1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIONetCDF-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIONetCDF-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIONetCDF-pv6.2.so.6.2"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIONetCDF-pv6.2.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIONetCDF-pv6.2.so.6.2"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIONetCDF-pv6.2.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIONetCDF-pv6.2.so.6.2"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIONetCDF-pv6.2.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:"
74  NEW_RPATH "\$ORIGIN")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIONetCDF-pv6.2.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/vtkMPASReader.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/vtkNetCDFAccessor.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/vtkXArrayAccessor.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/vtkNetCDFCAMReader.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/vtkNetCDFCFReader.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/vtkNetCDFCFWriter.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/vtkNetCDFPOPReader.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/vtkNetCDFReader.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/vtkNetCDFUGRIDReader.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/vtkSLACParticleReader.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/vtkSLACReader.h"
102  )
103 endif()
104
105 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/NetCDF/vtkIONetCDFModule.h")
107 endif()
108
109 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses" OR NOT CMAKE_INSTALL_COMPONENT)
110  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkIONetCDF" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/IO/NetCDF/LICENSE")
111 endif()
112
113 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/NetCDF/vtkIONetCDF.spdx")
115 endif()
116
