1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/Prism
47  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Filters/cmake_install.cmake")
48 endif()
49
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51  # Include the install script for the subdirectory.
52  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Views/cmake_install.cmake")
53 endif()
54
55 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
56  # Include the install script for the subdirectory.
57  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager/cmake_install.cmake")
58 endif()
59
60 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
61  # Include the install script for the subdirectory.
62  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Readers/cmake_install.cmake")
63 endif()
64
65 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
66  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2/Prism-targets.cmake")
67  file(DIFFERENT _cmake_export_file_changed FILES
68  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2/Prism-targets.cmake"
69  "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/CMakeFiles/Export/9e46d3f506773a16a8c3559c1dbd58c7/Prism-targets.cmake")
70  if(_cmake_export_file_changed)
71  file(GLOB _cmake_old_config_files "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2/Prism-targets-*.cmake")
72  if(_cmake_old_config_files)
73  string(REPLACE ";" ", " _cmake_old_config_files_text "${_cmake_old_config_files}")
74  message(STATUS "Old export file \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2/Prism-targets.cmake\" will be replaced. Removing files [${_cmake_old_config_files_text}].")
75  unset(_cmake_old_config_files_text)
76  file(REMOVE ${_cmake_old_config_files})
77  endif()
78  unset(_cmake_old_config_files)
79  endif()
80  unset(_cmake_export_file_changed)
81  endif()
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/CMakeFiles/Export/9e46d3f506773a16a8c3559c1dbd58c7/Prism-targets.cmake")
83  if(CMAKE_INSTALL_CONFIG_NAME MATCHES "^([Rr][Ee][Ll][Ee][Aa][Ss][Ee])$")
84  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/CMakeFiles/Export/9e46d3f506773a16a8c3559c1dbd58c7/Prism-targets-release.cmake")
85  endif()
86 endif()
87
88 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
89  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.2" TYPE FILE RENAME "Prism-vtk-module-properties.cmake" FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/CMakeFiles/Prism-vtk-module-properties.cmake.install")
90 endif()
91
92 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
93  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPrismFiltersCS.a")
94 endif()
95
96 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
97  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPrismReadersCS.a")
98 endif()
99
100 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
101  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPrismServerManagerCS.a")
102 endif()
103
104 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
105  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPrismViewsCS.a")
106 endif()
107
108 if(CMAKE_INSTALL_COMPONENT STREQUAL "plugins" OR NOT CMAKE_INSTALL_COMPONENT)
109  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/Prism.so" AND
110  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/Prism.so")
111  file(RPATH_CHECK
112  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/Prism.so"
113  RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
114  endif()
115  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism/Prism.so")
116  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/Prism.so" AND
117  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/Prism.so")
118  file(RPATH_CHANGE
119  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/Prism.so"
120  OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.2/plugins/Prism:/builds/gitlab-kitware-sciviz-ci/build/lib64:/usr/lib64/openmpi/lib:"
121  NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
122  if(CMAKE_INSTALL_DO_STRIP)
123  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.2/plugins/Prism/Prism.so")
124  endif()
125  endif()
126 endif()
127
128 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
129  # Include the install script for the subdirectory.
130  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Testing/cmake_install.cmake")
131 endif()
132
