1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelNetCDF 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkIOParallelNetCDF-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOParallelNetCDF-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelNetCDF-pv6.2.so.6.2
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelNetCDF-pv6.2.so.1
" 54 if(EXISTS "${file}
") 58 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOParallelNetCDF-pv6.2.so.6.2
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOParallelNetCDF-pv6.2.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelNetCDF-pv6.2.so.6.2
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOParallelNetCDF-pv6.2.so.1
" 69 if(EXISTS "${file}
") 73 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 74 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOParallelNetCDF-pv6.2.so
" TYPE FILE FILES 92 "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelNetCDF/
vtkPSLACReader.h
" 96 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 97 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/ParallelNetCDF/vtkIOParallelNetCDFModule.h
") 100 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses
" OR NOT CMAKE_INSTALL_COMPONENT) 101 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkIOParallelNetCDF
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/IO/ParallelNetCDF/LICENSE
") 104 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 105 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/ParallelNetCDF/vtkIOParallelNetCDF.spdx
