Prism-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
11
14
16 set(_targetsDefined)
17 set(_targetsNotDefined)
18 set(_expectedTargets)
19 foreach(_expectedTarget Prism::vtkPrismFilters Prism::vtkPrismViews Prism::vtkPrismServerManager Prism::vtkPrismReaders)
23  endif()
26  endif()
27 endforeach()
29  unset(_targetsDefined)
30  unset(_targetsNotDefined)
31  unset(_expectedTargets)
33  cmake_policy(POP)
34  return()
35 endif()
39 unset(_targetsDefined)
40 unset(_targetsNotDefined)
41 unset(_expectedTargets)
42
43
44 # Create imported target Prism::vtkPrismFilters
45 add_library(Prism::vtkPrismFilters SHARED IMPORTED)
46
47 set_target_properties(Prism::vtkPrismFilters PROPERTIES
48  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Filters"
49  INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel"
50 )
51
52 # Create imported target Prism::vtkPrismViews
53 add_library(Prism::vtkPrismViews SHARED IMPORTED)
54
55 set_target_properties(Prism::vtkPrismViews PROPERTIES
56  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Views;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Views"
57  INTERFACE_LINK_LIBRARIES "ParaView::RemotingViews;VTK::CommonExecutionModel;VTK::PythonUsed"
58 )
59
60 # Create imported target Prism::vtkPrismServerManager
61 add_library(Prism::vtkPrismServerManager SHARED IMPORTED)
62
63 set_target_properties(Prism::vtkPrismServerManager PROPERTIES
64  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/ServerManager"
65  INTERFACE_LINK_LIBRARIES "ParaView::RemotingServerManager;VTK::CommonExecutionModel;VTK::PythonUsed"
66 )
67
68 # Create imported target Prism::vtkPrismReaders
69 add_library(Prism::vtkPrismReaders SHARED IMPORTED)
70
71 set_target_properties(Prism::vtkPrismReaders PROPERTIES
72  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Readers;/builds/gitlab-kitware-sciviz-ci/Plugins/Prism/Readers"
73  INTERFACE_LINK_LIBRARIES "ParaView::VTKExtensionsIOCore;Prism::vtkPrismServerManager;VTK::CommonExecutionModel;VTK::PythonUsed"
74 )
75
76 # Import target "Prism::vtkPrismFilters" for configuration "Release"
77 set_property(TARGET Prism::vtkPrismFilters APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
78 set_target_properties(Prism::vtkPrismFilters PROPERTIES
79  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::FiltersCore;VTK::FiltersGeneral;VTK::fmt"
80  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/Prism/libvtkPrismFilters.so"
81  IMPORTED_SONAME_RELEASE "libvtkPrismFilters.so"
82  )
83
84 # Import target "Prism::vtkPrismViews" for configuration "Release"
85 set_property(TARGET Prism::vtkPrismViews APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
86 set_target_properties(Prism::vtkPrismViews PROPERTIES
87  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingCore;Prism::vtkPrismFilters;VTK::CommonCore;VTK::CommonDataModel;VTK::FiltersExtraction;VTK::FiltersGeometry"
88  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/Prism/libvtkPrismViews.so"
89  IMPORTED_SONAME_RELEASE "libvtkPrismViews.so"
90  )
91
92 # Import target "Prism::vtkPrismServerManager" for configuration "Release"
93 set_property(TARGET Prism::vtkPrismServerManager APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
94 set_target_properties(Prism::vtkPrismServerManager PROPERTIES
95  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingCore;VTK::CommonCore;VTK::CommonDataModel"
96  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/Prism/libvtkPrismServerManager.so"
97  IMPORTED_SONAME_RELEASE "libvtkPrismServerManager.so"
98  )
99
100 # Import target "Prism::vtkPrismReaders" for configuration "Release"
101 set_property(TARGET Prism::vtkPrismReaders APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
102 set_target_properties(Prism::vtkPrismReaders PROPERTIES
103  IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMisc;VTK::FiltersGeometry"
104  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/Prism/libvtkPrismReaders.so"
105  IMPORTED_SONAME_RELEASE "libvtkPrismReaders.so"
106  )
107
108 # Make sure the targets which have been exported in some other
109 # export set exist.
110 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
111 foreach(_target "VTK::CommonExecutionModel" "ParaView::RemotingViews" "VTK::PythonUsed" "ParaView::RemotingServerManager" "ParaView::VTKExtensionsIOCore" )
112  if(NOT TARGET "${_target}" )
113  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
114  endif()
115 endforeach()
116
117 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
118  if(CMAKE_FIND_PACKAGE_NAME)
119  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
120  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
121  else()
122  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
123  endif()
124 endif()
125 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
126
127 # Commands beyond this point should not need to know the version.
128 set(CMAKE_IMPORT_FILE_VERSION)
129 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
