3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
17 set(_targetsNotDefined)
19 foreach(_expectedTarget BivariateRepresentations::vtkBivariateRepresentations)
20 list(APPEND _expectedTargets ${_expectedTarget})
21 if(NOT TARGET ${_expectedTarget})
22 list(APPEND _targetsNotDefined ${_expectedTarget})
24 if(TARGET ${_expectedTarget})
25 list(APPEND _targetsDefined ${_expectedTarget})
28 if("${_targetsDefined}
") 29 unset(_targetsDefined) 30 unset(_targetsNotDefined) 31 unset(_expectedTargets) 32 set(CMAKE_IMPORT_FILE_VERSION) 36 if(NOT "${_targetsDefined}
" STREQUAL "") 37 message(FATAL_ERROR "Some (but not all) targets in
this export
") 39 unset(_targetsDefined) 40 unset(_targetsNotDefined) 41 unset(_expectedTargets) 44 # Create imported target BivariateRepresentations::vtkBivariateRepresentations 45 add_library(BivariateRepresentations::vtkBivariateRepresentations STATIC IMPORTED) 47 set_target_properties(BivariateRepresentations::vtkBivariateRepresentations PROPERTIES 48 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/BivariateRepresentations/Representations;/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations
" 49 INTERFACE_LINK_LIBRARIES "ParaView::RemotingViews;VTK::RenderingOpenGL2;\$<LINK_ONLY:ParaView::RemotingMisc>;\$<LINK_ONLY:ParaView::VTKExtensionsFiltersRendering>;\$<LINK_ONLY:VTK::CommonCore>;\$<LINK_ONLY:VTK::RenderingContextOpenGL2>;VTK::PythonUsed
" 52 # Import target "BivariateRepresentations::vtkBivariateRepresentations
" for configuration "Release
" 53 set_property(TARGET BivariateRepresentations::vtkBivariateRepresentations APPEND PROPERTY IMPORTED_CONFIGURATIONS RELEASE) 54 set_target_properties(BivariateRepresentations::vtkBivariateRepresentations PROPERTIES 55 IMPORTED_LINK_INTERFACE_LANGUAGES_RELEASE "CXX
" 56 IMPORTED_LOCATION_RELEASE "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/BivariateRepresentations/libvtkBivariateRepresentations.a
" 59 # Make sure the targets which have been exported in some other 61 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 62 foreach(_target "ParaView::RemotingViews
" "VTK::RenderingOpenGL2
" "ParaView::RemotingMisc
" "ParaView::VTKExtensionsFiltersRendering
" "VTK::CommonCore
" "VTK::RenderingContextOpenGL2
" "VTK::PythonUsed
" ) 63 if(NOT TARGET "${_target}
" ) 64 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 68 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 69 if(CMAKE_FIND_PACKAGE_NAME) 70 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 71 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 73 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 76 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 78 # Commands beyond this point should not need to know the version. 79 set(CMAKE_IMPORT_FILE_VERSION)
