1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVTKExtensionsInteractionStyle-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsInteractionStyle-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.2.so.6.2"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.2.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.2.so.6.2"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.2.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.2.so.6.2"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.2.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
74  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.2.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVCameraManipulator.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkCameraManipulatorGUIHelper.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVInteractorStyle.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVJoystickFly.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVJoystickFlyIn.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVJoystickFlyOut.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballMoveActor.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballMultiRotate.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballPan.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballPanAxisConstrained.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballRoll.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballRotate.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballEnvironmentRotate.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballZoom.h"
105  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/vtkPVTrackballZoomToMouse.h"
106  )
107 endif()
108
109 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
110  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/InteractionStyle/vtkPVVTKExtensionsInteractionStyleModule.h")
111 endif()
112
113 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses" OR NOT CMAKE_INSTALL_COMPONENT)
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkPVVTKExtensionsInteractionStyle" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/LICENSE")
115 endif()
116
117 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
118  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/InteractionStyle/vtkPVVTKExtensionsInteractionStyle.spdx")
119 endif()
120
Helper class for Camera Manipulators.
Pans camera with x y mouse movements.
Rotates camera with xy mouse movement.
This camera manipulator combines the vtkPVTrackballRotate and vtkPVTrackballRoll manipulators in one...
Fly camera towards or away from the object.
Rolls camera around a point.
Abstraction of style away from button.
Zooms camera with vertical mouse movement.
Rotates the environment with xy mouse movement.
Zooms camera with vertical mouse movement to mouse position.
interactive manipulation of the camera
