1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/Testing 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOCore/Testing/Cxx/cmake_install.cmake")
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51 # Include the install script for the subdirectory. 52 include(
"/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOCore/Testing/Python/cmake_install.cmake")
