ParaViewClients-targets.cmake
1 # Generated by CMake
5 endif()
6 if(CMAKE_VERSION VERSION_LESS "3.0.0")
7  message(FATAL_ERROR "CMake >= 3.0.0 required")
8 endif()
9 cmake_policy(PUSH)
10 cmake_policy(VERSION 3.0.0...3.27)
14
17
22 foreach(_cmake_expected_target IN ITEMS ParaView::AdaptorsPython ParaView::Catalyst ParaView::Catalyst-private-kit-links ParaView::AdaptorsPhasta ParaView::AdaptorsParticle ParaView::PythonCatalyst ParaView::AdaptorsPagosa ParaView::AdaptorsNPIC ParaView::CatalystTestDriver ParaView::AdaptorsCam ParaView::AdaptorsCamPython ParaView::AdaptorsCTH ParaView::ClientsWeb ParaView::InSitu)
26  else()
28  endif()
29 endforeach()
36  cmake_policy(POP)
37  return()
47
48
49 # Create imported target ParaView::AdaptorsPython
50 add_library(ParaView::AdaptorsPython INTERFACE IMPORTED)
51
52 # Create imported target ParaView::Catalyst
53 add_library(ParaView::Catalyst SHARED IMPORTED)
54
55 set_target_properties(ParaView::Catalyst PROPERTIES
56  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/Fortran"
57  INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::PythonUsed"
58 )
59
60 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
61  target_sources(ParaView::Catalyst
62  INTERFACE
63  FILE_SET "vtk_module_templates"
64  TYPE "HEADERS"
65  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst"
66  FILES
67  INTERFACE
68  FILE_SET "vtk_module_headers"
69  TYPE "HEADERS"
70  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst"
71  FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/vtkCPConfig.h" "/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/FortranAdaptorAPIMangling.h" "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/CAdaptorAPI.h" "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPAdaptorAPI.h" "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPCxxHelper.h" "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPDataDescription.h" "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPInputDataDescription.h" "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPPipeline.h" "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPProcessor.h" "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPXMLPWriterPipeline.h" "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/FortranAdaptorAPI.h"
72  INTERFACE
73  FILE_SET "vtk_module_nowrap_headers"
74  TYPE "HEADERS"
75  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst"
76  FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/vtkPVCatalystModule.h"
77  )
78 else()
79  set_property(TARGET ParaView::Catalyst
80  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
81  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst"
82  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst"
83  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst"
84  )
85 endif()
86
87 # Create imported target ParaView::Catalyst-private-kit-links
88 add_library(ParaView::Catalyst-private-kit-links INTERFACE IMPORTED)
89
90 set_target_properties(ParaView::Catalyst-private-kit-links PROPERTIES
91  INTERFACE_LINK_LIBRARIES "\$<LINK_ONLY:ParaView::paraview_plugins>"
92 )
93
94 # Create imported target ParaView::AdaptorsPhasta
95 add_library(ParaView::AdaptorsPhasta SHARED IMPORTED)
96
97 set_target_properties(ParaView::AdaptorsPhasta PROPERTIES
98  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Phasta;/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Phasta;/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Phasta"
99  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonCore;VTK::CommonDataModel;VTK::PythonUsed"
100 )
101
102 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
103  target_sources(ParaView::AdaptorsPhasta
104  INTERFACE
105  FILE_SET "vtk_module_templates"
106  TYPE "HEADERS"
107  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta"
108  FILES
109  INTERFACE
110  FILE_SET "vtk_module_headers"
111  TYPE "HEADERS"
112  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta"
113  FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta/PhastaAdaptor.h"
114  INTERFACE
115  FILE_SET "vtk_module_nowrap_headers"
116  TYPE "HEADERS"
117  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta"
118  FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Phasta/vtkPVAdaptorsPhastaModule.h"
119  )
120 else()
121  set_property(TARGET ParaView::AdaptorsPhasta
122  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
123  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta"
124  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta"
125  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta"
126  )
127 endif()
128
129 # Create imported target ParaView::AdaptorsParticle
130 add_library(ParaView::AdaptorsParticle SHARED IMPORTED)
131
132 set_target_properties(ParaView::AdaptorsParticle PROPERTIES
133  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Particle;/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Particle;/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Particle"
