1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/gl2ps
47  include("/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/gl2ps/vtkgl2ps/cmake_install.cmake")
48 endif()
49
50 if(CMAKE_INSTALL_COMPONENT STREQUAL "license" OR NOT CMAKE_INSTALL_COMPONENT)
51  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkgl2ps" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/ThirdParty/gl2ps/vtkgl2ps/COPYING.GL2PS")
52 endif()
53
54 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
55  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/gl2ps/vtkgl2ps.spdx")
56 endif()
57
58 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
59  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/ThirdParty/gl2ps/vtk_gl2ps.h")
60 endif()
61
