3 if(
4 message(FATAL_ERROR
"CMake >= 2.8.0 required")
6 if(CMAKE_VERSION VERSION_LESS "3.0.0")
7 message(FATAL_ERROR "CMake >= 3.0.0 required")
10 cmake_policy(
VERSION 3.0.0...3.27)
19 set(_cmake_targets_defined
22 foreach(_cmake_expected_target IN ITEMS viskores::vectorization_flags viskores::compiler_flags viskores::developer_flags viskores::optionparser viskores::viskoresdiympi_nompi viskores::viskoresdiy viskores::diy_developer_flags
viskores::diy viskores::lcl viskores::viskores_exec viskores::loguru
viskores::cont viskores::cont_testing viskores::worklet viskores::filter_core viskores::filter viskores::filter_clean_grid viskores::filter_connected_components viskores::filter_vector_analysis viskores::filter_mesh_info viskores::filter_multi_block viskores::filter_contour viskores::filter_geometry_refinement viskores::filter_density_estimate viskores::filter_entity_extraction viskores::filter_field_conversion viskores::filter_field_transform viskores::filter_flow viskores::filter_image_processing viskores::filter_resampling viskores::filter_uncertainty viskores::filter_zfp viskores::lodepng viskores::io viskores::source)
"${_cmake_expected_target}")
24 if(TARGET
") 41 string(REPLACE ";
this export
") 44 unset(_cmake_targets_defined) 45 unset(_cmake_targets_not_defined) 46 unset(_cmake_expected_targets) 49 # Compute the installation prefix relative to this file. 50 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 51 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 52 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 53 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 54 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 55 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 56 if(_IMPORT_PREFIX STREQUAL "/
") 57 set(_IMPORT_PREFIX "") 60 # Create imported target viskores::vectorization_flags 61 add_library(viskores::vectorization_flags INTERFACE IMPORTED) 63 set_target_properties(viskores::vectorization_flags PROPERTIES 64 INTERFACE_COMPILE_OPTIONS "\$<\$<COMPILE_LANGUAGE:CXX>:>
" 67 # Create imported target viskores::compiler_flags 68 add_library(viskores::compiler_flags INTERFACE IMPORTED) 70 set_target_properties(viskores::compiler_flags PROPERTIES 71 INTERFACE_COMPILE_FEATURES "cxx_std_17
" 72 INTERFACE_COMPILE_OPTIONS "\$<\$<COMPILE_LANGUAGE:CXX>:-ffunction-sections>
" 73 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.2/vtkviskores/
viskores" 76 # Create imported target viskores::developer_flags 77 add_library(viskores::developer_flags INTERFACE IMPORTED) 79 set_target_properties(viskores::developer_flags PROPERTIES 80 INTERFACE_COMPILE_OPTIONS "\$<\$<COMPILE_LANGUAGE:CXX>:-Wall;-Wcast-align;-Wextra;-Wpointer-arith;-Wformat;-Wformat-security;-Wshadow;-Wunused;-fno-common;-Wno-unused-
function;-Wchar-subscripts;-Wfloat-conversion;-Wodr>
" 83 # Create imported target viskores::optionparser 84 add_library(viskores::optionparser INTERFACE IMPORTED) 86 set_target_properties(viskores::optionparser PROPERTIES 87 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.2/vtkviskores/
viskores/
viskores/thirdparty/optionparser
" 90 # Create imported target viskores::viskoresdiympi_nompi 91 add_library(viskores::viskoresdiympi_nompi SHARED IMPORTED) 93 # Create imported target viskores::viskoresdiy 94 add_library(viskores::viskoresdiy INTERFACE IMPORTED) 96 set_target_properties(viskores::viskoresdiy PROPERTIES 97 INTERFACE_COMPILE_DEFINITIONS "VISKORESDIY_NO_THREADS;VISKORESDIY_MPI_AS_LIB
" 98 INTERFACE_COMPILE_FEATURES "cxx_std_14
" 99 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.2/vtkviskores/
viskores/
diy/viskoresdiy/include;${_IMPORT_PREFIX}/include/paraview-6.2/vtkviskores/
viskores/
diy/viskoresdiy/include/viskoresdiy/mpi
" 100 INTERFACE_LINK_LIBRARIES "viskores::viskoresdiympi_nompi
" 101 INTERFACE_SYSTEM_INCLUDE_DIRECTORIES "include/paraview-6.2/vtkviskores/
viskores/
diy/viskoresdiy/include;include/paraview-6.2/vtkviskores/
viskores/
" 104 # Create imported target viskores::diy_developer_flags 105 add_library(viskores::diy_developer_flags INTERFACE IMPORTED) 107 set_target_properties(viskores::diy_developer_flags PROPERTIES 108 INTERFACE_COMPILE_OPTIONS "\$<\$<COMPILE_LANGUAGE:CXX>:-Wall;-Wcast-align;-Wchar-subscripts;-Wextra;-Wpointer-arith;-Wformat;-Wformat-security;-Wshadow;-Wunused;-fno-common;-Wfloat-conversion;-Wno-sign-conversion;-Wno-sign-compare;-Wno-cast-align;-Wodr>
