DigitalSignalProcessing-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
11
14
16 set(_targetsDefined)
17 set(_targetsNotDefined)
18 set(_expectedTargets)
19 foreach(_expectedTarget DigitalSignalProcessing::DSPDataModel DigitalSignalProcessing::DSPFiltersPlugin)
23  endif()
26  endif()
27 endforeach()
29  unset(_targetsDefined)
30  unset(_targetsNotDefined)
31  unset(_expectedTargets)
33  cmake_policy(POP)
34  return()
35 endif()
39 unset(_targetsDefined)
40 unset(_targetsNotDefined)
41 unset(_expectedTargets)
42
43
44 # Create imported target DigitalSignalProcessing::DSPDataModel
45 add_library(DigitalSignalProcessing::DSPDataModel STATIC IMPORTED)
46
47 set_target_properties(DigitalSignalProcessing::DSPDataModel PROPERTIES
48  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel"
49  INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonExecutionModel;\$<LINK_ONLY:VTK::CommonDataModel>"
50 )
51
52 # Create imported target DigitalSignalProcessing::DSPFiltersPlugin
53 add_library(DigitalSignalProcessing::DSPFiltersPlugin STATIC IMPORTED)
54
55 set_target_properties(DigitalSignalProcessing::DSPFiltersPlugin PROPERTIES
56  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters"
57  INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::FiltersGeneral;\$<LINK_ONLY:DigitalSignalProcessing::DSPDataModel>;\$<LINK_ONLY:VTK::FiltersCore>;\$<LINK_ONLY:VTK::FiltersExtraction>;\$<LINK_ONLY:VTK::ParallelCore>"
58 )
59
60 # Import target "DigitalSignalProcessing::DSPDataModel" for configuration "Release"
61 set_property(TARGET DigitalSignalProcessing::DSPDataModel APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
62 set_target_properties(DigitalSignalProcessing::DSPDataModel PROPERTIES
63  IMPORTED_LINK_INTERFACE_LANGUAGES_RELEASE "CXX"
64  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/DigitalSignalProcessing/libvtkDSPDataModel.a"
65  )
66
67 # Import target "DigitalSignalProcessing::DSPFiltersPlugin" for configuration "Release"
68 set_property(TARGET DigitalSignalProcessing::DSPFiltersPlugin APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE)
69 set_target_properties(DigitalSignalProcessing::DSPFiltersPlugin PROPERTIES
70  IMPORTED_LINK_INTERFACE_LANGUAGES_RELEASE "CXX"
71  IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/DigitalSignalProcessing/libvtkDSPFiltersPlugin.a"
72  )
73
74 # Make sure the targets which have been exported in some other
75 # export set exist.
76 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
77 foreach(_target "VTK::CommonCore" "VTK::CommonExecutionModel" "VTK::CommonDataModel" "VTK::FiltersGeneral" "VTK::FiltersCore" "VTK::FiltersExtraction" "VTK::ParallelCore" )
78  if(NOT TARGET "${_target}" )
79  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
80  endif()
81 endforeach()
82
83 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
84  if(CMAKE_FIND_PACKAGE_NAME)
85  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
86  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
87  else()
88  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
89  endif()
90 endif()
91 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
92
93 # Commands beyond this point should not need to know the version.
94 set(CMAKE_IMPORT_FILE_VERSION)
95 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
