3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 if(CMAKE_VERSION VERSION_LESS 3.0.0)
16 message(FATAL_ERROR
"This file relies on consumers using CMake 3.0.0 or greater.")
19 # Protect against multiple inclusion, which would fail when already imported targets are added once more. 21 set(_targetsNotDefined)
23 foreach(_expectedTarget ParaView::AdaptorsPython ParaView::Catalyst ParaView::Catalyst-
private-kit-links ParaView::AdaptorsPhasta ParaView::AdaptorsParticle ParaView::PythonCatalyst ParaView::AdaptorsPagosa ParaView::AdaptorsNPIC ParaView::CatalystTestDriver ParaView::AdaptorsCam ParaView::AdaptorsCamPython ParaView::AdaptorsCTH ParaView::ClientsWeb ParaView::InSitu)
24 list(APPEND _expectedTargets ${_expectedTarget})
25 if(NOT TARGET ${_expectedTarget})
26 list(APPEND _targetsNotDefined ${_expectedTarget})
28 if(TARGET ${_expectedTarget})
29 list(APPEND _targetsDefined ${_expectedTarget})
32 if("${_targetsDefined}
") 33 unset(_targetsDefined) 34 unset(_targetsNotDefined) 35 unset(_expectedTargets) 36 set(CMAKE_IMPORT_FILE_VERSION) 40 if(NOT "${_targetsDefined}
" STREQUAL "") 41 message(FATAL_ERROR "Some (but not all) targets in
this export
") 43 unset(_targetsDefined) 44 unset(_targetsNotDefined) 45 unset(_expectedTargets) 48 # Create imported target ParaView::AdaptorsPython 49 add_library(ParaView::AdaptorsPython INTERFACE IMPORTED) 51 # Create imported target ParaView::Catalyst 52 add_library(ParaView::Catalyst SHARED IMPORTED) 54 set_target_properties(ParaView::Catalyst PROPERTIES 55 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/Fortran
" 56 INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::PythonUsed
" 59 # Create imported target ParaView::Catalyst-private-kit-links 60 add_library(ParaView::Catalyst-private-kit-links INTERFACE IMPORTED) 62 set_target_properties(ParaView::Catalyst-private-kit-links PROPERTIES 63 INTERFACE_LINK_LIBRARIES "\$<LINK_ONLY:ParaView::paraview_plugins>
" 66 # Create imported target ParaView::AdaptorsPhasta 67 add_library(ParaView::AdaptorsPhasta SHARED IMPORTED) 69 set_target_properties(ParaView::AdaptorsPhasta PROPERTIES 70 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Phasta;/builds/gitlab-kitware-sciviz-ci/Adaptors/Phasta
" 71 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonCore;VTK::CommonDataModel;VTK::PythonUsed
" 74 # Create imported target ParaView::AdaptorsParticle 75 add_library(ParaView::AdaptorsParticle SHARED IMPORTED) 77 set_target_properties(ParaView::AdaptorsParticle PROPERTIES 78 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Particle;/builds/gitlab-kitware-sciviz-ci/Adaptors/Particle
" 79 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::RemotingViews;VTK::CommonCore;VTK::CommonDataModel;VTK::IOImage;VTK::IOParallelXML;VTK::ParallelMPI;VTK::RenderingCore;VTK::RenderingOpenGL2;VTK::PythonUsed
" 82 # Create imported target ParaView::PythonCatalyst 83 add_library(ParaView::PythonCatalyst SHARED IMPORTED) 85 set_target_properties(ParaView::PythonCatalyst PROPERTIES 86 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst;/builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst/Fortran
" 87 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::PythonInterpreter;ParaView::PythonInterpreterPath;VTK::PythonUsed
" 90 # Create imported target ParaView::AdaptorsPagosa 91 add_library(ParaView::AdaptorsPagosa SHARED IMPORTED) 93 set_target_properties(ParaView::AdaptorsPagosa PROPERTIES 94 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Pagosa;/builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa
" 95 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonDataModel;VTK::PythonUsed
" 98 # Create imported target ParaView::AdaptorsNPIC 99 add_library(ParaView::AdaptorsNPIC SHARED IMPORTED) 101 set_target_properties(ParaView::AdaptorsNPIC PROPERTIES 102 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/NPIC;/builds/gitlab-kitware-sciviz-ci/Adaptors/NPIC
" 103 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::CommonDataModel;VTK::CommonCore;VTK::ParallelMPI;VTK::PythonUsed
