3 This page describes how to build and install ParaView. It covers building for
4 development, on both Linux and Windows. Please Note that Linux (x86_64), Windows (x86_64)
5 and macOS (x86_64 and arm64) version are built and tested by our continuous
6 integration system and are considered supported environments.
8 Any other environnements and architecture (including Cygwin, MingGW, PowerPC) are considered
9 non-officially supported, however, patches to fix problems with these platforms will
10 be considered for inclusion.
12 ParaView depends on several open source tools and libraries such as Python, Qt,
13 CGNS, HDF5, etc. Some of these are included in the ParaView source itself
14 (e.g., HDF5), while others are expected to be present on the machine on which
15 ParaView is being built (e.g., Python, Qt).
17 The first section is a getting started guide by OS that is very helpful if you have never
18 built ParaView before and do not know which options you need.
19 If you are looking for the generic help, please read the [Complete Compilation Guide](#complete-compilation-guide)
21 ## Getting Started Guide
22 This is a section intended to help those that have never built ParaView before, are not
23 experienced with compilation in general or have no idea which option they may need when building ParaView.
24 If you follow this guide, you will be able to compile and run a standard version of ParaView
25 for your operating system. It will be built with the Python wrapping, MPI capabilities and multithreading capabilities.
27 * If you are using a Linux distribution, please see [the Linux part](#linux),
28 * If you are using Microsoft Windows, please see [the Windows part](#windows),
29 * If you are using macOS, please see [the macOS part](#macos),
30 * If you are using another OS, feel free to provide compilation steps.
35 Please run the command in a terminal to install the following dependencies depending of your linux distribution.
37 ##### Ubuntu 22.04 LTS / Debian 12
39 `sudo apt-get install git cmake build-essential libgl1-mesa-dev libxt-dev libqt5x11extras5-dev libqt5help5 qttools5-dev qtxmlpatterns5-dev-tools libqt5svg5-dev python3-dev python3-numpy libopenmpi-dev libtbb-dev ninja-build qtbase5-dev qtchooser qt5-qmake qtbase5-dev-tools`
41 ##### Ubuntu 18.04 LTS / Debian 10
42 `sudo apt-get install git cmake build-essential libgl1-mesa-dev libxt-dev qt5-default libqt5x11extras5-dev libqt5help5 qttools5-dev qtxmlpatterns5-dev-tools libqt5svg5-dev python3-dev python3-numpy libopenmpi-dev libtbb-dev ninja-build`
47 Download and install [cmake][cmake-download]) as the packaged version is not enough considering that
48 CMake 3.12 or higher is needed.
51 `sudo yum install python3-devel openmpi-devel mesa-libGL-devel libX11-devel libXt-devel qt5-qtbase-devel qt5-qtx11extras-devel qt5-qttools-devel qt5-qtxmlpatterns-devel tbb-devel ninja-build git`
55 alias ninja=ninja-build
56 export PATH=$PATH:/usr/lib64/openmpi/bin/
60 `sudo pacman -S base-devel ninja openmpi tbb qt python python-numpy cmake`
62 ##### Other distribution
63 If you are using another distribution, please try to adapt the package list.
64 Feel free to then provide it so we can integrate it in this guide by creating an [issue][paraview-issues].
68 To build ParaView development version (usually refered as "master"), please run the following commands in a terminal:
70 git clone --recursive https://gitlab.kitware.com/paraview/paraview.git
73 cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_SMP_IMPLEMENTATION_TYPE=TBB -DCMAKE_BUILD_TYPE=Release ../paraview
77 To build a specific ParaView version, eg: v5.9.1, please run the following commands in a terminal while replacing "tag" by the version you want to build
79 git clone https://gitlab.kitware.com/paraview/paraview.git
83 git submodule update --init --recursive
85 cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_SMP_IMPLEMENTATION_TYPE=TBB -DCMAKE_BUILD_TYPE=Release ../paraview
89 ParaView also ships CMake presets:
94 They can be used directly like this:
97 cmake -GNinja --preset presetName ../paraview
102 Double click on the paraview executable in the `/bin` directory or run in the previous terminal
109 These instructions have worked on a mid 2023 MacMini with an M2 chipset on macOS Ventura.
111 #### Install Homebrew
112 Please run the command in a terminal to install the following dependencies on your Mac via [Homebrew](https://brew.sh/) and add the relevant environment variables for brew.
