessing::DSPDataModel APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 121 set_target_properties(DigitalSignalProcessing::DSPDataModel PROPERTIES 122 IMPORTED_LINK_INTERFACE_LANGUAGES_RELEASE "CXX
" 123 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/DigitalSignalProcessing/libvtkDSPDataModel.a
" 126 # Import target "DigitalSignalProcessing::DSPFiltersPlugin
" 127 set_property(TARGET DigitalSignalProcessing::DSPFiltersPlugin APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 128 set_target_properties(DigitalSignalProcessing::DSPFiltersPlugin PROPERTIES 129 IMPORTED_LINK_INTERFACE_LANGUAGES_RELEASE "CXX
" 130 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/DigitalSignalProcessing/libvtkDSPFiltersPlugin.a
" 133 # Make sure the targets which have been exported in some other 135 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 136 foreach(_target "VTK::CommonCore
" "VTK::CommonExecutionModel
" "VTK::CommonDataModel
" "VTK::FiltersGeneral
" "VTK::FiltersCore
" "VTK::FiltersExtraction
" "VTK::ParallelCore
" ) 137 if(NOT TARGET "${_target}
" ) 138 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 142 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 143 if(CMAKE_FIND_PACKAGE_NAME) 144 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 145 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 147 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 150 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 152 # Commands beyond this point should not need to know the version. 153 set(CMAKE_IMPORT_FILE_VERSION)