134  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::RemotingViews;VTK::CommonCore;VTK::CommonDataModel;VTK::IOImage;VTK::IOParallelXML;VTK::ParallelMPI;VTK::RenderingCore;VTK::RenderingOpenGL2;VTK::PythonUsed"
135 )
136
137 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
138  target_sources(ParaView::AdaptorsParticle
139  INTERFACE
140  FILE_SET "vtk_module_templates"
141  TYPE "HEADERS"
142  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle"
143  FILES
144  INTERFACE
145  FILE_SET "vtk_module_headers"
146  TYPE "HEADERS"
147  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle"
148  FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle/ParticleAdaptor.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle/vtkParticlePipeline.h"
149  INTERFACE
150  FILE_SET "vtk_module_nowrap_headers"
151  TYPE "HEADERS"
152  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle"
153  FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Particle/vtkPVAdaptorsParticleModule.h"
154  )
155 else()
156  set_property(TARGET ParaView::AdaptorsParticle
157  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
158  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle"
159  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle"
160  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle"
161  )
162 endif()
163
164 # Create imported target ParaView::PythonCatalyst
165 add_library(ParaView::PythonCatalyst SHARED IMPORTED)
166
167 set_target_properties(ParaView::PythonCatalyst PROPERTIES
168  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst/Fortran"
169  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::PythonInterpreter;ParaView::PythonInterpreterPath;VTK::PythonUsed"
170 )
171
172 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
173  target_sources(ParaView::PythonCatalyst
174  INTERFACE
175  FILE_SET "vtk_module_templates"
176  TYPE "HEADERS"
177  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst"
178  FILES
179  INTERFACE
180  FILE_SET "vtk_module_headers"
181  TYPE "HEADERS"
182  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst"
183  FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst/FortranPythonAdaptorAPIMangling.h" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/CPythonAdaptorAPI.h" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/vtkCPPythonAdaptorAPI.h" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/vtkCPPythonPipeline.h" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/vtkCPPythonScriptPipeline.h" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/vtkCPPythonScriptV2Helper.h" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/vtkCPPythonScriptV2Pipeline.h" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/vtkCPPythonStringPipeline.h" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/FortranPythonAdaptorAPI.h"
184  INTERFACE
185  FILE_SET "vtk_module_nowrap_headers"
186  TYPE "HEADERS"
187  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst"
188  FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst/vtkPVPythonCatalystModule.h"
189  )
190 else()
191  set_property(TARGET ParaView::PythonCatalyst
192  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
193  "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst"
194  "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst"
195  "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst"
196  )
197 endif()
198
199 # Create imported target ParaView::AdaptorsPagosa
200 add_library(ParaView::AdaptorsPagosa SHARED IMPORTED)
201
202 set_target_properties(ParaView::AdaptorsPagosa PROPERTIES
203  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Pagosa;/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Pagosa;/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Pagosa"
204  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonDataModel;VTK::PythonUsed"
205 )
206
207 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
208  target_sources(ParaView::AdaptorsPagosa
209  INTERFACE
210  FILE_SET "vtk_module_templates"
211  TYPE "HEADERS"
212  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa"
213  FILES
214  INTERFACE
215  FILE_SET "vtk_module_headers"
216  TYPE "HEADERS"
217  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa"
218  FILES
219  INTERFACE
220  FILE_SET "vtk_module_nowrap_headers"
221  TYPE "HEADERS"
222  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa"
223  FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Pagosa/vtkPVAdaptorsPagosaModule.h"
224  )
225 else()
226  set_property(TARGET ParaView::AdaptorsPagosa
227  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
228  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa"
229  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa"
230  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa"
231  )
232 endif()
233