114 /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
115 (echo; echo 'eval "$(/opt/homebrew/bin/brew shellenv)"') >> ~/.zprofile
116 eval "$(/opt/homebrew/bin/brew shellenv)"
118 ##### Install dependencies (largely following the Ubuntu steps for Linux)
119 `brew install open-mpi cmake mesa tbb ninja gdal qt5`
121 ##### Set build environment
123 echo 'export PATH="/opt/homebrew/opt/qt@5/bin:$PATH"' >> ~/.zshrc
124 echo 'export LDFLAGS="-L/opt/homebrew/opt/qt@5/lib"' >> ~/.zshrc
125 echo 'export CPPFLAGS="-I/opt/homebrew/opt/qt@5/include"' >> ~/.zshrc
131 To build a specific ParaView version, eg: v5.11.1, please run the following commands in a terminal
133 git clone https://gitlab.kitware.com/paraview/paraview.git
137 git submodule update --init --recursive
139 cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_SMP_IMPLEMENTATION_TYPE=TBB -DCMAKE_BUILD_TYPE=Release -DPARAVIEW_ENABLE_GDAL=ON ../paraview
144 Double click on the paraview executable in the `/bin` directory or run in the previous terminal
147 ./bin/paraview.app/Contents/MacOS/paraview
152 Note: The following steps concerning Visual Studio 2019 can also be applied to newer versions.
153 If so, be sure to use the respective Qt Version (e.g. for VS 2022, use msvc2022_64) and the Native Tools Command Prompt.
156 * Download and install [git bash for windows][gitforwindows]
157 * Download and install [cmake][cmake-download]
158 * Download and install [Visual Studio 2019 Community Edition][visual-studio]
159 * Download [ninja-build][ninja] and drop `ninja.exe` in `C:\Windows\`
160 * Download and install both `msmpisetup.exe` and `msmpisdk.msi` from [Microsoft MPI][msmpi]
161 * Download and install [Python for Windows][pythonwindows], make sure to add the path to your Python installation folder to the `PATH` environnement variable.
162 * Download and install [Qt 5.15.3][qt-download-5.15.3] for Windows, make sure to check the MSVC 2019 64-bit component during installation.
163 * Make sure to add `C:\Qt\Qt5.15.3\5.15.3\msvc2019_64\bin` to your `PATH` environment variable.
164 * You may also need to add an environment variable `QT_QPA_PLATFORM_PLUGIN_PATH`: `C:\Qt\Qt5.15.3\5.15.3\msvc2019_64\plugins\platforms`.
166 #### Recover the source
168 * To build ParaView development version (usually referred to as `master`), run the following commands:
174 git clone --recursive https://gitlab.kitware.com/paraview/paraview.git
179 * Or, to build a specific ParaView version, eg: v5.9.1, please run the following commands while replacing "tag" by the version you want to build
185 git clone https://gitlab.kitware.com/paraview/paraview.git
190 git submodule update --init --recursive
195 * Open VS2019 x64 Native Tools Command Prompt and run the following commands
198 cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_SMP_IMPLEMENTATION_TYPE=STDThread -DCMAKE_BUILD_TYPE=Release ..\pv
202 Note: If you want to build ParaView with `CMAKE_BUILD_TYPE=Debug` you also need to add the option `-DPARAVIEW_WINDOWS_PYTHON_DEBUGGABLE=ON`.
