1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc
45 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
46  foreach(file
47  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv6.2.so.6.2"
48  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv6.2.so.1"
49  )
50  if(EXISTS "${file}" AND
51  NOT IS_SYMLINK "${file}")
52  file(RPATH_CHECK
53  FILE "${file}"
54  RPATH "\$ORIGIN")
55  endif()
56  endforeach()
57  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
58  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkxdmf2-pv6.2.so.6.2"
59  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkxdmf2-pv6.2.so.1"
60  )
61  foreach(file
62  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv6.2.so.6.2"
63  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkxdmf2-pv6.2.so.1"
64  )
65  if(EXISTS "${file}" AND
66  NOT IS_SYMLINK "${file}")
67  file(RPATH_CHANGE
68  FILE "${file}"
69  OLD_RPATH "\$ORIGIN:"
70  NEW_RPATH "\$ORIGIN")
71  if(CMAKE_INSTALL_DO_STRIP)
72  execute_process(COMMAND "/usr/bin/strip" "${file}")
73  endif()
74  endif()
75  endforeach()
76 endif()
77
78 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
79  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkxdmf2-pv6.2.so")
80 endif()
81
83 endif()
84
85 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/vtkxdmf2/libsrc" TYPE FILE FILES
87  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/Xdmf.h"
88  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfExport.h"
89  "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfConfig.h"
90  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfArray.h"
91  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDOM.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDataDesc.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDataItem.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDataStructure.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDataTransform.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfElement.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfExpression.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfHDF.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfHDFSupport.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfHeavyData.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfInformation.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfLightData.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfObject.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfValues.h"
105  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfValuesBinary.h"
106  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfValuesHDF.h"
107  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfValuesXML.h"
108  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfAttribute.h"
109  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDomain.h"
110  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDsm.h"
111  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDsmBuffer.h"
112  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDsmComm.h"
113  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfDsmMsg.h"
114  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfGeometry.h"
115  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfGrid.h"
116  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfH5Driver.h"
117  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfMap.h"
118  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfRegion.h"
119  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfRoot.h"
120  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfSet.h"
121  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfTime.h"
122  "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfTopology.h"
123  )
124 endif()
125
126 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
127 endif()
128
