1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/glad/vtkglad 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
47 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkglad-pv6.2.so.6.2" 48 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkglad-pv6.2.so.1" 50 if(EXISTS
"${file}" AND
51 NOT IS_SYMLINK
"${file}")
" TYPE SHARED_LIBRARY FILES 58 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkglad-pv6.2.so.6.2
" 59 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkglad-pv6.2.so.1
" 62 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkglad-pv6.2.so.6.2
" 63 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkglad-pv6.2.so.1
" 65 if(EXISTS "${file}
") 71 if(CMAKE_INSTALL_DO_STRIP) 72 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 78 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 79 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkglad-pv6.2.so
" OR NOT CMAKE_INSTALL_COMPONENT) 85 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 86 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/vtkglad/include/EGL
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/glad/vtkglad/include/EGL/eglplatform.h
") 87 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/vtkglad/include/KHR
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/glad/vtkglad/include/KHR/khrplatform.h
") 88 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2/vtkglad/include/glad
" TYPE FILE FILES 89 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/glad/vtkglad/include/glad/vtk_gl_mangle.h
" 90 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/glad/vtkglad/include/glad/gl.h
" 91 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/glad/vtkglad/include/glad/vtk_egl_mangle.h
" 92 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/glad/vtkglad/include/glad/egl.h
" 93 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/glad/vtkglad/include/glad/vtk_glx_mangle.h
" 94 "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/glad/vtkglad/include/glad/glx.h
" 98 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