234 # Create imported target ParaView::AdaptorsNPIC
235 add_library(ParaView::AdaptorsNPIC SHARED IMPORTED)
236
237 set_target_properties(ParaView::AdaptorsNPIC PROPERTIES
238  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/NPIC;/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/NPIC;/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/NPIC"
239  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonDataModel;VTK::CommonCore;VTK::ParallelMPI;VTK::PythonUsed"
240 )
241
242 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
243  target_sources(ParaView::AdaptorsNPIC
244  INTERFACE
245  FILE_SET "vtk_module_templates"
246  TYPE "HEADERS"
247  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC"
248  FILES
249  INTERFACE
250  FILE_SET "vtk_module_headers"
251  TYPE "HEADERS"
252  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC"
253  FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC/NPICAdaptor.h"
254  INTERFACE
255  FILE_SET "vtk_module_nowrap_headers"
256  TYPE "HEADERS"
257  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC"
258  FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/NPIC/vtkPVAdaptorsNPICModule.h"
259  )
260 else()
261  set_property(TARGET ParaView::AdaptorsNPIC
262  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
263  "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC"
264  "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC"
265  "/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC"
266  )
267 endif()
268
269 # Create imported target ParaView::CatalystTestDriver
270 add_library(ParaView::CatalystTestDriver SHARED IMPORTED)
271
272 set_target_properties(ParaView::CatalystTestDriver PROPERTIES
273  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver;/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver;/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver"
274  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::PythonUsed"
275 )
276
277 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
278  target_sources(ParaView::CatalystTestDriver
279  INTERFACE
280  FILE_SET "vtk_module_templates"
281  TYPE "HEADERS"
282  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver"
283  FILES
284  INTERFACE
285  FILE_SET "vtk_module_headers"
286  TYPE "HEADERS"
287  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver"
288  FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPBaseFieldBuilder.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPBaseGridBuilder.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPCellFieldBuilder.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPConstantScalarFieldFunction.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPFieldBuilder.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPFileGridBuilder.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPGridBuilder.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPLinearScalarFieldFunction.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPMultiBlockGridBuilder.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPNodalFieldBuilder.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPScalarFieldFunction.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPTensorFieldFunction.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPTestDriver.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPUniformGridBuilder.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPUnstructuredGridBuilder.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver/vtkCPVector3FieldFunction.h"
289  INTERFACE
290  FILE_SET "vtk_module_nowrap_headers"
291  TYPE "HEADERS"
292  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver"
293  FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver/vtkPVCatalystTestDriverModule.h"
294  )
295 else()
296  set_property(TARGET ParaView::CatalystTestDriver
297  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
298  "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver"
299  "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver"
300  "/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver"
301  )
302 endif()
303
304 # Create imported target ParaView::AdaptorsCam
305 add_library(ParaView::AdaptorsCam SHARED IMPORTED)
306
307 set_target_properties(ParaView::AdaptorsCam PROPERTIES
308  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Cam;/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Cam;/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Cam"
309  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::PythonCatalyst;VTK::CommonDataModel;VTK::CommonCore;VTK::PythonUsed"
310 )
311
312 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
313  target_sources(ParaView::AdaptorsCam
314  INTERFACE
315  FILE_SET "vtk_module_templates"
316  TYPE "HEADERS"
317  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam"
318  FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/Grid.txx"
319  INTERFACE
320  FILE_SET "vtk_module_headers"
