1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
47 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkh5hut-pv6.2.so.6.2" 48 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkh5hut-pv6.2.so.1" 50 if(EXISTS
"${file}" AND
51 NOT IS_SYMLINK
"${file}")
" TYPE SHARED_LIBRARY FILES 58 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkh5hut-pv6.2.so.6.2
" 59 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkh5hut-pv6.2.so.1
" 62 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkh5hut-pv6.2.so.6.2
" 63 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkh5hut-pv6.2.so.1
" 65 if(EXISTS "${file}
") 71 if(CMAKE_INSTALL_DO_STRIP) 72 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 78 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 79 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkh5hut-pv6.2.so
" OR NOT CMAKE_INSTALL_COMPONENT) 85 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 86 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/vtkh5hut/src/include
" TYPE FILE FILES 87 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5_attachments.h
" 88 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5_err.h
" 89 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5_file.h
" 90 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5_file_attribs.h
" 91 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5_log.h
" 92 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5_model.h
" 93 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5_step_attribs.h
" 94 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5Block_attribs.h
" 95 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5Block_io.h
" 96 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5Block_model.h
" 97 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5Fed_adjacency.h
" 98 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5Fed_model.h
" 99 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5Fed_retrieve.h
" 100 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5Fed_store.h
" 101 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5Fed_tags.h
" 102 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5hut.h
" 103 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5Part_io.h
" 104 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/H5Part_model.h
" 105 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/vtk_h5hut_mangle.h
" 106 "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/h5hut/vtkh5hut/src/include/vtkh5hut_export.h
" 107 "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/h5hut/vtkh5hut/src/include/config.h
" 109 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/vtkh5hut/src/include/h5core
" TYPE FILE FILES 110 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5_attachments.h
" 111 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5_err.h
" 112 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5_file.h
" 113 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5_file_attribs.h
" 114 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5_log.h
" 115 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5_model.h
" 116 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5_step_attribs.h
" 117 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5_syscall.h
" 118 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5_types.h
" 119 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5b_attribs.h
" 120 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5b_io.h
" 121 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5b_model.h
" 122 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5t_adjacencies.h
" 123 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5t_map.h
" 124 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5t_model.h
" 125 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5t_octree.h
" 126 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5t_retrieve.h
" 127 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5t_store.h
" 128 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5t_tags.h
" 129 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5u_io.h
" 130 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/h5hut/vtkh5hut/src/include/h5core/h5u_model.h
" 134 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