206 * Double click on the `C:\pv\pvb\bin\paraview.exe` executable
208 ## Complete Compilation Guide
210 ### Obtaining the source
212 To obtain ParaView's sources locally, clone this repository using
216 git clone --recursive https://gitlab.kitware.com/paraview/paraview.git
221 ParaView supports all of the common generators supported by CMake. The Ninja,
222 Makefiles, and Visual Studio generators are the most well-tested however.
226 ParaView only requires a few packages to build with its basic capabilities. However,
227 specific features may require additional packages to be provided to ParaView's
233 - Version 3.12 or newer, however, the latest version is always recommended
237 - IBM XL 17.1 or newer
240 - Visual Studio 2019 or newer
242 Optional dependencies:
245 - At least 3.3 is required
247 - Version 5.15 or newer when using Qt 5, Qt 6.9 when using Qt 6.
249 ##### Installing CMake
251 CMake is a tool that makes cross-platform building simple. On several systems
252 it will probably be already installed or available through system package
253 management utilities. If it is not, there are precompiled binaries available on
254 [CMake's download page][cmake-download].
258 ParaView uses Qt to provide its graphical user interface. Precompiled binaries are available on
259 [Qt's website][qt-download].
261 Note that on Windows, the compiler used for building ParaView must match the
262 compiler version used to build Qt.
264 #### Optional Additions
266 ##### Download And Install ffmpeg (`.avi`) movie libraries
268 When the ability to write `.avi` files is desired, and writing these files is
269 not supported by the OS, ParaView can use the ffmpeg library. This is generally
270 true for Linux. Source code for ffmpeg can be obtained from [its
275 To run ParaView in parallel, an [MPI][mpi] implementation is required. If an
276 MPI implementation that exploits special interconnect hardware is provided on
277 your system, we suggest using it for optimal performance. Otherwise, on
278 Linux/Mac, we suggest either [OpenMPI][openmpi] or [MPICH][mpich]. On Windows,
279 [Microsoft MPI][msmpi] is required.
283 In order to use Python scripting, [Python][python] is required (version 3.3 or later). Python
284 is also required in order to build ParaViewWeb support.
288 Off-screen Mesa can be used as a software-renderer for running ParaView on a
289 server without hardware OpenGL acceleration. This is usually available in
290 system packages on Linux. For example, the `libosmesa6-dev` package on Debian
291 and Ubuntu. However, for older machines, building a newer version of Mesa is
292 likely necessary for bug fixes and support for features needed by ParaView.
293 Its source and build instructions can be found on [its website][mesa].
295 ### Creating the Build Environment
297 #### Linux (Ubuntu/Debian)
299 * `sudo apt install` the following packages:
306 - `ninja` is a speedy replacement for `make`, highly recommended.
308 *Note*: If you are using an Ubuntu-provided compiler, there is a known issue
309 with the optional Python linking. This case is hard to auto-detect, so if
310 undefined symbol errors related to Python symbols arise, setting
311 `vtk_undefined_symbols_allowed=OFF` may resolve the errors. If it does not,
312 please file a new [issue][paraview-issues].
316 * [Visual Studio 2019 Community Edition][visual-studio]
317 * Use "x64 Native Tools Command Prompt" for the installed Visual Studio
318 version to configure with CMake and to build with ninja.
319 * Get [ninja][ninja]. Unzip the binary and put it in `PATH`.
323 In order to build, CMake requires two steps, configure and build. ParaView
324 itself does not support what are known as in-source builds, so the first step
325 is to create a build directory.
328 On Windows, there have historically been issues if the path to the
329 build directory is too long. These issues should have been addressed in
330 more recent versions of ParaView's build system, but they may appear again. If you
331 see errors related to header files not being found at paths on your file
332 system that do exist, please report them to [the issue
333 tracker][paraview-issues].