" 111 # Create imported target viskores::diy 112 add_library(viskores::diy INTERFACE IMPORTED) 114 set_target_properties(viskores::diy PROPERTIES 115 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.2/vtkviskores/
viskores/
diy" 116 INTERFACE_LINK_LIBRARIES "viskores::viskoresdiy;viskores::viskoresdiympi_nompi
" 119 # Create imported target viskores::lcl 120 add_library(viskores::lcl INTERFACE IMPORTED) 122 set_target_properties(viskores::lcl PROPERTIES 123 INTERFACE_COMPILE_FEATURES "cxx_std_11
" 124 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-6.2/vtkviskores/
viskores/
viskores/thirdparty/lcl/viskoreslcl
" 127 # Create imported target viskores::viskores_exec 128 add_library(viskores::viskores_exec INTERFACE IMPORTED) 130 set_target_properties(viskores::viskores_exec PROPERTIES 131 INTERFACE_COMPILE_DEFINITIONS "VISKORES_DEVICE_LINKED
" 134 # Create imported target viskores::loguru 135 add_library(viskores::loguru INTERFACE IMPORTED) 137 set_target_properties(viskores::loguru PROPERTIES 138 INTERFACE_COMPILE_FEATURES "cxx_std_11
" 139 INTERFACE_LINK_LIBRARIES "dl;Threads::Threads
" 142 # Create imported target viskores::cont 143 add_library(viskores::cont SHARED IMPORTED) 145 set_target_properties(viskores::cont PROPERTIES 146 INTERFACE_LINK_LIBRARIES "viskores::optionparser;
viskores::diy;viskores::lcl;viskores::compiler_flags;Threads::Threads
" 149 # Create imported target viskores::cont_testing 150 add_library(viskores::cont_testing SHARED IMPORTED) 152 set_target_properties(viskores::cont_testing PROPERTIES 156 # Create imported target viskores::worklet 157 add_library(viskores::worklet SHARED IMPORTED) 159 set_target_properties(viskores::worklet PROPERTIES 163 # Create imported target viskores::filter_core 164 add_library(viskores::filter_core SHARED IMPORTED) 166 set_target_properties(viskores::filter_core PROPERTIES 167 INTERFACE_LINK_LIBRARIES "viskores::cont
" 170 # Create imported target viskores::filter 171 add_library(viskores::filter INTERFACE IMPORTED) 173 set_target_properties(viskores::filter PROPERTIES 174 INTERFACE_LINK_LIBRARIES "viskores::filter_core;viskores::filter_clean_grid;viskores::filter_connected_components;viskores::filter_vector_analysis;viskores::filter_mesh_info;viskores::filter_multi_block;viskores::filter_contour;viskores::filter_geometry_refinement;viskores::filter_density_estimate;viskores::filter_entity_extraction;viskores::filter_field_conversion;viskores::filter_field_transform;viskores::filter_flow;viskores::filter_image_processing;viskores::filter_resampling;viskores::filter_zfp
" 177 # Create imported target viskores::filter_clean_grid 178 add_library(viskores::filter_clean_grid SHARED IMPORTED) 180 set_target_properties(viskores::filter_clean_grid PROPERTIES 181 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 184 # Create imported target viskores::filter_connected_components 185 add_library(viskores::filter_connected_components SHARED IMPORTED) 187 set_target_properties(viskores::filter_connected_components PROPERTIES 188 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 191 # Create imported target viskores::filter_vector_analysis 192 add_library(viskores::filter_vector_analysis SHARED IMPORTED) 194 set_target_properties(viskores::filter_vector_analysis PROPERTIES 195 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 198 # Create imported target viskores::filter_mesh_info 199 add_library(viskores::filter_mesh_info SHARED IMPORTED) 201 set_target_properties(viskores::filter_mesh_info PROPERTIES 202 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 205 # Create imported target viskores::filter_multi_block 206 add_library(viskores::filter_multi_block SHARED IMPORTED) 208 set_target_properties(viskores::filter_multi_block PROPERTIES 209 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 212 # Create imported target viskores::filter_contour 213 add_library(viskores::filter_contour SHARED IMPORTED) 215 set_target_properties(viskores::filter_contour PROPERTIES 216 INTERFACE_LINK_LIBRARIES "viskores::filter_core;viskores::filter_vector_analysis;viskores::filter_mesh_info;viskores::filter_multi_block
