BivariateRepresentations-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "2.8.3")
7  message(FATAL_ERROR "CMake >= 2.8.3 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 2.8.3...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS BivariateRepresentations::vtkBivariateRepresentations)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Create imported target BivariateRepresentations::vtkBivariateRepresentations
50 add_library(BivariateRepresentations::vtkBivariateRepresentations STATIC IMPORTED)
51
52 set_target_properties(BivariateRepresentations::vtkBivariateRepresentations PROPERTIES
53  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations;/builds/gitlab-kitware-sciviz-ci/build/Plugins/BivariateRepresentations/Representations;/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations;/builds/gitlab-kitware-sciviz-ci/build/Plugins/BivariateRepresentations/Representations;/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations;/builds/gitlab-kitware-sciviz-ci/build/Plugins/BivariateRepresentations/Representations"
54  INTERFACE_LINK_LIBRARIES "ParaView::RemotingViews;VTK::RenderingOpenGL2;\$<LINK_ONLY:ParaView::RemotingMisc>;\$<LINK_ONLY:ParaView::VTKExtensionsFiltersRendering>;\$<LINK_ONLY:VTK::CommonCore>;\$<LINK_ONLY:VTK::RenderingContextOpenGL2>;VTK::PythonUsed"
55 )
56
57 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
58  target_sources(BivariateRepresentations::vtkBivariateRepresentations
59  INTERFACE
60  FILE_SET "vtk_module_templates"
61  TYPE "HEADERS"
62  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations"
63  FILES
64  INTERFACE
65  FILE_SET "vtk_module_headers"
66  TYPE "HEADERS"
67  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations"
68  FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkBivariateNoiseMapper.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkBivariateNoiseRepresentation.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkBivariateTextureRepresentation.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkContext2DTexturedScalarBarActor.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkContext2DTexturedScalarBarRepresentation.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkSMBivariateTextureRepresentationProxy.h" "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkOpenGLBivariateNoiseMapperDelegator.h"
69  INTERFACE
70  FILE_SET "vtk_module_nowrap_headers"
71  TYPE "HEADERS"
72  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations"
73  FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/BivariateRepresentations/Representations/vtkBivariateRepresentationsModule.h"
74  )
75 else()
76  set_property(TARGET BivariateRepresentations::vtkBivariateRepresentations
77  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
78  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations"
79  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations"
80  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations"
81  )
82 endif()
83
84 # Import target "BivariateRepresentations::vtkBivariateRepresentations" for configuration "Release"
85 set_property(TARGET BivariateRepresentations::vtkBivariateRepresentations APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
86 set_target_properties(BivariateRepresentations::vtkBivariateRepresentations PROPERTIES
87  IMPORTED_LINK_INTERFACE_LANGUAGES_RELEASE "CXX"
88  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/BivariateRepresentations/libvtkBivariateRepresentations.a"
89  )
90
91 # Make sure the targets which have been exported in some other
92 # export set exist.
93 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
94 foreach(_target "ParaView::RemotingViews" "VTK::RenderingOpenGL2" "ParaView::RemotingMisc" "ParaView::VTKExtensionsFiltersRendering" "VTK::CommonCore" "VTK::RenderingContextOpenGL2" "VTK::PythonUsed" )
95  if(NOT TARGET "${_target}" )
96  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
97  endif()
98 endforeach()
99
100 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
101  if(CMAKE_FIND_PACKAGE_NAME)
102  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
103  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
104  else()
105  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
106  endif()
107 endif()
108 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
109
110 # Commands beyond this point should not need to know the version.
111 set(CMAKE_IMPORT_FILE_VERSION)
112 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