336 mkdir -p paraview/build
338 ccmake ../path/to/paraview/source # -GNinja may be added to use the Ninja generator
341 CMake's GUI has input entries for the build directory and the generator
342 already. Note that on Windows, the GUI must be launched from a "Native Tools
343 Command Prompt" available with Visual Studio in the start menu.
347 ParaView has a number of settings available for its build. These are categorized
348 as build options, capability options, feature options and miscellaneous options.
352 Options that impact the build begin with the prefix `PARAVIEW_BUILD_`.
353 Common variables to modify include:
355 * `PARAVIEW_BUILD_SHARED_LIBS` (default `ON`): If set, shared libraries will
356 be built. This is usually what is wanted.
358 Less common, but variables which may be of interest to some:
360 * `PARAVIEW_BUILD_EDITION` (default `CANONICAL`): Choose which features to
361 enable in this build. This is useful to generate ParaView builds with
362 limited features. More on this later.
363 * `PARAVIEW_ENABLE_EXAMPLES` (default `OFF`): If set, ParaView's example code
364 will be added as tests to the ParaView test suite. These tests may be built
365 and run using the `paraview-examples` target.
366 * `PARAVIEW_BUILD_DEVELOPER_DOCUMENTATION` (default `OFF`): If set, the HTML
367 documentation for ParaView's C++, Python, and proxies will be generated.
368 * `PARAVIEW_PLUGIN_DISABLE_XML_DOCUMENTATION` (default `OFF`): Whether
369 plugin XML documentation is forcefully disabled.
370 * `PARAVIEW_BUILD_TESTING` (default `OFF`): Whether to build tests or not.
371 Valid values are `OFF` (no testing), `DEFAULT` (enable tests which have all
372 test dependencies satisfied), `WANT` (enable test dependencies as possible;
373 see vtk/vtk#17509), and `ON` (enable all tests; may error out if features
374 otherwise disabled are required by test code).
375 * `PARAVIEW_BUILD_VTK_TESTING` (default `OFF`): Whether to build tests for the
376 VTK codebase built by ParaView. Valid values are same as
377 `PARAVIEW_BUILD_TESTING`.
378 * `PARAVIEW_ENABLE_CATALYST` (default `OFF`): Whether to build the ParaView
379 implementation of Catalyst.
381 More advanced build options are:
383 * `PARAVIEW_BUILD_ALL_MODULES` (default `OFF`): If set, ParaView will enable
384 all modules not disabled by other features.
385 * `PARAVIEW_BUILD_LEGACY_REMOVE` (default `OFF`): Remove legacy / deprecated
387 * `PARAVIEW_BUILD_LEGACY_SILENT` (default `OFF`): Silence all legacy
388 / deprecated code messages.
389 * `PARAVIEW_BUILD_WITH_EXTERNAL` (default `OFF`): When set to `ON`, the build
390 will try to use external copies of all included third party libraries unless
391 explicitly overridden.
392 * `PARAVIEW_BUILD_WITH_KITS` (default `OFF`; requires
393 `PARAVIEW_BUILD_SHARED_LIBS`): Compile ParaView into a smaller set of
394 libraries. Can be useful on platforms where ParaView takes a long time to
395 launch due to expensive disk access.
396 * `PARAVIEW_BUILD_ID` (default `""`): A build ID for the ParaView build. It
397 can be any arbitrary value which can be used to indicate the provenance of
399 * `PARAVIEW_GENERATE_SPDX` (default `OFF`): When compiling ParaView, generate
400 a SPDX file for each of ParaView modules containing license and copyright
403 #### Capability settings
405 These settings control capabitities of the build. These begin with the prefix
406 `PARAVIEW_USE_`. The common variables to modify include:
408 * `PARAVIEW_USE_QT` (default `ON`): Builds the `paraview` GUI application.
409 * `PARAVIEW_USE_MPI` (default `OFF`): Whether MPI support will be available
411 * `PARAVIEW_USE_PYTHON` (default `OFF`): Whether Python
412 support will be available or not.
414 Less common, but potentially useful variables are:
416 * `PARAVIEW_USE_VISKORES` (default `ON`): Whether Viskores based filters are enabled.