" 219 # Create imported target viskores::filter_geometry_refinement 220 add_library(viskores::filter_geometry_refinement SHARED IMPORTED) 222 set_target_properties(viskores::filter_geometry_refinement PROPERTIES 223 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 226 # Create imported target viskores::filter_density_estimate 227 add_library(viskores::filter_density_estimate SHARED IMPORTED) 229 set_target_properties(viskores::filter_density_estimate PROPERTIES 230 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 233 # Create imported target viskores::filter_entity_extraction 234 add_library(viskores::filter_entity_extraction SHARED IMPORTED) 236 set_target_properties(viskores::filter_entity_extraction PROPERTIES 237 INTERFACE_LINK_LIBRARIES "viskores::filter_core;viskores::filter_clean_grid
" 240 # Create imported target viskores::filter_field_conversion 241 add_library(viskores::filter_field_conversion SHARED IMPORTED) 243 set_target_properties(viskores::filter_field_conversion PROPERTIES 244 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 247 # Create imported target viskores::filter_field_transform 248 add_library(viskores::filter_field_transform SHARED IMPORTED) 250 set_target_properties(viskores::filter_field_transform PROPERTIES 251 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 254 # Create imported target viskores::filter_flow 255 add_library(viskores::filter_flow SHARED IMPORTED) 257 set_target_properties(viskores::filter_flow PROPERTIES 258 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 261 # Create imported target viskores::filter_image_processing 262 add_library(viskores::filter_image_processing SHARED IMPORTED) 264 set_target_properties(viskores::filter_image_processing PROPERTIES 265 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 268 # Create imported target viskores::filter_resampling 269 add_library(viskores::filter_resampling SHARED IMPORTED) 271 set_target_properties(viskores::filter_resampling PROPERTIES 272 INTERFACE_LINK_LIBRARIES "viskores::filter_core;viskores::filter_density_estimate;viskores::filter_entity_extraction
" 275 # Create imported target viskores::filter_uncertainty 276 add_library(viskores::filter_uncertainty SHARED IMPORTED) 278 set_target_properties(viskores::filter_uncertainty PROPERTIES 279 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 282 # Create imported target viskores::filter_zfp 283 add_library(viskores::filter_zfp SHARED IMPORTED) 285 set_target_properties(viskores::filter_zfp PROPERTIES 286 INTERFACE_LINK_LIBRARIES "viskores::filter_core
" 289 # Create imported target viskores::lodepng 290 add_library(viskores::lodepng INTERFACE IMPORTED) 292 # Create imported target viskores::io 293 add_library(viskores::io SHARED IMPORTED) 295 set_target_properties(viskores::io PROPERTIES 296 INTERFACE_LINK_LIBRARIES "viskores::cont
" 299 # Create imported target viskores::source 300 add_library(viskores::source SHARED IMPORTED) 302 set_target_properties(viskores::source PROPERTIES 303 INTERFACE_LINK_LIBRARIES "viskores::cont;viskores::filter_field_conversion;viskores::filter_multi_block
" 306 # Load information for each installed configuration. 307 file(GLOB _cmake_config_files "${CMAKE_CURRENT_LIST_DIR}/ViskoresTargets-*.cmake
") 308 foreach(_cmake_config_file IN LISTS _cmake_config_files) 309 include("${_cmake_config_file}
") 311 unset(_cmake_config_file) 312 unset(_cmake_config_files) 314 # Cleanup temporary variables. 317 # Loop over all imported files and verify that they actually exist 318 foreach(_cmake_target IN LISTS _cmake_import_check_targets) 319 if(CMAKE_VERSION VERSION_LESS "3.28
" 320 OR NOT DEFINED _cmake_import_check_xcframework_for_${_cmake_target} 321 OR NOT IS_DIRECTORY "${_cmake_import_check_xcframework_for_${_cmake_target}}
") 322 foreach(_cmake_file IN LISTS "_cmake_import_check_files_for_${_cmake_target}
") 323 if(NOT EXISTS "${_cmake_file}
") 324 message(FATAL_ERROR "The imported
target \
"${_cmake_target}\" references the file 326 but this file does not exist. Possible reasons include: 327 * The file was deleted, renamed, or moved to another location. 328 * An install or uninstall procedure did not complete successfully. 329 * The installation package was faulty and contained 330 \"${CMAKE_CURRENT_LIST_FILE}\" 331 but not all the files it references. 337 unset("_cmake_import_check_files_for_${_cmake_target}
") 340 unset(_cmake_import_check_targets) 342 # This file does not depend on other imported targets which have 343 # been exported from the same project but in a separate export set. 345 # Commands beyond this point should not need to know the version. 346 set(CMAKE_IMPORT_FILE_VERSION) boost::graph_traits< vtkGraph *>::vertex_descriptor target(boost::graph_traits< vtkGraph *>::edge_descriptor e, vtkGraph *)