" 106 # Create imported target ParaView::CatalystTestDriver 107 add_library(ParaView::CatalystTestDriver SHARED IMPORTED) 109 set_target_properties(ParaView::CatalystTestDriver PROPERTIES 110 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CatalystTestDriver;/builds/gitlab-kitware-sciviz-ci/Adaptors/CatalystTestDriver
" 111 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;VTK::PythonUsed
" 114 # Create imported target ParaView::AdaptorsCam 115 add_library(ParaView::AdaptorsCam SHARED IMPORTED) 117 set_target_properties(ParaView::AdaptorsCam PROPERTIES 118 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Cam;/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam
" 119 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::PythonCatalyst;VTK::CommonDataModel;VTK::CommonCore;VTK::PythonUsed
" 122 # Create imported target ParaView::AdaptorsCamPython 123 add_library(ParaView::AdaptorsCamPython INTERFACE IMPORTED) 125 set_target_properties(ParaView::AdaptorsCamPython PROPERTIES 126 INTERFACE_LINK_LIBRARIES "ParaView::AdaptorsCam
" 129 # Create imported target ParaView::AdaptorsCTH 130 add_library(ParaView::AdaptorsCTH SHARED IMPORTED) 132 set_target_properties(ParaView::AdaptorsCTH PROPERTIES 133 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CTH;/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH
" 134 INTERFACE_LINK_LIBRARIES "ParaView::Catalyst;ParaView::PythonCatalyst;VTK::CommonCore;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::ParallelMPI;VTK::PythonUsed
" 137 # Create imported target ParaView::ClientsWeb 138 add_library(ParaView::ClientsWeb SHARED IMPORTED) 140 set_target_properties(ParaView::ClientsWeb PROPERTIES 141 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Clients/Web;/builds/gitlab-kitware-sciviz-ci/Clients/Web
" 142 INTERFACE_LINK_LIBRARIES "VTK::WebCore;VTK::WebGLExporter;VTK::PythonUsed
" 145 # Create imported target ParaView::InSitu 146 add_library(ParaView::InSitu SHARED IMPORTED) 148 set_target_properties(ParaView::InSitu PROPERTIES 149 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Clients/InSitu;/builds/gitlab-kitware-sciviz-ci/Clients/InSitu
" 150 INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::PythonUsed
" 153 # Import target "ParaView::Catalyst
" for configuration "Release
" 154 set_property(TARGET ParaView::Catalyst APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 155 set_target_properties(ParaView::Catalyst PROPERTIES 156 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingApplication;VTK::FiltersGeneral;VTK::FiltersHybrid;VTK::vtksys;VTK::ParallelMPI
" 157 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalyst-pv6.0.so.6.0
" 158 IMPORTED_SONAME_RELEASE "libvtkPVCatalyst-pv6.0.so.1
" 161 # Import target "ParaView::AdaptorsPhasta
" 162 set_property(TARGET ParaView::AdaptorsPhasta APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 163 set_target_properties(ParaView::AdaptorsPhasta PROPERTIES 164 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::ParallelMPI
" 165 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPhasta-pv6.0.so.6.0
" 166 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsPhasta-pv6.0.so.1
" 169 # Import target "ParaView::AdaptorsParticle
" 170 set_property(TARGET ParaView::AdaptorsParticle APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 171 set_target_properties(ParaView::AdaptorsParticle PROPERTIES 172 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsParticle-pv6.0.so.6.0
" 173 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsParticle-pv6.0.so.1
" 176 # Import target "ParaView::PythonCatalyst
" 177 set_property(TARGET ParaView::PythonCatalyst APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 178 set_target_properties(ParaView::PythonCatalyst PROPERTIES 179 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::PythonInitializer;ParaView::RemotingServerManager;ParaView::VTKExtensionsCore;VTK::ParallelCore;VTK::WrappingPythonCore;ParaView::RemotingLive
" 180 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVPythonCatalyst-pv6.0.so.6.0
" 181 IMPORTED_SONAME_RELEASE "libvtkPVPythonCatalyst-pv6.0.so.1