417 * `PARAVIEW_USE_FORTRAN` (default `ON` if Fortran compiler found): Enable
418 Fortran support for Catalyst libraries.
419 * `PARAVIEW_USE_CUDA` (default `OFF`): Enable CUDA support in ParaView.
420 * `PARAVIEW_USE_HIP` (default `OFF`, requires CMake >= 3.21 and NOT
421 `PARAVIEW_USE_CUDA`): Enable HIP support in ParaView.
422 * `PARAVIEW_LOGGING_TIME_PRECISION` (default `3`): Change the precision of
423 times output. Possible values are 3 for ms, 6 for us, 9 for ns.
424 * `PARAVIEW_USE_SERIALIZATION` (default `OFF`): Whether VTK serialization is enabled.
426 #### Feature settings
428 These settings control optional features. These begin with the prefix
429 `PARAVIEW_ENABLE_`. The common variables to modify include:
431 * `PARAVIEW_ENABLE_RAYTRACING` (default `OFF`): Enable ray-tracing support
432 with OSPray and/or OptiX. Requires appropriate external libraries.
433 * `PARAVIEW_ENABLE_WEB` (default `OFF`; requires `PARAVIEW_USE_PYTHON`):
434 Whether ParaViewWeb support will be available or not.
436 These settings are used for translating purpose:
437 * `PARAVIEW_BUILD_TRANSLATIONS` (default `OFF`): Enable translation
438 files update and generation.
439 * `PARAVIEW_TRANSLATIONS_DIRECTORY` (default `${CMAKE_BINARY_DIR}/Translations`):
440 Path where the translation files will be generated on build.
442 More advanced / less common options include:
444 * `PARAVIEW_ENABLE_VISITBRIDGE` (default `OFF`): Enable support for VisIt
446 * `PARAVIEW_ENABLE_NVPIPE` (default `OFF`): Use [nvpipe][nvpipe] image
447 compression that uses the GPU when communicating. Requires CUDA and an NVIDIA GPU.
448 * `PARAVIEW_ENABLE_GDAL` (default `OFF`): Enable support for reading GDAL
450 * `PARAVIEW_ENABLE_LAS` (default `OFF`): Enable support for reading LAS
452 * `PARAVIEW_ENABLE_OPENTURNS` (default `OFF`): Enable support for reading
454 * `PARAVIEW_ENABLE_PDAL` (default `OFF`): Enable support for reading PDAL
456 * `PARAVIEW_ENABLE_MOTIONFX` (default `OFF`): Enable support for reading
458 * `PARAVIEW_ENABLE_MOMENTINVARIANTS` (default `OFF`): Enable
459 MomentInvariants filters.
460 * `PARAVIEW_ENABLE_LOOKINGGLASS` (default `OFF`): Enable support for LookingGlass displays.
461 * `PARAVIEW_ENABLE_XDMF2` (default `OFF`): Enable support for reading Xdmf2
463 * `PARAVIEW_ENABLE_XDMF3` (default `OFF`): Enable support for reading Xdmf3
465 * `PARAVIEW_ENABLE_FFMPEG` (default `OFF`; not available on Windows): Enable
467 * `PARAVIEW_ENABLE_COSMOTOOLS` (default `OFF`; requires `PARAVIEW_USE_MPI`
468 and not available on Windows): Enable support for CosmoTools which includes
469 GenericIO readers and writers as well as some point cloud algorithms.
470 * `PARAVIEW_ENABLE_CGNS_READER` (default `ON` for CANONICAL builds, `OFF` for
471 non-CANONICAL builds): Enable support for reading CGNS files. When building
472 ParaView for e.g. CATALYST, this option allows building support for reading
473 CGNS files. It will also build CGNSReader dependencies: HDF5 and CGNS.
474 * `PARAVIEW_ENABLE_CGNS_WRITER` (default `ON` for CANONICAL builds, `OFF` for
475 non-CANONICAL builds): Enable support for writing CGNS files. When building
476 ParaView for e.g. CATALYST, this option allows building support for writing
477 CGNS files. It will also build CGNSReader dependencies: HDF5 and CGNS. If
478 `PARAVIEW_ENABLE_MPI` is `ON`, the parallel CGNS writer will also be built.
