1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCGNS/Testing
47  include("/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOCGNS/Testing/Cxx/cmake_install.cmake")
48 endif()
49
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51  # Include the install script for the subdirectory.
52  include("/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOCGNS/Testing/Python/cmake_install.cmake")
53 endif()
54
