3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
17 set(_targetsNotDefined)
19 foreach(_expectedTarget GeodesicMeasurement::GeodesicMeasurementFilters GeodesicMeasurement::FmmMesh)
20 list(APPEND _expectedTargets ${_expectedTarget})
21 if(NOT TARGET ${_expectedTarget})
22 list(APPEND _targetsNotDefined ${_expectedTarget})
24 if(TARGET ${_expectedTarget})
25 list(APPEND _targetsDefined ${_expectedTarget})
28 if("${_targetsDefined}
") 29 unset(_targetsDefined) 30 unset(_targetsNotDefined) 31 unset(_expectedTargets) 32 set(CMAKE_IMPORT_FILE_VERSION) 36 if(NOT "${_targetsDefined}
" STREQUAL "") 37 message(FATAL_ERROR "Some (but not all) targets in
this export
") 39 unset(_targetsDefined) 40 unset(_targetsNotDefined) 41 unset(_expectedTargets) 44 # Create imported target GeodesicMeasurement::GeodesicMeasurementFilters 45 add_library(GeodesicMeasurement::GeodesicMeasurementFilters SHARED IMPORTED) 47 set_target_properties(GeodesicMeasurement::GeodesicMeasurementFilters PROPERTIES 48 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/GeodesicMeasurement/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters
" 49 INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel
" 52 # Create imported target GeodesicMeasurement::FmmMesh 53 add_library(GeodesicMeasurement::FmmMesh STATIC IMPORTED) 55 set_target_properties(GeodesicMeasurement::FmmMesh PROPERTIES 56 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/GeodesicMeasurement/Filters/FmmMesh;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh/gw_core;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh/gw_geodesic;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh/gw_maths
" 59 # Import target "GeodesicMeasurement::GeodesicMeasurementFilters
" for configuration "Release
" 60 set_property(TARGET GeodesicMeasurement::GeodesicMeasurementFilters APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 61 set_target_properties(GeodesicMeasurement::GeodesicMeasurementFilters PROPERTIES 62 IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE "VTK::CommonCore;VTK::CommonDataModel;VTK::FiltersCore;VTK::FiltersModeling
" 63 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/GeodesicMeasurement/libvtkGeodesicMeasurementFilters.so
" 64 IMPORTED_SONAME_RELEASE "libvtkGeodesicMeasurementFilters.so
" 67 # Import target "GeodesicMeasurement::FmmMesh
" 68 set_property(TARGET GeodesicMeasurement::FmmMesh APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 69 set_target_properties(GeodesicMeasurement::FmmMesh PROPERTIES 70 IMPORTED_LINK_INTERFACE_LANGUAGES_RELEASE "CXX
" 71 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/GeodesicMeasurement/libFmmMesh.a
" 74 # Make sure the targets which have been exported in some other 76 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 77 foreach(_target "VTK::CommonExecutionModel
" ) 78 if(NOT TARGET "${_target}
" ) 79 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 83 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 84 if(CMAKE_FIND_PACKAGE_NAME) 85 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 86 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 88 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 91 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 93 # Commands beyond this point should not need to know the version. 94 set(CMAKE_IMPORT_FILE_VERSION)