321  TYPE "HEADERS"
322  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam"
323  FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/fv_create_data.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/se_create_data.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/Grid.h"
324  INTERFACE
325  FILE_SET "vtk_module_nowrap_headers"
326  TYPE "HEADERS"
327  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam"
328  FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Cam/vtkPVAdaptorsCamModule.h"
329  )
330 else()
331  set_property(TARGET ParaView::AdaptorsCam
332  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
333  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam"
334  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam"
335  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam"
336  )
337 endif()
338
339 # Create imported target ParaView::AdaptorsCamPython
340 add_library(ParaView::AdaptorsCamPython INTERFACE IMPORTED)
341
342 set_target_properties(ParaView::AdaptorsCamPython PROPERTIES
343  INTERFACE_LINK_LIBRARIES "ParaView::AdaptorsCam"
344 )
345
346 # Create imported target ParaView::AdaptorsCTH
347 add_library(ParaView::AdaptorsCTH SHARED IMPORTED)
348
349 set_target_properties(ParaView::AdaptorsCTH PROPERTIES
350  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CTH;/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CTH;/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH;/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CTH"
351  INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::PythonCatalyst;VTK::CommonCore;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::ParallelMPI;VTK::PythonUsed"
352 )
353
354 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
355  target_sources(ParaView::AdaptorsCTH
356  INTERFACE
357  FILE_SET "vtk_module_templates"
358  TYPE "HEADERS"
359  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH"
360  FILES
361  INTERFACE
362  FILE_SET "vtk_module_headers"
363  TYPE "HEADERS"
364  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH"
365  FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH/CTHAdaptor.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH/vtkCTHSource.h" "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH/vtkCTHDataArray.h"
366  INTERFACE
367  FILE_SET "vtk_module_nowrap_headers"
368  TYPE "HEADERS"
369  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH"
370  FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CTH/vtkPVAdaptorsCTHModule.h"
371  )
372 else()
373  set_property(TARGET ParaView::AdaptorsCTH
374  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
375  "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH"
376  "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH"
377  "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH"
378  )
379 endif()
380
381 # Create imported target ParaView::ClientsWeb
382 add_library(ParaView::ClientsWeb SHARED IMPORTED)
383
384 set_target_properties(ParaView::ClientsWeb PROPERTIES
385  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Clients/Web;/builds/gitlab-kitware-sciviz-ci/build/Clients/Web;/builds/gitlab-kitware-sciviz-ci/Clients/Web;/builds/gitlab-kitware-sciviz-ci/build/Clients/Web;/builds/gitlab-kitware-sciviz-ci/Clients/Web;/builds/gitlab-kitware-sciviz-ci/build/Clients/Web"
386  INTERFACE_LINK_LIBRARIES "VTK::WebCore;VTK::WebGLExporter;VTK::PythonUsed"
387 )
388
389 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
390  target_sources(ParaView::ClientsWeb
391  INTERFACE
392  FILE_SET "vtk_module_templates"
393  TYPE "HEADERS"
394  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Web"
395  FILES
396  INTERFACE
397  FILE_SET "vtk_module_headers"
398  TYPE "HEADERS"
399  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Web"
400  FILES "/builds/gitlab-kitware-sciviz-ci/Clients/Web/vtkPVWebApplication.h"
401  INTERFACE
402  FILE_SET "vtk_module_nowrap_headers"
403  TYPE "HEADERS"
404  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/Web"
405  FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/Web/vtkPVClientWebModule.h"
406  )
407 else()
408  set_property(TARGET ParaView::ClientsWeb
409  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
410  "/builds/gitlab-kitware-sciviz-ci/Clients/Web"
411  "/builds/gitlab-kitware-sciviz-ci/Clients/Web"
412  "/builds/gitlab-kitware-sciviz-ci/Clients/Web"
413  )
414 endif()
415
416 # Create imported target ParaView::InSitu
417 add_library(ParaView::InSitu SHARED IMPORTED)
418
419 set_target_properties(ParaView::InSitu PROPERTIES
420  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu;/builds/gitlab-kitware-sciviz-ci/build/Clients/InSitu;/builds/gitlab-kitware-sciviz-ci/Clients/InSitu;/builds/gitlab-kitware-sciviz-ci/build/Clients/InSitu;/builds/gitlab-kitware-sciviz-ci/Clients/InSitu;/builds/gitlab-kitware-sciviz-ci/build/Clients/InSitu"
421  INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::PythonUsed"
