1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOSPCTH 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkPVVTKExtensionsIOSPCTH-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsIOSPCTH-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOSPCTH-pv6.2.so.6.2
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOSPCTH-pv6.2.so.1
" 54 if(EXISTS "${file}
") 58 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOSPCTH-pv6.2.so.6.2
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOSPCTH-pv6.2.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOSPCTH-pv6.2.so.6.2
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOSPCTH-pv6.2.so.1
" 69 if(EXISTS "${file}
") 73 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 74 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOSPCTH-pv6.2.so
" TYPE FILE FILES 91 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOSPCTH/
vtkSpyPlotBlock.h
" 101 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 102 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2
" TYPE FILE FILES 104 "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOSPCTH/vtkPVVTKExtensionsIOSPCTHModule.h
" 108 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses
" OR NOT CMAKE_INSTALL_COMPONENT) 109 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkPVVTKExtensionsIOSPCTH
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOSPCTH/LICENSE
") 112 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 113 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOSPCTH/vtkPVVTKExtensionsIOSPCTH.spdx
Maps strings to vtkSpyPlotUniReaders.
vtkSpyPlotFileSeriesReader extends vtkFileSeriesReader to change the number of output ports on this r...
Read SPCTH Spy Plot history file format.
vtkSpyPlotIStream represents input functionality required by the vtkSpyPlotReader and vtkSpyPlotUniRe...
Read SPCTH Spy Plot file format.
Represents a SpyPlot Block Grid.
