1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/glad 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/glad/vtkglad/cmake_install.cmake")
50 if(CMAKE_INSTALL_COMPONENT STREQUAL "license" OR NOT CMAKE_INSTALL_COMPONENT)
51 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkglad
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/glad/vtkglad/LICENSE
") 54 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 55 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/glad/vtkglad.spdx
") 58 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 59 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/glad/vtk_glad.h