422 )
423
424 if(NOT CMAKE_VERSION VERSION_LESS "3.23.0")
425  target_sources(ParaView::InSitu
426  INTERFACE
427  FILE_SET "vtk_module_templates"
428  TYPE "HEADERS"
429  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu"
430  FILES
431  INTERFACE
432  FILE_SET "vtk_module_headers"
433  TYPE "HEADERS"
434  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu"
435  FILES "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu/vtkInSituInitializationHelper.h" "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu/vtkInSituPythonConduitHelper.h" "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu/vtkInSituPipeline.h" "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu/vtkInSituPipelineIO.h" "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu/vtkInSituPipelinePython.h"
436  INTERFACE
437  FILE_SET "vtk_module_nowrap_headers"
438  TYPE "HEADERS"
439  BASE_DIRS "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu"
440  FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/InSitu/vtkPVInSituModule.h"
441  )
442 else()
443  set_property(TARGET ParaView::InSitu
444  APPEND PROPERTY INTERFACE_INCLUDE_DIRECTORIES
445  "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu"
446  "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu"
447  "/builds/gitlab-kitware-sciviz-ci/Clients/InSitu"
448  )
449 endif()
450
451 # Import target "ParaView::Catalyst" for configuration "Release"
452 set_property(TARGET ParaView::Catalyst APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
453 set_target_properties(ParaView::Catalyst PROPERTIES
454  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingApplication;VTK::FiltersGeneral;VTK::FiltersHybrid;VTK::vtksys;VTK::ParallelMPI"
455  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalyst-pv6.1.so.6.1"
456  IMPORTED_SONAME_RELEASE "libvtkPVCatalyst-pv6.1.so.1"
457  )
458
459 # Import target "ParaView::AdaptorsPhasta" for configuration "Release"
460 set_property(TARGET ParaView::AdaptorsPhasta APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
461 set_target_properties(ParaView::AdaptorsPhasta PROPERTIES
462  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::ParallelMPI"
463  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPhasta-pv6.1.so.6.1"
464  IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsPhasta-pv6.1.so.1"
465  )
466
467 # Import target "ParaView::AdaptorsParticle" for configuration "Release"
468 set_property(TARGET ParaView::AdaptorsParticle APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
469 set_target_properties(ParaView::AdaptorsParticle PROPERTIES
470  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsParticle-pv6.1.so.6.1"
471  IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsParticle-pv6.1.so.1"
472  )
473
474 # Import target "ParaView::PythonCatalyst" for configuration "Release"
475 set_property(TARGET ParaView::PythonCatalyst APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
476 set_target_properties(ParaView::PythonCatalyst PROPERTIES
477  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::PythonInitializer;ParaView::RemotingServerManager;ParaView::VTKExtensionsCore;VTK::ParallelCore;VTK::WrappingPythonCore;ParaView::RemotingLive"
478  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVPythonCatalyst-pv6.1.so.6.1"
479  IMPORTED_SONAME_RELEASE "libvtkPVPythonCatalyst-pv6.1.so.1"
480  )
481
482 # Import target "ParaView::AdaptorsPagosa" for configuration "Release"
483 set_property(TARGET ParaView::AdaptorsPagosa APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
484 set_target_properties(ParaView::AdaptorsPagosa PROPERTIES
485  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::PythonCatalyst;VTK::ParallelMPI"
486  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPagosa-pv6.1.so.6.1"
487  IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsPagosa-pv6.1.so.1"
488  )
489
490 # Import target "ParaView::AdaptorsNPIC" for configuration "Release"
491 set_property(TARGET ParaView::AdaptorsNPIC APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
492 set_target_properties(ParaView::AdaptorsNPIC PROPERTIES
493  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsNPIC-pv6.1.so.6.1"
494  IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsNPIC-pv6.1.so.1"
495  )
496
497 # Import target "ParaView::CatalystTestDriver" for configuration "Release"
498 set_property(TARGET ParaView::CatalystTestDriver APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
499 set_target_properties(ParaView::CatalystTestDriver PROPERTIES
500  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonDataModel;VTK::ParallelCore"
501  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalystTestDriver-pv6.1.so.6.1"
502  IMPORTED_SONAME_RELEASE "libvtkPVCatalystTestDriver-pv6.1.so.1"
503  )
504
505 # Import target "ParaView::AdaptorsCam" for configuration "Release"
