1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkRenderingContext2D-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRenderingContext2D-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingContext2D-pv6.2.so.6.2
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingContext2D-pv6.2.so.1
" 54 if(EXISTS "${file}
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingContext2D-pv6.2.so.6.2
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingContext2D-pv6.2.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingContext2D-pv6.2.so.6.2
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRenderingContext2D-pv6.2.so.1
" 69 if(EXISTS "${file}
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRenderingContext2D-pv6.2.so
" TYPE FILE FILES 93 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkBlockItem.h
" 94 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkBrush.h
" 95 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkContext2D.h
" 96 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkContext3D.h
" 97 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkContextActor.h
" 98 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkContextClip.h
" 101 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkContextItem.h
" 105 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkContextScene.h
" 107 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkImageItem.h
" 108 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/vtkLabeledContourPolyDataItem.h
" 110 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkPen.h
" 111 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/vtkPolyDataItem.h
" 112 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkPropItem.h
" 113 "/builds/gitlab-kitware-sciviz-ci/VTK/Rendering/Context2D/
vtkTooltipItem.h
" 117 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 118 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES 119 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Context2D/vtkRenderingContext2DModule.h
" 120 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Context2D/vtkRenderingContext2DSerDes.h
" 124 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 125 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Rendering/Context2D/vtkRenderingContext2D.spdx