479 * `PARAVIEW_ENABLE_OCCT` (default `OFF`): Enable support for reading OpenCascade
480 file formats such as STEP and IGES.
484 ParaView includes several optional plugins that can be enabled and disabled using the
487 * `PARAVIEW_PLUGINS_DEFAULT` (default `ON`): Pass this flag to the command
488 line using `-DPARAVIEW_PLUGINS_DEFAULT=OFF` before the first cmake run to
489 disable all plugins by default. Note this has no impact after the first
490 cmake configure and hence must be passed on the command line itself.
491 * `PARAVIEW_PLUGIN_ENABLE_<name>` (default varies): Whether to enable a
493 * `PARAVIEW_PLUGIN_AUTOLOAD_<name>` (default `OFF`): Whether to autoload a
494 plugin at startup or not. Note that this affects all clients linking to
495 ParaView's plugin target.
497 #### Miscellaneous settings
498 ParaView uses VTK's module system to control its build. This infrastructure
499 provides a number of variables to control modules which are not otherwise
500 controlled by the other options provided.
502 * `VTK_MODULE_USE_EXTERNAL_<name>` (default depends on
503 `PARAVIEW_BUILD_WITH_EXTERNAL`): Use an external source for the named third-party
504 module rather than the copy contained within the ParaView source tree.
505 * `VTK_MODULE_ENABLE_<name>` (default `DEFAULT`): Change the build settings
506 for the named module. Valid values are those for the module system's build
507 settings (see below).
508 * `VTK_GROUP_ENABLE_<name>` (default `DEFAULT`): Change the default build
509 settings for modules belonging to the named group. Valid values are those
510 for the module system's build settings (see below).
512 For variables that use the module system's build settings, the valid values are as follows:
514 * `YES`: Require the module to be built.
515 * `WANT`: Build the module if possible.
516 * `DEFAULT`: Use the settings by the module's groups and
517 `PARAVIEW_BUILD_ALL_MODULES`.
518 * `DONT_WANT`: Don't build the module unless required as a dependency.
519 * `NO`: Do not build the module.
521 If any `YES` module requires a `NO` module, an error is raised.
523 More advanced options:
525 * `PARAVIEW_INITIALIZE_MPI_ON_CLIENT` (default `ON`; requires
526 `PARAVIEW_USE_MPI`): Initialize MPI on client processes by default.
527 * `PARAVIEW_USE_QTHELP` (default `ON`; requires `PARAVIEW_USE_QT`): Use Qt's
528 help infrastructure for runtime documentation.
529 * `PARAVIEW_VERSIONED_INSTALL` (default `ON`): Whether to add version numbers
530 to ParaView's include and plugin directories in the install tree.
531 * `PARAVIEW_CUSTOM_LIBRARY_SUFFIX` (default depends on
532 `PARAVIEW_VERSIONED_INSTALL`): The custom suffix for libraries built by
533 ParaView. Defaults to either an empty string or `pvX.Y` where `X` and `Y`
534 are ParaView's major and minor version components, respectively.
535 * `PARAVIEW_INSTALL_DEVELOPMENT_FILES` (default `ON`): If set, ParaView will
536 install its headers, CMake API, etc. into its install tree for use.
537 * `PARAVIEW_RELOCATABLE_INSTALL` (default `ON`): If set, the install tree
538 will be relocatable to another path or machine. External dependencies
539 needed by ParaView which are in non-standard locations may need manual
540 settings in ParaView-using projects (those which share an install prefix
541 with ParaView should be OK though). If unset, the install tree will include
542 hints for the location of its dependencies which may include
543 build-machine-specific paths in the install tree.
