ParaViewPythonIncubator-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
11
14
15 if(CMAKE_VERSION VERSION_LESS 3.0.0)
16  message(FATAL_ERROR "This file relies on consumers using CMake 3.0.0 or greater.")
17 endif()
18
19 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
20 set(_targetsDefined)
21 set(_targetsNotDefined)
22 set(_expectedTargets)
23 foreach(_expectedTarget ParaView::vtkPVIncubatorCorePython ParaView::pvincubatorpythonmodules)
24  list(APPEND _expectedTargets ${_expectedTarget})
25  if(NOT TARGET ${_expectedTarget})
26  list(APPEND _targetsNotDefined ${_expectedTarget})
28  if(TARGET ${_expectedTarget})
29  list(APPEND _targetsDefined ${_expectedTarget})
30  endif()
31 endforeach()
32 if("${_targetsDefined}" STREQUAL "${_expectedTargets}")
33  unset(_targetsDefined)
34  unset(_targetsNotDefined)
35  unset(_expectedTargets)
36  set(CMAKE_IMPORT_FILE_VERSION)
37  cmake_policy(POP)
38  return()
39 endif()
40 if(NOT "${_targetsDefined}" STREQUAL "")
41  message(FATAL_ERROR "Some (but not all) targets in this export set were already defined.\nTargets Defined: ${_targetsDefined}\nTargets not yet defined: ${_targetsNotDefined}\n")
42 endif()
43 unset(_targetsDefined)
44 unset(_targetsNotDefined)
45 unset(_expectedTargets)
46
47
48 # Create imported target ParaView::vtkPVIncubatorCorePython
49 add_library(ParaView::vtkPVIncubatorCorePython MODULE IMPORTED)
50
51 # Create imported target ParaView::pvincubatorpythonmodules
52 add_library(ParaView::pvincubatorpythonmodules INTERFACE IMPORTED)
53
54 set_target_properties(ParaView::pvincubatorpythonmodules PROPERTIES
55  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/include/paraview-6.0/pvincubatorpythonmodules"
56  INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules"
57 )
58
59 # Import target "ParaView::vtkPVIncubatorCorePython" for configuration "Release"
60 set_property(TARGET ParaView::vtkPVIncubatorCorePython APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
61 set_target_properties(ParaView::vtkPVIncubatorCorePython PROPERTIES
62  IMPORTED_COMMON_LANGUAGE_RUNTIME_RELEASE ""
63  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/incubator/vtkPVIncubatorCore.so"
64  IMPORTED_NO_SONAME_RELEASE "TRUE"
65  )
66
67 # Make sure the targets which have been exported in some other
68 # export set exist.
69 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
70 foreach(_target "VTK::vtkpythonmodules" )
71  if(NOT TARGET "${_target}" )
72  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
73  endif()
74 endforeach()
75
76 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
77  if(CMAKE_FIND_PACKAGE_NAME)
78  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
79  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
80  else()
81  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
82  endif()
83 endif()
84 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
85
86 # Commands beyond this point should not need to know the version.
87 set(CMAKE_IMPORT_FILE_VERSION)
88 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