506 set_property(TARGET ParaView::AdaptorsCam APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
507 set_target_properties(ParaView::AdaptorsCam PROPERTIES
508  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCam-pv6.1.so.6.1"
509  IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsCam-pv6.1.so.1"
510  )
511
512 # Import target "ParaView::AdaptorsCTH" for configuration "Release"
513 set_property(TARGET ParaView::AdaptorsCTH APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
514 set_target_properties(ParaView::AdaptorsCTH PROPERTIES
515  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCTH-pv6.1.so.6.1"
516  IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsCTH-pv6.1.so.1"
517  )
518
519 # Import target "ParaView::ClientsWeb" for configuration "Release"
520 set_property(TARGET ParaView::ClientsWeb APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
521 set_target_properties(ParaView::ClientsWeb PROPERTIES
522  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingApplication;ParaView::RemotingViews;VTK::CommonSystem"
523  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVClientWeb-pv6.1.so.6.1"
524  IMPORTED_SONAME_RELEASE "libvtkPVClientWeb-pv6.1.so.1"
525  )
526
527 # Import target "ParaView::InSitu" for configuration "Release"
528 set_property(TARGET ParaView::InSitu APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
529 set_target_properties(ParaView::InSitu PROPERTIES
530  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::Catalyst;ParaView::RemotingApplication;ParaView::RemotingLive;ParaView::VTKExtensionsCore;ParaView::PythonCatalyst;ParaView::PythonInitializer;VTK::IOCatalystConduit;VTK::ParallelMPI;VTK::WrappingPythonCore"
531  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVInSitu-pv6.1.so.6.1"
532  IMPORTED_SONAME_RELEASE "libvtkPVInSitu-pv6.1.so.1"
533  )
534
535 # Make sure the targets which have been exported in some other
536 # export set exist.
537 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
538 foreach(_target "VTK::CommonCore" "VTK::PythonUsed" "ParaView::paraview_plugins" "VTK::CommonDataModel" "ParaView::RemotingViews" "VTK::IOImage" "VTK::IOParallelXML" "VTK::ParallelMPI" "VTK::RenderingCore" "VTK::RenderingOpenGL2" "VTK::PythonInterpreter" "ParaView::PythonInterpreterPath" "VTK::CommonExecutionModel" "VTK::WebCore" "VTK::WebGLExporter" )
539  if(NOT TARGET "${_target}" )
540  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
541  endif()
542 endforeach()
543
544 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
545  if(CMAKE_FIND_PACKAGE_NAME)
546  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
547  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
548  else()
549  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
550  endif()
551 endif()
552 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
553
554 # Commands beyond this point should not need to know the version.
555 set(CMAKE_IMPORT_FILE_VERSION)
556 cmake_policy(POP)
Class for specifying constant scalars at points.
Abstract class for specifying tensor fields at points.
This class provides the data description for each input for the coprocessor pipelines.
Class for specifying nodal fields over grids.
vtkCPAdaptorAPI provides the implementation for API exposed to typical adaptor, such as C...
Class for specifying cell fields over grids.
Class for creating uniform grids.
vtkCPPipeline for Catalyst Python script / package version 2.0
Class that creates a coprocessing pipeline from a coprocessing string.
Abstract class for creating grids.
Class for creating multiblock grids.
an internal class encapsulating logic for Catalyst Python scripts.
defines ParaViewWeb application interface.
Similar to vtkCPAdaptorAPI provides the implementation for API exposed to typical adaptor...
Generic PXML writer pipeline to write out the full Catalyst input datasets.
Class for creating a co-processor test driver.
Singleton class for initializing without python.
#define VERSION
Definition: jconfigint.h:17
Abstract class that takes care of initializing Catalyst Python pipelines for all concrete implementat...
initialization helper for in situ environments.
There are 3 distinct phases for the operation of a co-processor.
Abstract class for specifying vectors at points.
subclass for Python in situ scripts.
Generic interface for operating on pipelines.
Definition: vtkCPPipeline.h:17
Abstract class for specifying scalars at points.
Abstract class for specifying fields over grids.
A helper class to get the conduit node stored during the execution of one of the catalyst* calls as a...
Class for specifying scalars at points.
Class that creates a coprocessing pipeline starting from a coprocessing script.
insitu pipeline for IO
abstract base class for all in situ pipelines.
Class for creating grids from a VTK file.
This class provides the description of the data for the coprocessor pipelines.
Class for creating unstructured grids.