544 * `PARAVIEW_SERIAL_TESTS_USE_MPIEXEC` (default `OFF`): Used on HPC to run
545 serial tests on compute nodes. If set, it prefixes serial tests with
546 "${MPIEXEC_EXECUTABLE}" "${MPIEXEC_NUMPROC_FLAG}" "1" ${MPI_PREFLAGS}
547 * `PARAVIEW_SKIP_CLANG_TIDY_FOR_VTK` (defaults `ON`; requires
548 `CMAKE_<LANG>_CLANG_TIDY`): If set, any `clang-tidy` settings will be
549 cleared for the internal VTK build.
550 * `PARAVIEW_TEST_DIR`: Used on HPC to set the test directory (default is
551 "${CMAKE_BINARY_DIR}/Testing/Temporary") to a location that is writable from
552 the compute nodes. Typically the user home directory is not.
553 * `PARAVIEW_LINKER_FATAL_WARNINGS`: Specify if linker warnings must
554 be considered as errors.
555 * `PARAVIEW_EXTRA_COMPILER_WARNINGS`: Add compiler flags to do
556 stricter checking when building.
557 * `PARAVIEW_ENABLE_EXTRA_BUILD_WARNINGS` (default `OFF`; requires CMake >= 3.19):
558 If set, PARAVIEW will enable additional build warnings.
561 These variables should be documented once they're effective again. Note that
562 various settings have a dependency on this that is not mentioned since the
563 option doesn't "exist" yet.
565 * `PARAVIEW_USE_EXTERNAL_VTK` (default `OFF`): Use an externally provided
566 VTK. Note that ParaView has fairly narrow requirements for the VTK it can
567 use, so only very recent versions are likely to work.
572 A typical ParaView build includes several modules and dependencies. While these
573 are necessary for a fully functional application, there are cases (e.g. in situ
574 use-cases) where a build with limited set of features is adequate. ParaView build supports
575 this using the `PARAVIEW_BUILD_EDITION` setting. Supported values for this setting are:
577 * `CORE`: Build modules necessary for core ParaView functionality.
578 This does not include rendering.
579 * `RENDERING`: Build modules necessary for supporting rendering including views
580 and representations. This includes everything in `CORE`.
581 * `CATALYST`: Build all modules necessary for in situ use cases without
582 rendering and optional components like NetCDF- and HDF5-based readers and
584 * `CATALYST_RENDERING`: Same as `CATALYST` but with rendering supported added.
585 * `CANONICAL` (default): Build modules necessary for standard ParaView build.
588 For cases where a limited set of features is adequate, but the default VTK module rejections
589 for the build edition are too strict, `PARAVIEW_BUILD_EDITION_STRICT` may be set to `OFF` in
590 order to enable specialized IO or rendering modules regardless of the build edition. This is
591 always the behavior when building with `PARAVIEW_USE_EXTERNAL_VTK`
593 ## Debugging facilities
595 ParaView's build is fairly complicated, so a few debugging facilities are
600 CMake provides the `--trace-expand` flag which causes CMake to log all commands
601 that it executes with variables expanded. This can help to trace logic and data
602 through the configure step.
604 Debugging `Find` modules can be done using the `--debug-find` flag (introduced
605 in CMake 3.17) to determine what CMake's `find_` commands are doing.
609 VTK's module system debugging facilities may be controlled by using the
612 * `ParaView_DEBUG_MODULE` (default `OFF`): If enabled, debugging is enabled.
613 Specific portions of the module system may be debugged using the other
615 * `ParaView_DEBUG_MODULE_ALL` (default `OFF`): Enable all debugging messages.