" 184 # Import target "ParaView::AdaptorsPagosa
" 185 set_property(TARGET ParaView::AdaptorsPagosa APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 186 set_target_properties(ParaView::AdaptorsPagosa PROPERTIES 187 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::PythonCatalyst;VTK::ParallelMPI
" 188 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPagosa-pv6.0.so.6.0
" 189 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsPagosa-pv6.0.so.1
" 192 # Import target "ParaView::AdaptorsNPIC
" 193 set_property(TARGET ParaView::AdaptorsNPIC APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 194 set_target_properties(ParaView::AdaptorsNPIC PROPERTIES 195 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsNPIC-pv6.0.so.6.0
" 196 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsNPIC-pv6.0.so.1
" 199 # Import target "ParaView::CatalystTestDriver
" 200 set_property(TARGET ParaView::CatalystTestDriver APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 201 set_target_properties(ParaView::CatalystTestDriver PROPERTIES 202 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonDataModel;VTK::ParallelCore
" 203 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalystTestDriver-pv6.0.so.6.0
" 204 IMPORTED_SONAME_RELEASE "libvtkPVCatalystTestDriver-pv6.0.so.1
" 207 # Import target "ParaView::AdaptorsCam
" 208 set_property(TARGET ParaView::AdaptorsCam APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 209 set_target_properties(ParaView::AdaptorsCam PROPERTIES 210 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCam-pv6.0.so.6.0
" 211 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsCam-pv6.0.so.1
" 214 # Import target "ParaView::AdaptorsCTH
" 215 set_property(TARGET ParaView::AdaptorsCTH APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 216 set_target_properties(ParaView::AdaptorsCTH PROPERTIES 217 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCTH-pv6.0.so.6.0
" 218 IMPORTED_SONAME_RELEASE "libvtkPVAdaptorsCTH-pv6.0.so.1
" 221 # Import target "ParaView::ClientsWeb
" 222 set_property(TARGET ParaView::ClientsWeb APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 223 set_target_properties(ParaView::ClientsWeb PROPERTIES 224 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::RemotingApplication;ParaView::RemotingViews;VTK::CommonSystem
" 225 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVClientWeb-pv6.0.so.6.0
" 226 IMPORTED_SONAME_RELEASE "libvtkPVClientWeb-pv6.0.so.1
" 229 # Import target "ParaView::InSitu
" 230 set_property(TARGET ParaView::InSitu APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 231 set_target_properties(ParaView::InSitu PROPERTIES 232 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "ParaView::Catalyst;ParaView::RemotingApplication;ParaView::RemotingLive;ParaView::VTKExtensionsCore;ParaView::PythonCatalyst;ParaView::PythonInitializer;VTK::IOCatalystConduit;VTK::ParallelMPI;VTK::WrappingPythonCore
" 233 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVInSitu-pv6.0.so.6.0
" 234 IMPORTED_SONAME_RELEASE "libvtkPVInSitu-pv6.0.so.1
" 237 # Make sure the targets which have been exported in some other 239 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 240 foreach(_target "VTK::CommonCore
" "VTK::PythonUsed
" "ParaView::paraview_plugins
" "VTK::CommonDataModel
" "ParaView::RemotingViews
" "VTK::IOImage
" "VTK::IOParallelXML
" "VTK::ParallelMPI
" "VTK::RenderingCore
" "VTK::RenderingOpenGL2
" "VTK::PythonInterpreter
" "ParaView::PythonInterpreterPath
" "VTK::CommonExecutionModel
" "VTK::WebCore
" "VTK::WebGLExporter
" ) 241 if(NOT TARGET "${_target}
" ) 242 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 246 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 247 if(CMAKE_FIND_PACKAGE_NAME) 248 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 249 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 251 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 254 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 256 # Commands beyond this point should not need to know the version. 257 set(CMAKE_IMPORT_FILE_VERSION)