616 * `ParaView_DEBUG_MODULE_building` (default `OFF`): Log when modules are
618 * `ParaView_DEBUG_MODULE_enable` (default `OFF`): Log why modules are
620 * `ParaView_DEBUG_MODULE_kit` (default `OFF`): Log information about
622 * `ParaView_DEBUG_MODULE_module` (default `OFF`): Log information about
624 * `ParaView_DEBUG_MODULE_provide` (default `OFF`): Log why a module is being
626 * `ParaView_DEBUG_MODULE_testing` (default `OFF`): Log testing for VTK
631 ParaView's plugin system has a similar setup:
633 * `ParaView_DEBUG_PLUGINS` (default `OFF`): If enabled, debugging is enabled.
634 Specific portions of the plugin system may be debugged using the other
636 * `ParaView_DEBUG_PLUGINS_ALL` (default `OFF`): Enable all debugging messages.
637 * `ParaView_DEBUG_PLUGINS_building` (default `OFF`): Log when plugins are
639 * `ParaView_DEBUG_PLUGINS_plugin` (default `OFF`): Log information about
644 The following target is provided to ensure that everything needed under `import
645 paraview` is available:
647 * `paraview_all_python_modules`
649 ### Building documentation
651 The following targets are used to build documentation for ParaView:
653 * `ParaViewDoxygenDoc` - build the doxygen documentation from ParaView's C++ source files.
654 * `ParaViewPythonDoc` - build the documentation from ParaView's Python source files.
655 * `ParaViewDoc-TGZ` - build a gzipped tarball of ParaView documentation.
659 [Spack][spack] is a package manager for supercomputers, Linux and macOS. ParaView is one of
660 the packages available in Spack. To install ParaView from spack, you can use:
663 spack install paraview
666 Please refer to [Spack documentation][spack-docs] for ways of customizing the install,
667 including choosing the version and/or variant to build. Based on the version chosen,
668 spack will download appropriate ParaView source and build it.
670 To make it easier to build ParaView using spack from an existing source checkout, we have included
671 relevant spack `package.yaml` files within the ParaView codebase itself. This
672 also makes it easier to keep the spack package up-to-date with any changes to
673 the ParaView buildsystem. With every release (and as frequently as required), we
674 will push the changes to the ParaView paraview.yaml file upstream to the
675 official spack repository.
677 To build your existing source checkout of ParaView using Spack, here are the
681 # assuming you've installed spack as documented in spack docs
682 # and activate the spack environment appropriately
684 # add custom paraview/package.yaml
685 > spack repo add $PARAVIEW_SOURCE_DIR/Utilities/spack/repo
687 # use info to confirm that the paraview package is available
688 # only one version should be available
689 > spack info paraview
691 # install similar to any other spack package
692 # e.g. following command installs osmesa-capable ParaView
695 > spack install paraview+osmesa^mesa~glx^mpich
698 [cmake-download]: https://cmake.org/download
699 [cmake]: https://cmake.org
700 [ffmpeg]: https://ffmpeg.org
701 [git]: https://git-scm.org
702 [gitforwindows]: https://gitforwindows.org/
703 [mesa]: https://www.mesa3d.org
704 [mpi]: https://www.mcs.anl.gov/research/projects/mpi
705 [mpich]: https://www.mpich.org
706 [msmpi]: https://docs.microsoft.com/en-us/message-passing-interface/microsoft-mpi
707 [ninja]: https://github.com/ninja-build/ninja/releases
708 [nvpipe]: https://github.com/NVIDIA/NvPipe
709 [openmpi]: https://www.open-mpi.org
710 [paraview-issues]: https://gitlab.kitware.com/paraview/paraview/-/issues
711 [python]: https://python.org
712 [pythonwindows]: https://www.python.org/downloads/windows/
713 [qt-download]: https://download.qt.io/official_releases/qt
715 [qt-download-5.15.3]: https://download.qt.io/archive/qt/5.15/5.15.3/
716 [tbb]: https://github.com/intel/tbb/releases
717 [visual-studio]: https://visualstudio.microsoft.com/vs/older-downloads
718 [spack]: https://spack.io/
719 [spack-docs]: https://spack.readthedocs.io/en/latest/
